[ORDER] Erica Synths eurorack PSU
Girts23
Post by Girts23 » Sun Nov 16, 2014 2:04 pm
With more modules in development, I felt, I need several eurorack +-12V power supply units. Therefore I decided to come up with a cost-effective PSU kit! :)
Erica Synths 12V bipolar 1,5A PSU hardware kit is arranged to build slim, eurorack standard PSU, easy to install in any modular system. Hardware kit contains PCB and all unconventional parts that are expensive to source alone - heat sinks, spacers, lugs, fuse holder, etc. Full kit contains all parts needed to complete the PSU. Sorry, full kits for 220V only at the moment, but if interested, you can source power transformer yourself.
Price:
PCB and hardware kit - 25EUR
Full kit - 55EUR
Check Erica Synths SHOP if interested!
Erica-Manual-bipolar.pdf
(3.35 MiB) Downloaded 108 times
tekzon
Post by tekzon » Sun Nov 16, 2014 10:38 pm
hey!! thank you sir!
qfactor
Post by qfactor » Mon Nov 17, 2014 12:16 am
What's international shipping like for a full kit? :hmm:
Also, what's the dimensions for the PCB? Considering if I get it, perhaps I could also house it in one of those hobbyist plastic casings for safety sake :despair:
snaper
Post by snaper » Mon Nov 17, 2014 1:49 am
Wow, finally, I can start building my second 9U :D
What is inside the PCB + HW kit?
What kind of power connector are in the full kit and is the toroid transformer included?
snaper
Post by snaper » Mon Nov 17, 2014 1:50 am
Oh another question : Is there a plan or etch file or something like this for a distribution board?
latigid on
Post by latigid on » Mon Nov 17, 2014 2:24 am
1.5 A is total load or per rail? Seems like the latter for those sized heatsinks.
Nantonos
Post by Nantonos » Mon Nov 17, 2014 4:12 am
Is 1.5A a measured, continuous value? Or a measured, peak value? Or is it just that the regulators are 1.5A parts?
I ask because those heatsinks look small and seem to be oriented so the fins would be at right angles to the airflow. The caps are also crammed between a hot heatsink and a warmish transformer (like on Doepfer PSU2).
Is there a ripple measurement at 80% load?
ondes | current rack
I am afraid a firmware change will not be able to turn a rather expensive 16-bit DAC into a 16-bit ADC, and flip all those op-amps :)
Girts23
Post by Girts23 » Mon Nov 17, 2014 6:37 am
1,5A is peak value, yes. It's not good idea to use it on the full load continuously. But otherwise parts are similar to those used in Doepfer PSU. I have built like 10 of these over last few years - this PSU works with 2x84HP case stuffed with typical eurorack modules without problem.
Parts of the hardware kit are shown on the picture.
PCB size is 87mmx180mm
Shipping EU - 5EUR, elsewhere in the world 8EUR.
Actually I have made a 14 connectors distribution board for myself, as well, if interested, I can make it available for some 10EUR.
NS4W
Post by NS4W » Mon Nov 17, 2014 6:44 am
I see two trimmers, any high voltage calibration procedures we should know of? Switching or linear?
qfactor
Post by qfactor » Mon Nov 17, 2014 7:47 am
Also, as mentioned by snaper, is the toroid (sp?) transformer, part of the full kit too? :tu:
Thank you for answering all these questions! :yay:
Girts23
Post by Girts23 » Mon Nov 17, 2014 7:48 am
NS4W wrote:I see two trimmers, any high voltage calibration procedures we should know of? Switching or linear?
No, trimmers adjust output voltage (range from ~16V to what you need)
qfactor
Post by qfactor » Mon Nov 17, 2014 7:51 am
One more thing, since you mentioned about the distro board, how many sockets does it have? And what are the dimensions?
Girts23
Post by Girts23 » Mon Nov 17, 2014 8:05 am
qfactor wrote:Also, as mentioned by snaper, is the toroid (sp?) transformer, part of the full kit too? :tu:
Yes, a transformer is included in the kit. But only 220V transformers are available at the moment. Sorrrryyyy :)
Girts23
Post by Girts23 » Mon Nov 17, 2014 8:06 am
qfactor wrote:One more thing, since you mentioned about the distro board, how many sockets does it have? And what are the dimensions?
300x32mm, 14 sockets. But those will be available late next week.
qfactor
Post by qfactor » Mon Nov 17, 2014 8:11 am
Thanks again! I'm interested in the full kit, but also want to get a distribution board, so I wait till next week to purchase both? :hmm:
NS4W
Post by NS4W » Mon Nov 17, 2014 8:49 am
Ok. I'll wait until everything is in the shop then :)
snaper
Post by snaper » Mon Nov 17, 2014 9:11 am
Is there a good replacement for the KBL04?
Can't find it in my locals list :(
roglok
Post by roglok » Mon Nov 17, 2014 9:24 am
Shouldn't AC mains be double fused? Live and neutral can be reversed with Type F mains plugs. :deadbanana:
spotta
Needs more wigglin' time
Post by spotta » Mon Nov 17, 2014 9:52 am
qfactor wrote:Thanks again! I'm interested in the full kit, but also want to get a distribution board, so I wait till next week to purchase both? :hmm:
+1. Nice!
Spotta
Nantonos
Post by Nantonos » Mon Nov 17, 2014 5:05 pm
Girts23 wrote:1,5A is peak value, yes. It's not good idea to use it on the full load continuously. But otherwise parts are similar to those used in Doepfer PSU.
Thanks for the clarification about a peak value.
What sort of continuous load can it handle, and what is the ripple at 80% of that?
clive.grace
Post by clive.grace » Tue Nov 18, 2014 5:07 pm
Superb. I assume 15U (5 x 3U) will suit ~2 x PSUs?
Bought
Good timing as I have just put vents and a 13A jack in my rack
spotta
Post by spotta » Sun Dec 07, 2014 5:54 pm
Do the mounting holes on the PCB match Doepfer ones?
My case already has holes drilled for Doepfer PSUs
Spotta
qfactor
Post by qfactor » Sun Dec 07, 2014 6:59 pm
Are the distros also ready for sale on your site already?
clive.grace
Post by clive.grace » Mon Dec 08, 2014 3:54 am
Mine arrived last week. A nice easy build and it replaced a blown out Makenoise Powered card (scrape off the components and its still a fine passive card). Added on MI Volts and voila, back in the game. Also powers a TipTop passive card.
ImageEricasynths Linear 12/-12V PSU by c-g., on Flickr
WRT Doepfer Spacings I think so, there have been few variants of the PSU in the past, my pic ought to be able to be viewable at 1:1 and you can compare mounting holes.
tekzon
Post by tekzon » Wed Dec 17, 2014 7:45 am
Hi there!
can I order distro board already,
i don't see them in the shop?
