Weird effect running RackPlanner on Mac
Downloads, information and resources for the RackPlanner software.
Moderators: Kent, dougcl
jbi
Post by jbi » Tue Mar 08, 2011 10:52 am
I'm trying to run RackPlanner on a Mac with Java version 1.6. When it runs I get the following display:
Picture file
This uses the following rack.xml
<?xml version="1.0" encoding="ISO-8859-1"?>
<rack>
<properties>
<scale>1.0</scale>
<rows>4</rows>
<cols>1</cols>
<imagesPath>./images</imagesPath>
<modulesPath>./5U</modulesPath>
<rackImageFilename>5U.jpg</rackImageFilename>
<rackHP>32</rackHP>
</properties>
<modules>
<module>
<zipFilename>Bridechamber_M_Mult.zip</zipFilename>
<row>1</row>
<col>1</col>
</module>
</modules>
</rack>
Where the yellow line seems to be the module image. Any idea what's going on?
John
qu.one
hypnotic and sanctified
Post by qu.one » Tue Mar 08, 2011 11:16 am
check your module folder locations - if they are not where expected, they will come up blank. default there is a 5U folder inside the RackPlanner folder.
Qu.One Instagram
Qu.One Bandcamp
Qu.One on YouTube Music
dougcl
Number 6
Post by dougcl » Tue Mar 08, 2011 11:17 am
Please attach 5U.jpg and I'll look at it.
jbi
Post by jbi » Tue Mar 08, 2011 1:05 pm
5U.jpg generated using BananaPlug's Rack-O-Matic tool
dougcl
Number 6
Post by dougcl » Wed Mar 09, 2011 5:15 pm
Sorry for the delay. I forgot about this thread. The problem is your rack image is 1HP wide. Use an image editor to duplicate it out to 32 of those and that should fix it.
Not sure why the rack builder gave you that image. You might try again instead of doing it by hand.
BananaPlug
Post by BananaPlug » Sun Mar 13, 2011 9:08 pm
:doh: Oh right. Silly me. Perhaps I was thinking RackPlanner took care of the repetition. I'll should add row and column controls so you can download one as big as you need.
“We have to articulate ourselves. Otherwise we would be cows in the field” Werner Herzog :nana:
dougcl
Number 6
Post by dougcl » Sun Mar 13, 2011 9:16 pm
I could have based everything on a 1HP background image. That would make a lot more sense, actually. Ugh.
Return to “RackPlanner”
