. correct in that 9 o'clock is the mid-point. Per Rick's comment on the Structure Fb group:Ras Thavas wrote: ↑Fri Jun 18, 2021 12:51 pm I believe this was discussed elsewhere, but going from memory, ER had an existing supply of pots they had to use for Structure and due to their size/configuration the only way they could fit behind the panels was to be tilted off axis.
I'm fairly new to Structure and this offset is still mildly frustrating to me at times, but I'm sure I'll get used to it.
"at the time the limitation here was the knobs, as typically you can order knobs with a rotation to match the orientation, but for these knobs, if I wanted that, I had to order 10,000 of them and this was the beginning of ET so I didn't have that kind of capital. I had to order what they offered.
These knobs are superior to any other small format knobs I had found, and I had probably 20-30 different small knobs I was testing. so, I decided to do something a little different to account for the packed space.
The way they seem normal to me is I just think of things in terms of 9 o'clock. This is more important on LEVIT8 which was my first module that shipped. At 9 o'clock the gain is 1:1 "
. if you look @ some of the other modules ET makes another concern was getting eight knobs to fit in standard eurorack height.
-james
