DigiKey Caps
oozitron
solder fume huffer
DigiKey Caps
Post by oozitron »
Building my ADR30, and there was one mistake (not my mistake!) in my parts order:
Oops...
I have a couple 50volt 47p NPO Xicon Ceramic Disc caps in my old parts stash. Would these be OK to use in the ADR30 (for C54 & C57) ?
Or do I really need to get the C0G caps? (hopefully they would send them to me for free)
Andrew
Never want to come down, never want to put my feet back down on the ground
Re: DigiKey Caps
oozitron wrote: Sat Feb 06, 2021 10:39 pmI have a couple 50volt 47p NPO Xicon Ceramic Disc caps in my old parts stash. Would these be OK to use in the ADR30 (for C54 & C57) ?
Yes. NP0 is the same as C0G. Just different codes for the same product. You'll see on the Digikey label that the caps are described as C0G/NP0.
Your biggest challenge will be find a project for those 6 way surface mount switches. ;)
oozitron
solder fume huffer
Re: DigiKey Caps
Post by oozitron »
Synthbuilder wrote: Sun Feb 07, 2021 4:44 am Your biggest challenge will be find a project for those 6 way surface mount switches. ;)
Sounds like a challenge for the Oakley Creative Design Team :sb:
Maybe some kind of tiny keyboard controller for slow-moving ambient melodies?
thanks again,
Andrew
