BANK
Support and discussion for Antumbra modules and DIY builds
Moderators: Kent, antumbra
henrry
Re: BANK
Post by henrry » Fri Apr 03, 2020 2:12 pm
I just built the BANK but it doesn't work.
The LEDs work fine but I actually mesure 9V DC on the Outputs...
Is there any shematic of this module available anywhere?
Cheers
henrry
Re: BANK
Post by henrry » Sat Apr 11, 2020 5:43 am
I had to do two repairs on this project:
1) For R86, as I lost the component or maybe forgot to buy it I DIYed a resistor in series who's value is 119.4k instead of 120k
2) C114 is directly soledered to the neighbouring pin as I destroyed the corresponding place of the PCB where it should have been soledered.
Does anybody see anything wrong?
The Gerber file and some help would be very welcome.
DMR
Re: BANK
Post by DMR » Sun Aug 23, 2020 10:33 am
Has anyone been able to get access to a schematic for the Bank? I know it is based on the YuSynth module, but it would be easier to debug problems if a proper schematic is available. I also have issues with the LED jacklights, which aren't present on the YuSynth module.
merlin
Re: BANK
Post by merlin » Fri Dec 11, 2020 10:05 am
Bank is based on another design detail of which can be found here.
Karl
Hazza26
Re: BANK
Post by Hazza26 » Wed Jul 14, 2021 11:37 am
I just bought one of these second hand and am also struggling with how low the output level is on this thing.
Listening to the mix output with input level at max, HP and LP fully open and bands set in the middle, the level drops 16dB through the high gain input and 33dB through the low gain input. If I crank my mixer to compensate the sound quality is a fair bit worse than the input signal. I assume the freq gain pots are set to +- from unity in the middle? I feel like it's pretty unusable as it is.
Any help much appreciated.
pjbulls
Re: BANK
Post by pjbulls » Thu Jul 29, 2021 2:33 am
No, the frequency pots only cut (apart from the little resonant peak the filters will introduce) as far as I know. The easiest way to increase the output level is probably to increase the gain on the output buffers, that's RN1, R85 and R86 in Yves' design (there's no schematic for BANK so can't tell exactly which ones correspond).
Return to “Antumbra”
