Same here! Fingers crossed!
. thanks for the heads up. we'll take a look at that.scragz wrote: ↑Tue Sep 06, 2022 2:48 pm website not loading so I'm posting my bug report here:
if you have clips in a performance and that performance is loaded on startup, it is not loading the clips in the performance, only the ones in the root. if nothing is in the root, it loads the default 4 clips. I have to select another performance and back, or load the wrong one by default and then select the one I want, to get the performance's clips to load.
this has been in the last couple firmwares since I started using structure, currently on 4.1
FWIW: While that should work, I've re-posted this excerpt from my "modularvideo: 2021 studio build" thread:TJontheRoad wrote: ↑Sat Sep 03, 2022 9:55 amOk thanks. Something like this?
Manufactured by a large multi-monitor display company, the Black Box scaler is the best HDMI-upscaler I've found.studio460 wrote: ↑Sat Oct 23, 2021 7:40 pm Update: Black Box 1080p60 scaler.
Just did some A-B comparisons between the [gofanco Prophecy and Black Box AVSC scalers]: Though the [gofanco Prophecy scaler's] composite-to-HDMI conversion is virtually noise-free (i.e., visibly cleaner than the Roland V-4EX' scaler), [the gofanco scaler] exhibits pronounced stair-stepping on native-16:9 480p24 DVCAM-ingested footage (shot with an 850-line horizontal-resoluton sensor, photographed at a 1/48th-shutter).
The Black Box AVSC scaler displays fewer artifacts with noticeably less stair-stepping. Though, neither box was capable of accepting the S-Video output of the DSR-11 via Y/C-cable (the Prophecy does not support Y/Pb/Pr or Y/C-inputs). If you don't need Y/Pb/Pr-output (which the Prophecy supports), the Black Box scaler is the better converter.
Black Box AVSC-VIDEO-HDMI 1080p60 scaler: $214.95.
This may be a silly question, but I don't know the answer. My projector accepts component and hdmi. I use the component out from my V-8 to the projector, would using an upscaler between my mixer and projector result in a better picture? Pretty sure my projector can do 1080.Manufactured by a large multi-monitor display company, the Black Box scaler is the best HDMI-upscaler I've found.
Starting to take a look at this, will likely make it into the 4.2 update in a couple weeks along with some other things!scragz wrote: ↑Tue Sep 06, 2022 2:48 pm if you have clips in a performance and that performance is loaded on startup, it is not loading the clips in the performance, only the ones in the root. if nothing is in the root, it loads the default 4 clips. I have to select another performance and back, or load the wrong one by default and then select the one I want, to get the performance's clips to load.
. i try to keep my eye on this group as well in case there are any questions or other Structure/video art discussions going on.BlastPast wrote: ↑Wed Sep 21, 2022 10:49 am I received mine from Perfect Circuit yesterday, I’m so excited to start learning, unfortunately I’ll be away for a few weeks and won’t get to dig in yet but I can’t wait!
Is there any other community for discussing and sharing Structure related things besides Facebook? I’ve been off of that platform for quite a while now and don’t really want to go back lol. But it seems there are some communities that are mostly focused on there so I might have to make a new account and give in eventually. Maybe a discord or something?
. hello! i'm James - half of the Erogenous Tones video team that makes Structure.11ish wrote: ↑Wed Jan 11, 2023 1:14 pm I've been looking at modular video synthesis (which is a new field of exploration for me) for the last 1 or 2 weeks, checked what is available at the moment, and now I'm torn between the Structure and the Sleepy Circuits Hypno. Although the Structure all in all looks more inviting with the screen and the whole user interface, I must admit that there are some youtube and vimeo clips from the Hypno that impress me more than anything I have seen from the Structure. So may I ask you Structure-users, can the Structure do something like this?
[snip]
… Any thoughts?
Something else to think about is that if you went with Structure. Say you are blown away with video synthesis and want to go deeper down the hole. I think it is going to be a little more inviting to expand into a bigger video modular system. Not to say Hypno will not fit within a video rig, but Structure to me feels like it has a bit more growth potential if you decide to expand. The LZX TBC2 just started shipping and is going to open up some fun times with structure and a 1v system!
Extra thanks for that link! I hadn't seen the site with all the shaders before, very helpful. I'm checking them out now …anomad wrote: ↑Wed Jan 11, 2023 2:19 pm …
Structure ships with all of these shaders (and effects) - http://glsl.erogenous-tones.com/ here you can make modifications to the shaders and copy them to the front SD card of Structure and use your own shaders or effects (w/the caveat that the shaders must be GLES 2.0 compatible, must not ray trace, or have excessive for loops) - but you only to worry about that if you want to make your own shaders.
. no, Structure only outputs NTSC or PAL video format. the website renders on your local GPU, so it may be faster/higher resolution that Structure can produce.11ish wrote: ↑Wed Jan 11, 2023 2:58 pmExtra thanks for that link! I hadn't seen the site with all the shaders before, very helpful. I'm checking them out now …anomad wrote: ↑Wed Jan 11, 2023 2:19 pm …
edit:
If you click on one individual shader from that collection … Is that the same resolution I will get from the Structure? That would be crisp enough for me.
. i love running VHS through Structure using it as a video FX unit - this is an Aeon Flux tape in to Structure and i was randomly changing generators and effects as well as how they were mixed -
So all the shaders on all 37 pages of the gallery are already available in the Structure module?anomad wrote: ↑Wed Jan 11, 2023 2:19 pmStructure ships with all of these shaders (and effects) - http://glsl.erogenous-tones.com/
