The design files are now up: Mikrophonie Contact Mic Documentation.
You'll find:
Documentation
Schematic
BOM
and full PCB design files.
This is a very simple circuit; apart from the 3.5mm jacks (which are Erthenvar / Thonk) pretty much everything should be available from your parts drawer or from Radio Shack / Maplin / Bitsbox. The PTC fuses may be hard to find, but any PTC fuse with a trip current above 100ma and 5mm lead spacing will work.
None of the component values are super critical, but changes will obviously effect gain levels. A pot below 50k will reduce the gain range, a larger pot will increase it.
The two PCBs (circuit and panel) are optimised for Seeed Studio Fusion PCB - you can buy 5 sets for about $65.
As usual, this is Creative Commons licensed: CC BY SA
Alternatively, WAITING LIST FOR THONK ORDERS IS HERE
British-made contact microphones with 3.5mm jacks are available from Jez Riley French.
My next design is currently being beta tested. If all goes well, I'll release the design files for this in the next few weeks.
Mikrophonie is a very simple contact mic module. There is a small piezo disk mounted behind the 4hp panel, or you can plug in an external mic (they're very easy to make).
The panel is PCB with no soldermask. The raw PCB fibreglass has quite a nice rough texture - rubbing it with a finger or a plectrum creates quite a wide range of sounds. The back of the panel is plated and grounded for shielding.
The mic will also pick up all the physical sounds in your modular - patching, cables rustling, switches, fingers on knobs - without picking up airborne sounds i.e. the sound your modular is making. At very high sound levels will pick up vibrations from the speaker output and start to feedback.
Here are a couple of great demo videos from Leafcutter John and Robin Rimbaud:
And here's a sound clip of the module picking up patching noises, feeding back through an Echophon
Here's a much cleaner demo of the built in microphone, just picking up the sound of the switches and knobs:
