Are there any recommended clock dividers that might go well with the Oakley clock - the Sample/Slew module?
I don't mind having to build it myself in either eurorack or MOTM form factor. Or should I just get a Doepfer divider?
Thanks.
Clock divider to pair with Oakley clock
Re: Clock divider to pair with Oakley clock
I'm happy with the motm 5u Yusynth clock divider in my 5U rack . I was not looking for digital precision it being an analog diy build. It has three outs you can switch manually. No vc changing of divisions. Has LEDs if you want them. From memory it has 0.1pct resistors for precision. One clk in can drive three outs.
Eurorack I originally built the 4ms rotating clock divider and multiplier kits ...teensy driven. Never got the rotating bit working on one. Even more LEDs .
Later I invested in Pamela's workout ..the ultimate in clocks x 8 .. lots of precision and div and mult .and the ,4ms relegated to occasional use.
rgds Pav
I'm going to poke around and try out the Yusynth clock divider.
