Mapping Mutant Brain CV output values
Discussion for Hexinverter eurorack modules - email Hex if you need anything urgent!
Moderators: Kent, hexinverter
Morog Far
Post by Morog Far » Thu Feb 25, 2021 1:55 am
I need some help regarding the CV Outputs. I want to have the CV outputs mapped to channels 9 through 12 and get the note pitch value that is triggered on my Digitakt. From what I understood I have to enable those four channels as note inputs and then also select them in the outputs section. I don't receive a CV output signal, though, while the triggers work fine. Can anybody see what I'm missing here?
EDIT: My bad, somehow the max values were set to 1 by default, just had to up them.
Return to “Hexinverter Electronique”
