DIY-1200 sync cable KIT
b3nsf
Post by b3nsf »
Just soldered up some more of these :guinness:
its like saying you experience michaelangelo because there is a picture on your happy meal
--shreddoggie
Last time I checked there was nothing Vanilla about old Chi- Acid....that shit's Chocolate as it gets.
--Kendall Station
sauflesautres
Post by sauflesautres »
b3nsf is a great guy. Cable was shipped fast and very well packed. I needed some tech support and he did all he could to help me out. Super patient guy with me although i argued (and i was wrong).
The cable is very well made and i'm happy to be able to sync my Acidlab Bassline to my modular :D
Effie
Post by Effie »
PM'd you about it, b3nsf :)
bassnode
Post by bassnode »
Have anymore of these b3nsf? I'm in SF so could pick up locally.
PM me if you do. Thanks!
mrsnatches
Post by mrsnatches »
:hail:
mrsnatches
Just wanted to add --- got my cable superfast and it works flawlessly.
Using it to clock an Intellijel Metropolis w either a tr-808 or an Elektron A4. Cannot understate the beauty of not having to manually reset the Metropolis any longer.
NorthBro
Post by NorthBro »
hello b3nsf
is this cable working to sync from Analog Rytm to Make Noise Wogglebug?
Regards.
b3nsf
Post by b3nsf »
:sb:
--shreddoggie
--Kendall Station
steef
Post by steef »
This is awesome - PMing you for details now. Thanks. (Apologies for lame post, but I signed up to MW specifically for this purchase and I needed to make a first post before I can PM haha :)
manfromuncool
Post by manfromuncool »
Received the cable today.
TR-606 starting, stopping and clocking FH-1, then midi out to Octatrack. Along with the trigger outs, lots of fun to be had.
Thank you :).
steef
Post by steef »
Received the cable his week - thanks!
b3nsf
Post by b3nsf »
I have 5 built cables in stock, first come, first serve!!!
--shreddoggie
--Kendall Station
mylomod
Post by mylomod »
Cable arrived yesterday - super quick. Looks great, professional.
Now - I have to wait for the weekend - grrrrrrrr.
tylrprtr
Post by tylrprtr »
The quality of this adapter is wonderful, and b3nsf had it shipped out immediately!
I ended up using a 3,5mm TRS to dual 3.5mm TS adapter to plug my BSP into my Pam's though. It was a more simple solution than adapter into midi cable into another adapter.
tommy.york
Post by tommy.york »
tylrprtr wrote:The quality of this adapter is wonderful, and b3nsf had it shipped out immediately!
However, I don't think these are the same spec as the Expert Sleepers DJ-1200, which I assumed they were since the Expert Sleepers site linked me to this thread. I say this because this adapter has a 180 degree 5 pin din plug, while the Expert Sleepers ones have a 120 degree 5 pin Din plug.
I too found this through the ES site.
Will this work to sync Grids from my Rytm using 24 ppq din sync?
tylrprtr
Post by tylrprtr »
Disregard my post, I was an idiot. It looked like the plugs were dissimmilar to the ones included with my Best Step pro but they totally fit.
I believe that should work, as long as you set your grids to 24ppqn in it's options mode. I believe the dinsync run gate will get the Grids to reset correctly. However, I believe it will keep running if you stop the Rytm though.
b3nsf
Post by b3nsf »
just an update, I switched to a more high quality wire, Canare GS-4 and it costs more, also I was not charging enough for the amount of time it takes to make the cables... so I had to raise prices on built cables... they now cost 25$ Please consider this small amount of money as a tip to a hard working artist...
A few lucky people got the new wire for the old price, you know who you are? look if the wire says "Canare GS4 - Made in Japan" on it :mrgreen:
--shreddoggie
--Kendall Station
b3nsf
Post by b3nsf »
I have 6 cables in stock at the moment :stardance:
--shreddoggie
--Kendall Station
tommy.york
Just got mine. Solid work, b3nsf.
I'm taking Analog Rytm din24 into the MI Grids... though tapping the stop button once doesn't stop the Grids, tapping it twice does. :nana:
Jbone1313
Post by Jbone1313 »
Got mine. Works wonderfully. Sending DIN 24 from RYTM to Trigger Riot. Yay. Thanks b3nsf!
lambwolf
Post by lambwolf »
got mine yesterday. No problems at all using the Analog RYTM and Pamela's Workout together. thanks
Mercutio
Post by Mercutio »
Hi, still available ?
NorthBro
Post by NorthBro »
b3nsf
hello, do you have some din sync cables?
Cheers.
kubus038
Din Sync - trigger reset cable
Post by kubus038 »
b3nsf
HI,
Do you still sell these kits or ready fabricated cables?
If yes can i order some ?
Do you ship to Holland?
Cheers,
Bart
Seaweed Sound
Re: DIY-1200 sync cable KIT
Post by Seaweed Sound »
b3nsf wrote:however there is a seller on ebay who is making these in china and they are half the price I was charging...
http://www.ebay.com/usr/seaweedsound?_t ... 7675.l2559
http://www.ebay.com/itm/EURORACK-Modula ... 3026523377
FYI these are currently hand soldered in the USA
