I received my PSU boards today - along with the three pin power socket used with the Yamaha power adapters. I'm realizing that I don't know the strategy for wiring the power socket and power switch. Attached is a photo. Are these just simple solder-and-heat-shrink jobs? For example, do I just put the power wires into the three pin socket, solder the wire to the socket, and then insulate with heat shrink tubing? Or is there a more appropriate or better way to do this?
I have the same question for the power switch, but this will depend on what switch I end up using - it might be more like wiring a mono socket.
Thanks.
Update:
I should mention that I'm using the three pin power socket available from Oakley.
Strategy for wiring three pin power socket and switch for PSUs
- Synthbuilder
Re: Strategy for wiring three pin power socket and switch for PSUs
Yes. I normally tin the bared ends of the wires. Then fill the solder buckets on the socket with a bit of solder. Then re-apply heat to the solder bucket and slide the wire into place. Remove heat and that one is done.waldenpotato wrote: ↑Tue Mar 02, 2021 6:35 pmFor example, do I just put the power wires into the three pin socket, solder the wire to the socket, and then insulate with heat shrink tubing?
Heat shrink can be applied to act as a strain relief.
This is a great strategy, thanks.Synthbuilder wrote: ↑Wed Mar 03, 2021 3:18 am Yes. I normally tin the bared ends of the wires. Then fill the solder buckets on the socket with a bit of solder. Then re-apply heat to the solder bucket and slide the wire into place. Remove heat and that one is done.
What about the power switch? From the part number in your parts guide I've found this:
https://www.newark.com/multicomp/r13-24 ... a-02-bb-3a
The product information states that the connectors are "quick connect", which is what the spades on the various power pcbs connect to or with. But I can't tell what size quick connect spades these switches have - the data sheet doesn't specify. Can I assume they would be the same as the spades used on the power boards?
Or I could solder directly to the switch, but I'd like to use the proper connector if it isn't a hassle.
- Synthbuilder
Probably not. I would think they would be the smaller middle sized (4.8mm) spades. You can solder these sorts of tabs but you can melt the plastic if you're not fast enough.waldenpotato wrote: ↑Wed Mar 03, 2021 8:03 amCan I assume they would be the same as the spades used on the power boards?
I will try this smaller size. Thanks.Synthbuilder wrote: ↑Wed Mar 03, 2021 9:24 am I would think they would be the smaller middle sized (4.8mm) spades.
