crt tube tv goes ~ after a while…
Discussion of modular and standalone video generating/processing techniques and associated hardware.
Granny
Post by Granny »
does anyone have any idea why my crt tube tv goes blank?
it's still on and glowing but stops showing my picture after some time, when I treat it with some video synths
when this happens I turn it off, wait a while, and it works again. but only for a short time
can it be that the signal is too overwhelming for the tv?
or might the problem be the tv only? maybe overheating?
does anyone with a little more experience with glitching analog tvs had similar things happen to them?
cheers
Agawell
Re: crt tube tv goes ~ after a while…
Post by Agawell »
I'm not an expert on crts, but I suspect it's got nothing to do with the signal...
but it couldn't hurt to test it with a vcr or dvd and a 'normal' signal...
probably something needs replacing - if you're going to take a look inside make sure you watch some videos on how to first - you need to discharge the stored electricity 1st otherwise it is dangerous - as in potentially deadly, iirc
sound sources < sound modifiers < modulation sources < utilities
Granny
Post by Granny »
Agawell wrote: Sat Mar 18, 2023 11:27 am I'm not an expert on crts, but I suspect it's got nothing to do with the signal...
thanks! yeah I`ll be careful, I modified a vectrex before
Return to “Video Synthesis”
