Sorry, until now I didn't even know that such a sub forum exists. I mostly hang out at the eurocrack bar. Am I too dumb to forum, too?
Probably not. Which forum to post in is often a crapshoot and, IMHO, you did just fine.
I was trying to articulate something like this but couldn't quite put my finger on it. There's a lot more you can do with reverb than place a sound in space. Mind you, I way always the kid who re-purposed those conical lego trees for other weird roles in any construct, too.narxistdan wrote: ↑Tue May 23, 2023 11:18 pm It's really hard to give useful advice about this kind of thing on this forum because people here make all kinds of weird (often awesome) music where typical guidelines don't apply. This comment is based on my experience with relatively conventional music that isn't typically using reverb as a "pay attention to me" effect a-la-80's-ballads but as a tool to create depth in a mix...
This reminds me of an idea: using CV to control reverb like a sustain pedal on a piano. So every section where the harmony changes or you want a “pedal up” you make the size and/or decay time small. Then when you want reverb use CV to make those values large again. Clocked probably would work best or trigger it off note gates.sleestack808 wrote: ↑Thu May 25, 2023 5:31 pm I’ll paste something from a Daniel Lanois interview that I found interesting.
It’s about chords not clashing. You could do this with a looper pedal. Or daw
“In recent times, I've taken an interest in not having long sustains carry through chords: if I've got a stretch of ascending notes, I'll queue up the machine right on the note of the resolve so one note will not bump into the other. I'll play a note and print that, then I'll print the next note separately, and then the next note separately…
It keeps passages more kinetic note-to-note as opposed to being a total wash.
Exactly, you get this overall effect where there's no smearing or bleeding. It's like the opposite of the Taj Mahal.”
wolfelli wrote: ↑Thu May 25, 2023 5:46 pmThis reminds me of an idea: using CV to control reverb like a sustain pedal on a piano. So every section where the harmony changes or you want a “pedal up” you make the size and/or decay time small. Then when you want reverb use CV to make those values large again. Clocked probably would work best or trigger it off note gates.sleestack808 wrote: ↑Thu May 25, 2023 5:31 pm I’ll paste something from a Daniel Lanois interview that I found interesting.
Thoughts on this approach?
Changing decay should be OK, but changing reverb size causes all delay lines to shift, resulting in a pitch shift that is also reverberated. There may be algorithms, adapted from similar ones in delay effects, that cancel the pitch shifts, but I don't know of any available.wolfelli wrote: ↑Thu May 25, 2023 5:46 pmThis reminds me of an idea: using CV to control reverb like a sustain pedal on a piano. So every section where the harmony changes or you want a “pedal up” you make the size and/or decay time small. Then when you want reverb use CV to make those values large again. Clocked probably would work best or trigger it off note gates.sleestack808 wrote: ↑Thu May 25, 2023 5:31 pm I’ll paste something from a Daniel Lanois interview that I found interesting.
Thanks for the tip! I hadn’t thought about how changing the size abruptly would change the pitchgrayghost wrote: ↑Thu Jun 01, 2023 3:01 pmChanging decay should be OK, but changing reverb size causes all delay lines to shift, resulting in a pitch shift that is also reverberated. There may be algorithms, adapted from similar ones in delay effects, that cancel the pitch shifts, but I don't know of any available.wolfelli wrote: ↑Thu May 25, 2023 5:46 pmThis reminds me of an idea: using CV to control reverb like a sustain pedal on a piano. So every section where the harmony changes or you want a “pedal up” you make the size and/or decay time small. Then when you want reverb use CV to make those values large again. Clocked probably would work best or trigger it off note gates.sleestack808 wrote: ↑Thu May 25, 2023 5:31 pm I’ll paste something from a Daniel Lanois interview that I found interesting.
To simulate change in size, especially alternation between a finite number of preset sizes: have several different reverbs and crossfade their outputs -- alternately for smoother transition, a single source panned between the reverbs with a simple mix of outputs.
I like (mostly) dry demos too, unless I’m looking at an effect, but I also like demos that show practical uses. Just about every video I’ve seen with NLC in it is mostly just hosing cv all over the place, which I find far less useful than hearing a little reverb in a demo. I often find it difficult to discern how I might use it in a normal use case.skinpop wrote: ↑Thu Jun 01, 2023 11:44 am Here's how I balance reverb:
Start with full reverb volume, then slowly turn down the reverb until I don't notice it anymore. Stop playback and write down the value.
Next start with zero volume then slowly turn up until I just about notice it. Write down the value then pick one between the two. I find this is just enough for the sound to move out of literally being right in my ear.
I don't like when reverb is prominent in a mix unless it's used to do some weird and deliberate effect. Thank god for NLC and their dry demoes.
Oh goodness, yes. I hardly ever use my spring reverb for actual reverb effects, more for weird swelling howls of feedback and the like. It's delightful when you just edge it so it's on the verge of breaking up into feedback too.mrbloor wrote: ↑Fri May 26, 2023 6:52 pm I was a bit obsessed with reverbs, pretty much had a ton & moved them on. I've settled on a spring with the modular, I love spring reverb & I love feedback so it's very much a creative effect but agree just for a reverb effect I tend to have it barely on & choose a few percussive voices to put through it.
The venerable Knas Ekdahl Moisturizer is of course a lovely standalone device for this. Karl is a great guy and local (to me) in the Greatest City in America, no less.Kattefjaes wrote: ↑Fri Jun 02, 2023 6:11 pmOh goodness, yes. I hardly ever use my spring reverb for actual reverb effects, more for weird swelling howls of feedback and the like. It's delightful when you just edge it so it's on the verge of breaking up into feedback too.mrbloor wrote: ↑Fri May 26, 2023 6:52 pm I was a bit obsessed with reverbs, pretty much had a ton & moved them on. I've settled on a spring with the modular, I love spring reverb & I love feedback so it's very much a creative effect but agree just for a reverb effect I tend to have it barely on & choose a few percussive voices to put through it.
I do a lot of feedback, kinda question the need for an oscillator, I usually patch the feedback through a bandpass filter so I can tune it. It does sound glorious and it's always there as an option during a performance if I feel the need to go there (which I usually do).Kattefjaes wrote: ↑Fri Jun 02, 2023 6:11 pm Oh goodness, yes. I hardly ever use my spring reverb for actual reverb effects, more for weird swelling howls of feedback and the like. It's delightful when you just edge it so it's on the verge of breaking up into feedback too.
Oh yes a beauty, for table setups and single instruments it's the best but when I ditched all that & went 3u modular it seemed daft to keep it so I sold it to a chap who had Karl's other masterpiece The Polygamist.leftbracket wrote: ↑Fri Jun 02, 2023 6:41 pm The venerable Knas Ekdahl Moisturizer is of course a lovely standalone device for this. Karl is a great guy and local (to me) in the Greatest City in America, no less.
Great post, Keltie, thanks.
Yes! It's very much a sound source itself, often the input is more of an impulse to provoke it as a resonator.mrbloor wrote: ↑Sat Jun 03, 2023 2:14 am I do a lot of feedback, kinda question the need for an oscillator, I usually patch the feedback through a bandpass filter so I can tune it. It does sound glorious and it's always there as an option during a performance if I feel the need to go there (which I usually do).
I entered a public Men's Room once in a hotel, there were three dudes in there actually recording a guitar solo. Battery powered Pignose amp, mic/preamp and some other stuff. I was politely escorted out by the largest male human I believe was ever born, and he explained they were using the large multi-stall "rest room" to capture the natural room 'verb. Not the weirdest thing I've seen going on in a public restroom, but it's right up there.mrbloor wrote: ↑Fri May 26, 2023 6:52 pm I was a bit obsessed with reverbs, pretty much had a ton & moved them on. I've settled on a spring with the modular, I love spring reverb & I love feedback so it's very much a creative effect but agree just for a reverb effect I tend to have it barely on & choose a few percussive voices to put through it.
A few years back my setup was totally different & my favourite reverb technique can be heard in the percussion on this track.
I keep meaning to revisit the technique, basically I played the percussion track through a set of bone transducers attached to an old zither & recorded the sound inside the zither. I've experimented with other instruments, cupboards, shower cubicles & very resonant rooms using a variety of transducers attached to objects & also speakers just playing in the space.
Of course this is nothing new but I do like the sound of a physical space, however large or small.
Now I wan't a Leslie.Rex Coil 7 wrote: ↑Sat Jun 03, 2023 8:01 am Gary Wright (sp?) used to set up the Leslies in bathrooms at various venues on tour.
interesting, this sounds super counter intuitive when i think of reverb dynamics and natural space but i have the feeling i'm gonna love the result, can't wait to trySynthBaron wrote: ↑Tue May 23, 2023 5:42 pm Sometimes I like putting a brickwall-style limiter before a reverb in the effects chain. It makes it sound "huger" while making you able to only have a tiny amount of it in a finished mix to have a very noticeable reverb sound. Interesting effect...
