Marble Physics - Tilt knobs
Moderators: Kent, __ag
Mercutio
Post by Mercutio » Mon Jun 25, 2012 3:26 am
i bought the last one available from the first batch.
It looks amazing but it's more complex than i tought. :doh:
I don't understand all the konbs :hmm: . Are they attenuateur (0 counter clokwise, dull clockwise) in the both mode (unuipolar/bipolar) or it's polarized ?
What's the function of the X/Y knobs ? i tyhinked it reduce the range but the 4walls looks to be fix (very high and very low , if i put signal on a pitch ...more than 10-12 octave)
__ag
Post by __ag » Mon Jun 25, 2012 5:28 am
Hello!
i can understand that at first sight it looks stange but it has a very simple working method once you get used to it.
so some overall assumptions:
All knobs are manual controls when no CV is in
If CV is in than they all act as attenuators (left = 0, right = full CV)
uni and bipolar defines which CV input you're using, if a unipolar or bipolar one, all 0+5V or -5+5V
tip: if you're using a pot as a manual control (no CV) the switch should be in unipolar for the full knob range, if the switch is set to bipolar you're only using the top half of the knob range, the knob by itself is always unipolar, so you'll never reach the bottom half dedicated to the negative voltages.
moving on, X & Y TILT Functions
X & Y are Tilt functions, these are the ones tilting the "marble tray", defining the tilt angle of the "tray".
you don't change the wall size.
Next, the outputs can be both uni or bipolar between 0+5V or -5+5V respectively.
so yes if you set it to bipolar and use it for a pitch you'll get 10 octaves or more depending on the VCO calibration quality...
hope this helps!
all the very best
andre
Mercutio
Post by Mercutio » Mon Jun 25, 2012 6:48 am
Thanks André, it helps me a lot.
i still have one question.
TILT : ... you talk about the angle...i think it was to " impulse the ball" so it's not a trig i have to put in but well a kind of offset (= Knob) or LFO or Eg ... ?
I don't have an oscilloscope with X/Y... do you know one which is compatible audio unit ?
PS: the red color is really beautiful !
__ag
Post by __ag » Mon Jun 25, 2012 7:29 am
Hello,
The X & Y Tilt defines the inclination angle in both X and Y vectors, where 0 is No Inclination or angle, this can be set by centering the Pot to mid point.
Also if knob is rotated to Left ball will slide to x =0V, if rotated right ball will slide to xMax or x = +5V
same for Y tilt.
the "impulse the ball" function is the BUMP function, here you can set the Strength to "impulse the ball". And then trigger the function with either the Gate input or the push-switch.
about last question, do you mean one oscilloscope that is compatible with voltages and audio? i think most are, i know our ADDAC205 is:
http://addacsystem.com/product/addac200 ... oscope-awg
all the very best
andre
Entrainer
Post by Entrainer » Mon Jun 25, 2012 7:16 pm
Oi, we are half way to a manual!
Just got this installed last night and went through
a late night test. (nice work BTW on this and the 601).
What voltage does the lock/gate input react to and
with what results?
The elasticity is kind of a curvature, right? Like
gravity towards a wall?
What is a good starting point for a long evolving, lasting
run of modulation?
THX-
5,159 custom drum samples for electronic music
made from 4 modular systems, drum modules, and some nice analog outboard processing
202 Instruments for Ableton Live/Push (128s), NI Kontakt, and Logic EXS24
41 Kits for NI Maschine, FXPansion Geist, Ableton Drum Racks, and Octatrack Sample Chains
http://www.drivenmachinedrums.com
mDang
Post by mDang » Tue Jun 26, 2012 2:06 am
We need more videos about this crazy module.... ;)
Analogeeks
HueMonContact
VoltageCtrlR
Post by HueMonContact » Tue Jun 26, 2012 2:16 am
This is getting interesting... :popcorn:
this module has some really sweet functions!
Sound:
http://soundcloud.com/voltagectrlr
http://voltagectrlr.bandcamp.com
Game of Life Label Release: Inner Siddhi Portal
http://gameoflife.bandcamp.com/album/vo ... dhi-portal
Blog:
http://shirovoltagectrlr.tumblr.com/
http://groundloup.wordpress.com/
Video:
http://vimeo.com/voltagectrlr
______________________________________
HueMonContact...
Hue=Color, Mon=Man/Monster, Contact=Touch.
Mercutio
Post by Mercutio » Tue Jun 26, 2012 4:22 am
I really enjoyed the module last night with the explanation... not easy to understand but a lot of good results yesterday.
I like the gate button !
I like the bump out.... a kind of burst genrator...with fast EG (Cwejman) = :guinness:
I like the direction ray and the strenght/speed/elastcicity...
Thought, pratically, the relation between these three...are :bang:
A manual will be grateful !
i think it's my crasiest module with phonogene, rené and geiger
__ag
Post by __ag » Tue Jun 26, 2012 5:55 am
Hello!
Great to hear that i helped!
and yes, it's a tricky module to control, like in real-life if you have a real marble on a tray... But it's exactly that combination that can generate endless modulations...
My favorite configuration is something like this:
1.connect already modulated lfos, like the Lissajous Curves outputs to the X & Y tilts CV ins
2.connect an attenuated and offset cv (something between +4 to +5v) to the elasticity
3. connect an attenuated cv (something between 0 +1v) to the speed cv, i prefer very very slow speeds with small spikes here and there...
4. connect a random gate at very slow speeds to the bump gate input
and let it run endlessly...
going through some other questions:
the elasticity is easier to explain if you think of it like being the wall elasticity or the wall material, changing from concrete to a trampoline wall.
and i forgot to mention the X LOCK feature before,
this locks the X position, meaning that the X CV Out freezes in that voltage. Once the gate goes down it starts moving again.
And all gates activate at +2.5v.
All the very best
Andre
Entrainer
Post by Entrainer » Tue Jun 26, 2012 10:17 pm
Thanks AG, this really helped. Today's mini-session was much more
musical/interesting. I had some cross-patching happening between
the 601 and 503, using the 601's band envelope outs.
I was using bi-polar mode and faster speeds at first and it was
tapping out to quickly or bouncing at light speed.
0netwo0netwo
Post by 0netwo0netwo » Wed Feb 14, 2018 2:10 am
__ag wrote:Hello,
same for Y tilt.
all the very best
andre
wouldnt rotating left also go to -5V 0v at midpoint and then +5V if it was switched to bipolar (either x or y axis)??
and where is the "midpoint" if you have CV inputted into either x or y with them switched to bipolar?
ADDAC System
Post by ADDAC System » Sun Feb 18, 2018 3:59 am
0netwo0netwo wrote:
__ag wrote:Hello,
same for Y tilt.
all the very best
andre
Hi 0netwo0netwo! If the outputs are switched to bipolar then yes, rotating the knob will essentially go from -5V to +5V. Your second question isn't very specific: I presume that you mean that the CV input functionality is switched to bipolar, right? Midpoint is at 12 o'clock.
I highly suggest you take a look at this video, made specifically for the ADDAC503. It goes through all the parameters in much detail.
0netwo0netwo
Post by 0netwo0netwo » Sun Feb 18, 2018 4:21 am
:eek: i missed the part where you explained about the pot defaulting to unipolar
so
if the switch is set to unipolar you get full knob range manually but if you add CV then you have to switch to bipolar in order to get full knob range "manually"??
ive watched that video so many times and i still dont get it, i mean i do but then i dont LOL :deadbanana:
regardless, its still a fun module to try to understand
and i did send you an email, still waiting on the response to it :tu:
have a nice day AG
ADDAC System
Post by ADDAC System » Sun Feb 18, 2018 4:59 am
0netwo0netwo wrote::eek: i missed the part where you explained about the pot defaulting to unipolar
so
The knob does not default to unipolar. Let me put it this way: the knob's position determines the motion direction (tilt left or right, tilt upwards or downwards) and how fast it happens (respecting the Speed setting as well). At 12 o'clock there is no tilt/no motion. That is always the case.
The switch next to the parameter determines what the incoming CV is recognized as, unipolar or bipolar. When an LFO is plugged, the knob acts as an attenuator to the incoming signal. So the result depends on what the incoming signal is, what the switch position is etc.
Also, keep in mind that there's a switch for the output CV which can either be unipolar or bipolar. This is independent of the incoming CV and allows allows the ADDAC503 to be used on any type of situation, whether you want to use it with 0-5V or -5V to +5V.
Hope this clears up your questions!
0netwo0netwo
Post by 0netwo0netwo » Sun Feb 18, 2018 5:11 am
ok i think maybe i was confusing the XY knobs with the other settings
X and Y start from mid point and all the other knobs start at full CCW
Paranormal Patroler
Post by Paranormal Patroler » Sat Mar 24, 2018 4:55 am
I just got this module back in my newest setup and I'm super excited to be getting back in bouncing balls territory! :hyper:
groovar
Post by groovar » Mon Feb 11, 2019 2:29 pm
does anyone have a "jumping" issue with this? no matter how much i try and control the marble, and mimic the demo, it still "jumps" erratically randomly. not even across the whole grid...and not when it hits the side....
i'm just trying for it to roll around smooth
propertyof
Post by propertyof » Mon Feb 11, 2019 3:26 pm
groovar wrote:does anyone have a "jumping" issue with this? no matter how much i try and control the marble, and mimic the demo, it still "jumps" erratically randomly. not even across the whole grid...and not when it hits the side....
Same with mine! got this module few weeks ago, trying to mimic the demo too with an O’tool+. Works but not exactly like what the demo does. The ball got jumping issue everytime in a while. Maybe a calibration issue?
Mine seems also has problem with the x lock.
groovar
Post by groovar » Mon Feb 11, 2019 3:51 pm
hmmm. my lock seems ok but the jumping is driving me nuts. i REALLY like the idea behind this and have tried very patiently. I made a little video I am going to send over to them.
propertyof
Post by propertyof » Tue Feb 12, 2019 2:15 am
Please share it here if you got any updates from them. I might send them email too about this later.
groovar
Post by groovar » Tue Feb 12, 2019 12:01 pm
I sent them an email with videos attached. Will update here when I hear back.
Paranormal Patroler
Post by Paranormal Patroler » Wed Feb 13, 2019 3:21 am
Are you using the bump ? From your description it seems like the module bumps on its own. Is that the case?
How do you have it patched or is it completely unpatched?
groovar
Post by groovar » Wed Feb 13, 2019 9:55 am
Completely unpatched. Have gone through every position position including mimicing the demo exactly. It just randomly “twitches”, which makes it impossible to do a smooth, slow modulation
propertyof
Post by propertyof » Mon Feb 18, 2019 9:37 pm
groovar
Any updates from ADDAC about this issue?
Would love to hear it.
I’ve sent them an email with video too last weekend and still waiting for Andre to respond.
propertyof
Post by propertyof » Mon Feb 18, 2019 9:45 pm
groovar wrote:hmmm. my lock seems ok but the jumping is driving me nuts. i REALLY like the idea behind this and have tried very patiently. I made a little video I am going to send over to them.
About the X-lock, I notice the toggle switch in my X-Lock is different from the other switches. It has 3 positions (up, middle, down) while the rest are only 2 (up & down). The one in the demo video only has 2, and it made me confused the first time since the panel made me thought that it looks like there are 3 position available too (unlock, x lock, lock). I checked it and turns out it’s using different kind toggle switch.
I seems doesn’t affect the lock/unlock function, just confusing.
How does anyone's x-lock switch btw?
Return to “ADDAC System”
