6equencer thread
6equencer thread
Post by tubbutec » Fri May 21, 2021 1:24 pm
Questions about 6equencer? Post them here :)
https://tubbutec.de/6equencer/
Tubbutec 6equencer is a TR-606 inspired step sequencer.
It is available in different Eurorack form factors (1U and 3U) and despite being compact has many powerful features.
6equencer is optimized for live performance and allows quick programming and editing of drum patterns.
  • Step based drum sequencer with 8 instruments inspired by the
 TR-606.
  • Compatible with analogue and midi based systems
  • 16 patterns, chainable in song mode, up to 32 patterns in a song
  • Forward, backward, ping-pong and random play directions for
 patterns and songs
  • Mute instruments live
  • Probability control of steps
  • Record steps by tapping or via midi
  • Clear steps while playing
  • Pattern length can be set individually (Last Step)
  • Copy, Paste and Clear patterns in song mode
  • 8 trigger outputs with adjustable trigger length, midi out
  • Analogue clock or midi clock input with adjustable clock divider
  • Multiple 6equencers can be chained to achieve longer
sequences or more instruments.
  • Trigger and record via midi in, doubles as midi interface
  • Trigger midi instruments via midi out
  • Very compact, yet versatile: 3U * 6HP, or 1U * 24HP Intellijel
  • For a detailed list and explanation of features, please refer to the user manual (PDF), which is also included with the 6equencer. There are a lot more features than listed here.
  • Firmware update is possible via midi sysex
KVK
Re: 6equencer thread
Post by KVK » Wed May 26, 2021 12:32 pm
Hiya, I couldn't see anything about ratchets in the manual so assuming it doesn't have any? Ta.
moo_lefty
Post by moo_lefty » Wed May 26, 2021 2:51 pm
Looks great.
What's the use for the link patchbay exactly? I know you can link multiple 6quencers with or without it - but what happens when you plug a cable into the patch bay?
Thanks
Post by tubbutec » Wed May 26, 2021 3:30 pm
The idea is that you can change the link between 6equencers on the fly:
If you plug in a cable, the 6equencers are disconnected work separately. Of course this can also be achieved by changing settings, but with the patchbay you can do that quickly and while the 6equencers are running. And of course you can also reconnect them using a cable.
If you have more then 2 6equencers you can use the patchbay to quickly change which are connected and in which order.
Patchbays also allow you to bridge larger distances between 6equencers by using an ordinary patch cable.
Guess I will make a short video showing the possibilities soon.
moo_lefty
Post by moo_lefty » Wed May 26, 2021 4:20 pm
Cool, thanks. I assume this is passive? What's the pinout? Could it also be used for DIY purposes?
Post by tubbutec » Thu May 27, 2021 1:32 am
Yes, it's passive. The Tubbutec LINK interface only uses ground and one signal wire, so normal mono patch cables can be used for connection. In the patchbay the connection is normalized. Using the link cables supplied with 6equencer and the patchbays it is possible to build a custom eurorack patchbay that can be used for all kinds of signals.
tito_tunes
Post by tito_tunes » Sat Sep 18, 2021 11:29 pm
Can this run on Sync 24 (DinSync)?
danielriera.bandcamp.com
Post by tubbutec » Sun Sep 19, 2021 12:09 am
There is an update ( tested and online soon) that introduces a din-sync clock in divider.
So: yes
jenamu6
Post by jenamu6 » Wed Sep 29, 2021 2:03 am
Can you have different amount of steps per track?
My music streaming:
My youtube modular music movies:
http://www.youtube.com/results?search_q ... type=&aq=f
Post by tubbutec » Wed Sep 29, 2021 12:18 pm
Sorry. But no.
Different number if steps for each pattern is included, but
A different number of steps per track would be too confusing given the minimalistic UI of 6equencer.
Also this has functional issues: when would you switch to the next pattern in a song?
My best solution: use multiple 6equencers.
jenamu6
Post by jenamu6 » Thu Sep 30, 2021 7:20 am
Thanks, I just wondered.
The steppy can do this, but that one only has 4 outs. 6equencer has 8 outputs, so I have to make a choice :)
My music streaming:
TransmissionTapes
Post by TransmissionTapes » Sat Oct 02, 2021 10:14 pm
would love this in black if that's a future option for the 1U
Post by tubbutec » Wed Oct 13, 2021 4:02 am
We were able to implement two commonly requested features:
- Swing
- Ratchet / Flam
Found a great implementation for Flam that works with the minimalistic UI we have, and is still very powerful with different modes triggers.
Even does quite a bit more than just the boring typical flam effect
A lot of fun playing with this!
Swing amount can be adjusted in 16 steps.
Needs some more testing to make sure it is stable, but found no bug so far :)
Demo video and firmware update coming soon .....
Post by tubbutec » Mon Oct 18, 2021 6:32 am
Ratchet is now included in firmware version 1.2 :party:
Post by tubbutec » Mon Oct 18, 2021 6:33 am
Yes, we added an analog clock divider in firmware version 1.2 which allows 6equencer to run from DIN-snyc directly.
KVK
Post by KVK » Mon Oct 18, 2021 6:37 pm
:yay:
honkfink
Post by honkfink » Tue Oct 19, 2021 7:45 pm
The firmware link for 1.2 doesn't work
honkfink
Post by honkfink » Tue Oct 19, 2021 7:58 pm
Also, what's the best way to send this file to the 6equencer as i only have access to a Mac at the moment, not Windows? (I can emulate Windows XP if needs be)
Post by tubbutec » Wed Oct 20, 2021 3:25 am
Fixed, thanks :)
Post by tubbutec » Wed Oct 20, 2021 3:26 am
If you can emulate, do that. We are looking at publishing a OSX version, too of course. Apple makes that quite difficult, when you don't own a mac ;)
honkfink
Post by honkfink » Wed Oct 20, 2021 4:51 am
The windows updater is not a valid windows 32 application is the error message I'm getting. That's the only Windows I have to run at the moment. I have access to Intel and M1 Macs. Is there any open source tool I could run or even run on emulated Linux?? Even iOS or Android would do.
