Alternatives to MI Branches?
- Zijnzijn Zijnzijn!
On the hunt for another controllable coin flip module aside from Branches, preferably a little bit smaller. Anything comparable out there?
- smithjohn
Ladik has the Dual probability skipper which should be in the ballpark and 4HP:
http://ladik.ladik.eu/?page_id=1649
- selfdestroyer
You can get a O_C with Hemisphere Suite and use duel "Brancher" if you want.
My DIY / Music Blog They Remain Silent
- gentle_attack
Modulation (or Random) into a sequential switch that has CV control.
Control Skiff ||Big Case || cv.ocd || TT303v2 || Manther || OP-1 OP-Lab|| Octatrack Digitone RYTM || BX-8 BX-16 || Monologue KP3+
The only problem with Marbles is, that it needs a steady clock. If you want it to make decisions at a constant rate, it will work, otherwise Marbles will get confused and not behave as wanted.mmpingo wrote:The random gate generator (left "t" section) in Marbles.
my rack: https://www.modulargrid.net/e/racks/view/487293
soundcloud: https://soundcloud.com/user-134176900
- smallstonefan
Can you elaborate on this? I have Marbles and my understanding is you can feed it a clock or use it's internal...?jbrandtp wrote:The only problem with Marbles is, that it needs a steady clock. If you want it to make decisions at a constant rate, it will work, otherwise Marbles will get confused and not behave as wanted.mmpingo wrote:The random gate generator (left "t" section) in Marbles.
Branches generates an output every time it gets a trigger in the input. It does not have to be at a constant rate.smallstonefan wrote:Can you elaborate on this? I have Marbles and my understanding is you can feed it a clock or use it's internal...?jbrandtp wrote:The only problem with Marbles is, that it needs a steady clock. If you want it to make decisions at a constant rate, it will work, otherwise Marbles will get confused and not behave as wanted.mmpingo wrote:The random gate generator (left "t" section) in Marbles.
Marbles t-section starts calculating a tempo every time it gets a trigger. It needs this tempo to generate clock multiplications (and jitter time). Marbles will therefore not behave as expected, if you only want to send occasionally triggers (or a rhythmic pattern) to get a value.
If you need new values at a constant rate, you can use Marbles (as well as Branches).
Hope this helps?
- smallstonefan
