Edelweiss - Build thread
Jonachi
Post by Jonachi »
So I made a little build document for the edelweiss panel. Original thread: viewtopic.php?t=94479&start=all&postday ... torder=asc
I can confirm that the build doc seems to be correct, at least one person has built their panel using it, I'm about 75% done with mine and so far it has been holding up. If you have suggestions how to improve it you can post your findings in this thread.
Edelweiss build document v 1.1.pdf
(866.81 KiB) Downloaded 487 times
modintx
Post by modintx »
This is fantastic Jonachi - extremely helpful and well laid out - thank you so much for taking the time to construct!!
:hail:
Jonachi
Post by Jonachi »
Thank you modintx
Jonachi
Post by Jonachi »
Got a new picture from Nordlead for the wiring of the random voltage processor. I've included this in a new version of the build doc, which you (still) find in the first post. No other changes have been made at this point.
Reality Checkpoint
Confused By Electricity
Post by Reality Checkpoint »
I know that I will be relying on this thread heavily at build time!
Thank you for your hard work Jonachi, it is much appreciated by me.
jooks
Post by jooks »
Great work :bananaguitar:
Maybe a lunchmeeting on tuesday?
modintx
Post by modintx »
Getting started :party:
Jonachi
Post by Jonachi »
Wow! Nice work!
modintx
Post by modintx »
Thanks Jonachi - I finally found nice dark blue jacks :tu:
nordlead
Post by nordlead »
modintx wrote:Thanks Jonachi - I finally found nice dark blue jacks :tu:
Hey, that's a surprise! Looks great! I like the Emerson (lighter) blue as well but never managed to come across the (old?) dark blue ones - mind sharing the source/manufacturer? There've been extensive discussions as to where the jacks originate ...
modintx
Post by modintx »
Sure these are from a company in California called E-Z-Hook. They have posts so you have to wind the hook-up wire around and solder - no problem, just different from the usual thru hole arrangement. These are't the same as STS but the color is very very close.
Price break at Qty 250 down to $.87 by the way.
http://catalog.e-z-hook.com/item/connec ... posts/9284?
Jonachi
Post by Jonachi »
Started my build today, populated the Noise PCB. Want to try it out with euro jacks before I use it for the panel. Got a little confused by this:
The resistor marked 100k* on the PCB is not needed unless you are experimenting with isolating the S&H from the noise circuit. If a resistor is inserted between the S&HT pads, the resistor in the 100k* forms the lower leg of a voltage divider with it. The pair of resistors can then be used to adjust the range of the voltages being fed into the S&H.
So first build question: Is the 100k* used or not for edelweiss?
modintx
Post by modintx »
^^^Good question. I checked the electro-music CGS forum and I don't see anyone who's built this combo of CGS92+97 just yet. Maybe best answered by Ken Stone.
My assumption right now is we DO NOT need it as we do NOT want it isolated as we require full functionality. Happy to be corrected.
After marking up the back of the panel ready for hook up wire, I started populating my Pulse divider / Logic PCB today...
Enjoy your build!
Jonachi
Post by Jonachi »
Yeah, I pretty much assumed the same, if not it will be easier to install it than unsolder it (once the boards are in place). My feeling right now is that Edelweiss feels like an easier build than the BOG (which I just completed). I might take that back though! :hihi:
nordlead
Post by nordlead »
I also finished the Noise, upper part (noise) looks good, the S&H section seems to require the "X" trace cut that Ken describes in the Setup part on his page. Haven't done that yet as I want to try out other transistors as noise source - maybe the different level changes the behavior of the S&H part. If the S&H is separated this way (and C connected to the S&H pad) my guess is that only tweaking the RPD resistor is necessary (without installing the 100K*), but this is just a guess.
Did you guys get the S&H section to work (to your satisfaction)?
In general I'll try to get the Noise source side of the Random Source fully working, then get at least one SSG (or both) fully working before hooking up one SSG as a RVG.
I've pretty much stuffed all the modules, but wired only the DUSG and CGS81 so far. Pro-tip: when building the DUSG, make sure you connect all the straight lines marked on the pcb with a lead... :oops:
modintx
Post by modintx »
Thanks nordlead, I'm due to stuff my DUSG's this weekend so good timing on the tips :tu:
Have not got to noise yet as I am missing the PN4250 from Ken. I'll get one when I order the PCB's for LaBestia etc - if you find alternative one that you like please do let us know.
Progress so far - CGS89 and CGS36 Stuffed and mounted (sounds like a safari hunt) - will do hookup wire and test this weekend as well.
:party:
J3RK
Post by J3RK »
You should be able to use the PN4250A as well:
http://www.mouser.com/ProductDetail/Cen ... lj3XHEg%3d
I've used these in some Serge circuits before.
modintx
Post by modintx »
Thanks J3RK, interesting as that part indicates low noise, not sure if that what we're after in this application? :hmm:
From Ken's Site:
If you are sourcing your own parts, it is best to install a socket for the 2N4250 transistor marked N (for noise). You will need to try multiple devices to find one that is sufficiently noisy. Boards purchased from me will include a hand-selected PN4250 which can be installed with no further testing, in reverse to the D symbol on the PCB.
J3RK
Post by J3RK »
Ahh, I kind of misread your post. I thought it was for the DUSG. Yeah, you probably want something more general purpose. These ones would probably still produce white noise, but possibly not as well perhaps. My white noise generator uses an NPN, so I haven't selected PNPs for noise before. (so no good recommendations really) I do find that the other Serge-favorite, the 5089 produces excellent white noise in an NPN based design.
modintx
Post by modintx »
Not at all - sorry if I wasn't clear on the DUSG vs Noise - my fault there. EDIT: to remove misunderstanding on 5089 - not a good fit for CGS97:-)
:guinness:
Jonachi
Post by Jonachi »
Will probably try CGS97 out this weekend. I'll let you know how it behaves.
Jonachi
Post by Jonachi »
nordlead wrote:I also finished the Noise, upper part (noise) looks good, the S&H section seems to require the "X" trace cut that Ken describes in the Setup part on his page. Haven't done that yet as I want to try out other transistors as noise source - maybe the different level changes the behavior of the S&H part. If the S&H is separated this way (and C connected to the S&H pad) my guess is that only tweaking the RPD resistor is necessary (without installing the 100K*), but this is just a guess.
Mine seems to work right away. Tried it out with my Eurorack and the s/h seems to work just as intended. The white noise was a tad bit lower than the doepfer noise module I compared it to but otherwise fine.
modintx
Post by modintx »
Excellent news Jonachi - thanks for sharing. I've got all but the 2 x SSG and 97 stuffed and test mounted on the rails. 1st SSG will get some love today...
modintx
Post by modintx »
Progress so far...waiting on some components (TL072's, J201s etc) so this is more test fit, stacking height etc to ensure will be able to get power each board etc. Have CGS97 to build and hook to one of the CGS92's.
This is my first Serge Panel build, learning a lot :tu:
Jonachi
Post by Jonachi »
Nice! Still some work to do though! Wireing of Serge panels is no joke! :hihi:
Great that there are so much room left behind the panel, much easier to wire that way.
