plumbutter patch sharing thread :D
home of post-70s electronics
Moderators: Kent, bartlebooth
mysticsusieq
1-Post Wiggler
Post by mysticsusieq » Sun Oct 21, 2018 11:46 pm
Hi! I'm a newbie here and this is my first post! :hyper: I got a Plumbutter a few months ago after I saw Hainbach's videos on YouTube and was so amazed that I decided to get one, too!
I have no previous experience with using patch cables and barely have an inkling of what I'm doing, but I really liked how this patch turned out. I didn't want to unplug anything for weeks because I liked it so much but I finally sat down and tried to make a record of it using one of the templates here (thanks!). This is all one patch but I needed to use three images to keep all of the wires from getting too confusing.
I hope others will find it fun and interesting!
Patch Part 1
Patch Part 1
Oct 2018 Patch Part 1.jpg (730.54 KiB) Viewed 674 times
Patch Part 2
Patch Part 2
Oct 2018 Patch Part 2.jpg (704.17 KiB) Viewed 673 times
Patch Part 3
Patch Part 3
Oct 2018 Patch Part 3.jpg (713.58 KiB) Viewed 674 times
rmro
Post by rmro » Thu Nov 08, 2018 4:21 am
I’ve been re-watching this video of PeterB with the Plumbutter and trying to generate the ultrasound noise that starts to be generated (around 11:10). I get similar sounds but not the feeling that it’s generating the noise like on the vid. More an accumulation of clicks, bleeding into each other.
I suspect I’m being too analytical but if there’s tips for generating this kind of sound using I’d be keen to hear.
jimmie
Post by jimmie » Thu Nov 08, 2018 5:15 pm
If you're after the 'noise' kind of sound you may get similar sound by connecting a 3 roll to ultrasound (try browns), and the roll needs to be modulated by other 4 (and 3) rollz somewhat complicated way. I get that kind of sound much easier with rolz5 whose rolls are not voltage controlled.
rmro
Post by rmro » Tue Nov 13, 2018 4:55 am
This is how I'm generating the noise as per previous posts.
The 4 is at slowest and the 3 is just enough to let the noise sound. I've found it a a good starting point for lots of interesting patches. e.g Creating a mirror on the other Rollz and getting more modulation
The noise can be drawn out longer going 3 Roll Orange out into 4 Roll Verso/Inverso (not sure which one but the Blue to slow the Roll down)
What I found from deep-diving on this is it's easy to patch too many things then it all becomes a rapid drill of pulses. In fact, it's what I've really grown to like about the PB, I requires space and balancing feedback to dig out the nuggets.
Also, if you have a Sidrax I’ve had interesting results patching the Orange outs into the PB Verso/Imverso rather than from the Rollz. Pressing the Barres gives a different playable effect
jimmie
Post by jimmie » Tue Nov 13, 2018 11:58 pm
Very nice patch :tu: :tu: Thanks for sharing.
By the way, I'm still after Plumbutter official page's example sound. Those are the sound made me to get a PB, bestest of PB for me. I can't get really the same sound no matter what. I think they were made by first version of PB and suppose that's the reason. I prefer PB2 formfactor, tho..
Lewis#
drone, bongo and ...
Post by Lewis# » Sun Nov 18, 2018 3:18 pm
... wanted to share the following patch which sounds cool when adding some delay: avdog contributing a constant tone, gongz a bongo-bass and ultrasound some vibes up to a very cool steamy sound (depending on turning the fm knob completely counterclock-wise) ... hope you like it:Image
jimmie
Post by jimmie » Thu Nov 22, 2018 9:01 am
It's so often the same patch doesn't yield the same result. It's not because of the subtle knob position; more likely the caps' condition etc. So to replicate something exactly, even chord patching order needs to be in mind, or even more is that sometimes plugged some jack and then umplugged it (to make some condition to the cap etc - my guess). That's where PB is very interesting and at the same time frustrating (hard reproducibility) and makes making truly working patch book so hard :ripbanana:
trax
Re:
Post by trax » Sun Oct 04, 2020 6:18 pm
mrbloor wrote:
Sat Jun 13, 2015 12:53 pm
welcome, just avoid yellow connected to brown & all will go swimmingly well :tu:
[/quote.]
Why? I do this all the time....
Curious to hear your reason....
trax
Re: Re:
Post by trax » Sun Oct 04, 2020 6:19 pm
[/quote.]
ST UF FLI N EAR
Re: plumbutter patch sharing thread :D
Post by ST UF FLI N EAR » Thu Jun 10, 2021 11:59 am
If there really was anything you can not patch together within the PB it would be mentioned by Peter in a note added to the Plumbutter when its shipped to a customer. Right?
Edit..
In the Plumbutter Quickstart thread somebody semi-quoted Peter
Peter designed all his instruments where anything can be plugged in anywhere. He mentioned it to me in an email awhile back. You can plug in the brown nodes anywhere. You can double stack inputs too. Literally go crazy! It’s one reason the pb remains at the top for endless patching possibilities.
0netwo0netwo
Post by 0netwo0netwo » Thu Jun 10, 2021 7:27 pm
this is "within" the ciat-lonbarde" world
some users have experienced some unfortunate events patching the brown nodes with modulars because of the voltage irregularities
some invest in gold, silver and stocks - I like to invest in synths and drum machines :sb:
https://0netwo0netwo.bandcamp.com/releases
https://soundcloud.com/0netwo0netwo
ST UF FLI N EAR
Post by ST UF FLI N EAR » Fri Jun 11, 2021 1:02 am
Yes, but i notice it gets twisted and some people are afraid to patch certain ways within PB or between PB/CQ for instance.
(I dont know, my first pb is on its way to my doorstep atm and i just assume Patchpoint provides some official words of authority if there would be some hazards.)
In- to output is stated in manual and no brown to outerworld.
baleen
Post by baleen » Fri Jun 11, 2021 9:15 am
they don't (or didn't).
i have kept brown rollz patched to CL only, no troubles. i am not gonna try patching brown out to anything else bc i uh like my stuff.
relevant to this thread, I'm still on the first page of this thread bc those patches are all great starting points. or at least as good as "let me spend some time figuring out what to do with AVDogs" which turns into an ultrasound/rollz workout.
Return to “Ciat-Lonbarde”
