Unipulse can't respond to fast triggering with active sensing.
Post by Synthbuilder » Wed Feb 26, 2020 6:10 am
My new Unipulse Mk3 doesn't always respond when triggers are sent in quick succession. This is perhaps related to active sensing. On controllers that use active sensing the Unipulse only responds to triggering every second or so. Without active sensing, eg. my computer's midi interface, the unit appears to trigger correctly.
Re: Unipulse can't respond to fast triggering with active sensing.
Post by Synthbuilder » Wed Feb 26, 2020 6:11 am
Actually, just noticed this other thread which could be the same thing:
viewtopic.php?f=78&t=225723
Post by tubbutec » Thu Mar 12, 2020 8:30 am
Hi Synthbuilder thank you very much for this. Helps a lot and we will look into it right away. Indeed this could be the reason uniPulse does not work properly with an MPC.
