[New Module] nw2s::io Balanced line transceiver
Discussion, support, and resources for our noise making modules and kits.
Moderators: Kent, scottwilson
scottwilson
Re: [New Module] nw2s::io Balanced line transceiver
Post by scottwilson » Mon May 31, 2021 7:03 am
True... The tradeoff between the ES modules where the converter is in the eurorack and something like the 'io and/or 'o16 is that you would be using your Avid, Antelope, Apogee, Apollo, or whatever converters which will make a world of difference.
Portability will always have some compromises... You could always go with a smaller USB audio interface like the MOTU Ultralite and just watch your levels. That will be about as good as you're going to get IMO.
Scott
nw2s.net
Return to “nw2s”
