uTune Expander Plug-in detection issue
Moderators: Kent, tubbutec
ErnieBall
Post by ErnieBall » Sun Mar 22, 2020 12:00 pm
Hi, I have an unusual repsonse similar to the one described with one dual expander attached.
I have HW 18 and Firmware 1.98 loaded and reset to default settings
On channel three I get cv in reading but no output unless I gate/add voltage to the gate input as well
other three channels 1,2 and 4 all behave as expected.
Am I missing something or are you aware of this as a bug.
Many thanks
tubbutec
Re: uTune doesn't output Pitch.
Post by tubbutec » Sun Mar 22, 2020 2:50 pm
Can you set channel 3 gate input to 'none' in simple config and report your findings? thank you
ErnieBall
Post by ErnieBall » Sun Mar 22, 2020 3:47 pm
Hi Thanks for that - when gate in set to none on channel 3, cv in behaves like 1,2 and 4 now although they are set to Gate In - Gate
In other words - a voltage plugged in cv in is passed through to cv out without the need to gate the input
Hope that helps
tubbutec
Re: uTune Expander Plug-in detection issue
Post by tubbutec » Tue Mar 24, 2020 5:28 am
It looks like there might be an issue with plug-in detection of channel 3.
This might be caused by:
- You need to use a mono-cable. Otherwise plug-in detection does not work. Make sure you are using a mono, not stereo cable
- an actual hardware issue. We have prepared a firmware version that shows the state of the plug-in detection (soon to be a feature). please get in touch via mail and we'll send it to you for debugging.
thank you
Return to “Tubbutec”
