Field Kit : How are you using it?
Discussion and support for KOMA Elektronik effects pedals, eurorack gear and all the other stuff we do...
Moderators: Kent, osterchrisi
RGB
Post by RGB » Thu Jun 15, 2017 12:52 pm
I just got the email that my field kit is on the way! I am excited about the potential, how are you using yours?
RGB
Post by RGB » Fri Jun 30, 2017 1:21 pm
Wondering if anyone can offer some advice on using the signal interface. I have been looking forward to using different types of sensors, switches, etc, but really have no experience with these things. I have been looking at adafruit with excitement and thinking of the possibilities. I am noticing that a bunch of these sensors only have two pins where the field kit has a three pin input. I am guessing that there is no ground on the sensors with two pins? Is the ground necessary?Any advice would be greatly appreciated in attempting to understand and explore these types of devices. Thanks in advance!!
1n
Post by 1n » Thu Jul 27, 2017 6:22 am
BUMP
Me too...
1n
Post by 1n » Thu Jul 27, 2017 6:26 am
Mainly using it for mixing, aux/sends, modulation of Eurorack/0-Coast.
I've a couple of DC projects awaiting time. I'll post when I have them sorted.
Pumpkin
Post by Pumpkin » Mon Aug 21, 2017 5:42 pm
I'm sitting in some electronics, what's your problem?
Torn n Frayed
Post by Torn n Frayed » Mon Aug 21, 2017 5:46 pm
RGB wrote:Wondering if anyone can offer some advice on using the signal interface. I have been looking forward to using different types of sensors, switches, etc, but really have no experience with these things. I have been looking at adafruit with excitement and thinking of the possibilities. I am noticing that a bunch of these sensors only have two pins where the field kit has a three pin input. I am guessing that there is no ground on the sensors with two pins? Is the ground necessary?Any advice would be greatly appreciated in attempting to understand and explore these types of devices. Thanks in advance!!
Great video on using a spider-web coil w/the Field Kit;
captjrab
Post by captjrab » Wed Dec 13, 2017 1:49 am
I rigged up the motor with a Tempi trigger pattern and nestled it between a string and bridge then applied a contact pickup which I nestled over it with two other strings. Cool acoustic sounding percussion. Good nestling fun.
captjrab
Post by captjrab » Wed Jan 24, 2018 12:20 am
Some Field Kit Breakout ideas
Leslie Speaker
Magnetic Gate Source and UFO Lamp
Solenoid Rings Activator w/Microphonie
Peace Fountain w/Clouds
Zerstorte Zelle
Post by Zerstorte Zelle » Wed Jan 24, 2018 7:49 am
Just picked one of these up. Great fun. Had a motor tuned in key with a guitarist at a jam the other night. Pretty fantastic to pull in “non musical” elements into the modular stuff I’m normally working on.
lisa
Post by lisa » Wed Jan 24, 2018 7:57 am
Most people I know of who got a kit aren't using it at all. :despair:
I guess it might be a bit hard to incorporate something so different into a normal modular workflow on more than a novel level.
Eurorack, Una Corda and cello. 🎛️🎹🎻
Goin_noW
Post by Goin_noW » Tue Jan 30, 2018 8:47 am
This is great! 8-)
captjrab
Post by captjrab » Fri Feb 02, 2018 1:02 pm
lisa wrote:Most people I know of who got a kit aren't using it at all. :despair:
Hopefully the FK and Bastl stuff catches on more in time. It could spark a whole new diy ethos in modular.
That said,
A couple more FK “patches”. Just the basics so far. Needs some modular mashing still:
Magnetic Sensor paired with woggle motor to cv shortwave static
DC Submersible pump for gurglie drips and garggles:
captjrab
Post by captjrab » Fri Feb 16, 2018 1:02 pm
I’m not getting the data input for the Switch function of the FK. What is it looking for?
I have a computer fan which I can control with a footswitch. It works great. I plug the yellow data cable of the fan into the switch header and....nothing. Then I plug the same yellow cable into the sensor data in and it works beaurifully. Im tryng to maximize all parts of the fk but have hit the wall with that lovely looking switch EG.
Anyone using the switch EG?
noisejockey
Post by noisejockey » Sat Sep 22, 2018 10:28 am
Here's a piece using the Field Kit, driven by a Varigate 4+, mostly effecting a broken crash cymbal for percussion. Ciat Lonbarde Tetrax Organ provides the melody.
https://soundcloud.com/noisejockey/tarnished-ritual
oneticketroundtrip
Post by oneticketroundtrip » Mon Apr 08, 2019 6:07 pm
the output fried for some reason and i havent used it since
:deadbanana:
Tonaldefiance
Re: Field Kit : How are you using it?
Post by Tonaldefiance » Mon Nov 02, 2020 11:54 am
Can you trigger the am / fm radio so that it lands on a new frequency with volts per octave?
Zerstorte Zelle
Post by Zerstorte Zelle » Sun Apr 18, 2021 7:15 am
Please excuse potential self promotion but thought it appropriate to link to a release from last year made nearly exclusively with the Koma Field Kit. All performances are live takes with no overdubs.
Sweetfiltersweep
Post by Sweetfiltersweep » Mon May 24, 2021 10:26 am
Basic but effective use:
joeyfivecents
Post by joeyfivecents » Sat Jul 24, 2021 9:46 am
Solenoid banging on an old tin cup (actually an equestrian trophy) powered by the Koma Field Kit and modulated (speed and intensity) by its LFO. Every percussive sound is from the solenoid/cup affected by the delay buffer on the Koma Field Kit FX. The cup is mic'ed with a small contact microphone and sent to the Field Kit FX from the Field Kit AUX in the mixer. The delay time is being modulated by the CV sequencer from the Field Kit FX and the really noisy parts are the result of turning the delay feedback all the way up. The sort of melodic parts are the result of sequencing the delay time with cv. Polyend Tracker is monitoring it all in case I want to sample and it's also adding reverb and a little bit of extra delay. I don't expect most people to sit through 10 minutes of noise but if you have the patience, there are some nice little moments in here. If you're into noise, this one's for you. I feel pretty good about it.
Octatrack, Polyend Tracker, Digitone, OP-Z, OP-1, Zoia, Live Suite, Logic, Reason, Melodyne Studio, 67 Jaguar, Deluxe Reverb, Marshall Class 5, pedalboard, pedals, mics, harmonicas, Little Martin, ukulele, banjo, FL Studio, Max, and other stuff.
Return to “KOMA Elektronik”
