Application UTune / arpeggiator and switch
Llouwelyn
Post by Llouwelyn »
Hello,
This Application is possible?,
I want to send CV out via Midi out of my Keyboard of the Utune in Sequential switch and CV out of the Sequential switch return in to the Utune for Trigg and pitch my Synth P5.
This application is good for select each notes of the Arpegiator in the sequantial switch with different clock of each.
Thanks for your helps!
Oups! LFO clock÷ 3 into Midi in.
Re: Application UTune / arpeggiator and switch
Post by tubbutec »
yes, you can route DIN midi in to µTune CV out, and CV-in to DIN midi out.
All you need you can find in the Midi in and out settings and in channel config.
if you want to trigger midi out for each midi in event, you need to configure gate out as 'midi gate' and connect it to gate in.
If you want to use a different clock ( the /3 ?) you can connect it to gate in instead.
Llouwelyn
Post by Llouwelyn »
Thanks you, this is possible to configure in channel 1 only or combinaison two channel requiert ?
Post by tubbutec »
One Channel is sufficient
Llouwelyn
Post by Llouwelyn »
Merci
runmiles
Post by runmiles »
Thanks for this information!
