Nord Modular thread
Anything modular synth related that is not format specific.
daveholiday
Re: Nord Modular thread
Post by daveholiday » Thu May 27, 2021 2:10 pm
ipnoteca wrote:
Wed May 26, 2021 3:50 am
does anyone knows if encore electronics is still doing business?
If you are curious about the availability of the expansion card, I have reached out to Tony. I will let you know when I here back from him!
It is all shits and giggles,
until somebody giggles and shits.
Stuff for sale: viewtopic.php?f=74&t=248930&p=3532378#p3532378
ipnoteca
cane morto
Post by ipnoteca » Thu May 27, 2021 6:44 pm
exactly! thank you so much!!!
sent an email couple of weeks ago but no answer so far.
i've blown a fuse...
previously robocoder
YOUTUBE http://www.youtube.com/user/ipnoteca
INSTAGRAM http://www.instagram.com/ipnoteca/
modulator_esp
schizophonic!
Post by modulator_esp » Fri May 28, 2021 4:29 am
G2 expansion appears to be available at Encore
http://www.encoreelectronics.com/cont_product.html
I just like weird music and adventures in sound - gear for sale
ipnoteca
cane morto
Post by ipnoteca » Fri May 28, 2021 4:56 am
thank you saw that, but before throw in the wild 500$ i prefer to have verbal confirmation ;)
daveholiday
Post by daveholiday » Wed Jun 02, 2021 6:40 pm
So my G2 came in a road case.....I have no use for a road case. Anyone here need a case for their Nord Modular G2?
Aside from Dexter....he seems to like it!
Dave Peck
Post by Dave Peck » Thu Jun 03, 2021 3:28 am
Seems to make a pretty badass looking cat bed!
daveholiday
Post by daveholiday » Fri Jun 04, 2021 4:38 pm
Navs
Post by Navs » Sat Jun 05, 2021 1:35 am
Well that's sorted then. Cat says the case stays.
Mitchk1989
*Probably* not a cyborg.
Post by Mitchk1989 » Sat Jun 05, 2021 7:42 pm
https://github.com/Lyve1981/dsp56300
This is still a little way out but the DSP chip the nord modular platform runs on is in the process of being emulated...
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Sun Jun 06, 2021 1:23 pm
My hope is that some programmer finds a way to make the Axoloti or the Akso boards run with a interface as elegant as the Nord's. They can do a ton of stuff already, many things the Nords can't. It is just not as easy or fun as it is on the Nords.
-James
rrooyyccee
Post by rrooyyccee » Mon Jun 07, 2021 12:51 pm
Hello:
I have a somewhat simple question.
What is the best way to make a tremolo for a polyphonic patch?
I understand the LFO should exist in the polyphonic part of the window.
But I'm not sure how to handle the audio.
Royce
Dave Peck
Post by Dave Peck » Mon Jun 07, 2021 4:44 pm
Hello:
Royce
Lots of ways to do this.
First, set the LFO signal output to POSITIVE OFFSET, either using a button on the LFO or by sending the LFO through a level shifter module.
Then:
If you want each voice to have it's own tremolo and you don't want the effect in sync across all voices, use any LFO +VCA at the end of the voice signal chain in the upper 'poly' window. You could even 'force' the LFOs to run at slightly different rates by using an LFO with a rate mod input and give them a little bit of KYBD CV so higher notes have slightly faster tremolo etc.
If you want all voices to have synchronized tremolo, you can put an LFO +VCA in the lower effects window and route the polyphonic patch from the upper window to the lower effects section, and it's like running any polyphonic synth through a stomp box effect. All voices go through ONE tremolo effect generator.
There is a another way to do this synchronized tremolo by using one of the more complex LFOs in the upper window scheme described above and select the little MONO button on the LFO which forces all of those replicated LFOs across all voices to operate in sync. But it probably uses up more DSP because you're forcing lots of LFOs to act as one LFO.
NOTE: To control the DEPTH of the tremolo effect, I suggest send the LFO (after the positive offset) to one input of a crossfader and send a +64 constant level to the second crossfader input, and send the crossfader output to the control input of the VCA that is processing the audio. now the knob on the crossfader sets the balance between 'always on' (no tremolo) and '100% tremolo effect'.
ipnoteca
cane morto
Post by ipnoteca » Fri Jun 11, 2021 10:10 am
i am on G2 rack and this thing is driving me crazy, but can someone explain me why in the "assign midi control" some channels are missing?
for exammple, channel 7 is not listed and by default is assigned to master volume and is not possible to change or customize.
or on channel 19 that's empty, one of the knob on the midi controller make jump from one project to another?
any idea?
thank you in advance!
jamos
Post by jamos » Fri Jun 11, 2021 10:41 am
Those aren't channels, they are continuous controllers.
The preassigned controllers cannot be reassigned. That's the way it is.
Controller 7 is the MIDI standard for volume. Controller 19 toggles between performance and patch mode.
This is all explained on page 142 and 143 of the manual.
Nord Modular G2 & G2X, Emulator X, MPC Live, and a growing Euro system.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Fri Jun 11, 2021 11:12 am
Here is the pertinent page of the manual and the manual if you need it.
G2Manual_V1_4.pdf
G2 Owner's Manual v1.4
(10.6 MiB) Downloaded 1 time
-James
ipnoteca
cane morto
Post by ipnoteca » Fri Jun 11, 2021 8:11 pm
@jamos and @ersatzplanet thank you!
last night while was hitting head on monitor i though myself why not RTFM :lol:
guess have to configure my midi controller accordingly.
cheers :guinness:
Return to “Modular Synth General Discussion”
