stg graphic sequencer not advancing
J1m
the wiggler of aus
Post by J1m » Fri Sep 30, 2011 8:13 pm
Had this unit going well, and let me say, it's the best. Had to unplug it though and now it's back on it won't advance through the stages. First slider lights up but that's it. I've tried gate from wogglebug, noisering and oberkorn, but no luck.
I read on another thread that this happens when the board fries so I'm feeling some degree of terror. BUT it's a brand new unit and power polarity is definately correct as it only fits in one way. Using Uzeus for power. Only thing I've done differently is swap a 12 1.5ma psu (which came with it) for a 15 2ma psu provided by tiptop.
Now it may be I'm doing something dopey, so apologies in advance but if anyone has thoughts they'd be well appreciated.
J1m
the wiggler of aus
Post by J1m » Wed Oct 05, 2011 7:20 pm
So no thoughts? STG? Bueller? Anyone? I'll email the retailer I guess...
infradead
leader of the secret trombones
Post by infradead » Wed Oct 05, 2011 7:27 pm
knobs not on 1 is it?
i know i did this once and was stumped... :doh:
Tacoma Noise Rodeo
polyroy
Ambient Wiggler
Post by polyroy » Wed Oct 05, 2011 7:28 pm
Email STG, from what I've heard he's responsive and a good bloke to deal with. Sorry to hear about your woes.
polyroy
Ambient Wiggler
Post by polyroy » Wed Oct 05, 2011 7:29 pm
infradead wrote:knobs not on 1 is it?
Haha shit, I know for a fact that I'd end up doing something like that if I owned one.
theparegorickid
Interzone, Inc.
Post by theparegorickid » Wed Oct 05, 2011 8:36 pm
Stg is an awesome guy. I'm afraid you are going to have to buy a new pcb from him. He is a busy guy but will eventually get back to you.
J1m
the wiggler of aus
Post by J1m » Fri Oct 07, 2011 7:00 am
Thanks folks. It aint on one, but I still can't shake the thought I must be doing something wack. Have an email for stg so will email directly. Seems like a fine gent.
suitandtieguy
Hammond King
Post by suitandtieguy » Fri Oct 07, 2011 7:27 pm
shit. i can't believe i didn't notice this thread until today.
my responsiveness sometimes wavers. i'm sorry.
http://suitandtieguy.com
http://stgsoundlabs.com
http://knobcon.com
J1m
the wiggler of aus
graphic eq
Post by J1m » Tue Oct 11, 2011 7:38 pm
No dramas! With any luck you are busy working on an asr :hihi:
What can I do about the sequencer? Maybe send me a pm or email?
suitandtieguy
Hammond King
Post by suitandtieguy » Tue Oct 11, 2011 8:44 pm
i did actually get the panels in for the ASR last week, so it's closer.
i think i got your email, sent from your Atari 2600? i typed a response but haven't sent it yet.
http://knobcon.com
vav
Beer Master
Post by vav » Tue Oct 11, 2011 10:00 pm
Hey what happened to Nelson's troll post?
Vactrols are the electronic equivalent of being drunk. -decaying.sine
giorgio
NITE MIND
Post by giorgio » Tue Oct 11, 2011 11:35 pm
vav wrote:Hey what happened to Nelson's troll post?
check muffwiggler.com i think he posted there
srsonido
Re: stg graphic sequencer not advancing
Post by srsonido » Sun Oct 11, 2015 11:05 pm
J1m wrote:Had this unit going well... Had to unplug it though and now it's back on it won't advance through the stages. First slider lights up but that's it...
Hi Jim,
Just a thought regarding STG GS, since you said it was a new unit.
Stop me if you've heard this one, but the STG GS has an offset on the step input that can cause problems with some triggering. It is a known design issue and I have discussed it with STG personally. In short, the STG GS sometimes doesn't play well with others. What happens specifically is that depending on the trigger source (ie, Trigger Riot/ MATHS/ etc.) the step input on the STG GS may float up by a couple volts - high enough that it essentially holds the input high and the clock can't drive the STG GS step input below the "off" threshold to trigger the step.
The fix is for STG to change the circuit design so that it will work with all clocks / triggers, but he has not offered to do that except as a $100 retro fit. In lieu of that, the workaround is to add a buffer between the driving trigger source and the step input on the STG GS. I find that running the trigger through a buffered mult usually does the trick because most are designed to correctly drive the next stage.
It's worth a shot befopre you scrap the board. Good luck.
I'm interested to hear the outcome of your issue too. Please post the results or PM me if you prefer.
Cheers,
J1m
the wiggler of aus
Post by J1m » Mon Oct 12, 2015 12:01 am
Hey Srsonido,
Thanks for that. This was years ago! I think what had happened was a surge elsewhere damaged the unit through the 5v rail. Apparently this issue can't happen with the new board. I've now had that installed and everything runs beautifully.
Thanks for the great post, though: it will undoubtedly help other with a similar issue.
Cheers,
srsonido
Post by srsonido » Mon Oct 12, 2015 12:32 am
J1m wrote:Hey Srsonido,
Cheers,
Ha! I saw the Sept, 30 and missed the 2011! Long day...
But yeah, if it adds to the knowledge base so much the better.
Glad you're straightened out.
Cheers.
Return to “STG Soundlabs”
