VC-ADSR version number help
terjewinther
Post by terjewinther » Sat Aug 27, 2011 7:57 am
Looked through all the unfinished drawer today, and found two PCBs that obviously were meant to be together: a four-pot board and a VC-ADSR board. However, looking through all my pdf docs, I have lost overview of the various issue numbers for the envelope variations.
The boards are:
- Four-pot, iss# 1
- VC-ADSR, iss# 2
I can find the pdfs for the correct 4pot and for various envelope versions, both the early non-vc version and various "upgrade" docs for the "newer" vc-adrs, version 1.0, 1,3 and version 3 and 4 - but not for version 2, that is: if board issue #2 corresponds to the docs version 2. Or am I missing something?
So please, which versions of the docs are needed to make the two boards above into a complete module?
Re: VC-ADSR version number help
Post by Synthbuilder » Sat Aug 27, 2011 10:20 am
terjewinther wrote:So please, which versions of the docs are needed to make the two boards above into a complete module?
There's only one Fourpot board issue. So the older 'Fourpot' VC-ADSR Upgrade User Guide (v1.3) on the site is the one to use:
http://www.oakleysound.com/vc-adsr.htm
However, that will only tell you how to populate the Fourpot and how to wire it to the VC-ADSR PCB.
For the issue 2 VC-ADSR PCB itself you need to have the User's and Builder's Guide for the issue 2 ADSR module. It should say VC-ADSR board issue 2 on the front. The most current version is also on the site:
http://www.oakleysound.com/adsr.htm
terjewinther
Post by terjewinther » Sun Aug 28, 2011 6:10 am
Ahhh..... Great!
Now I know how to put the two together.
TwinX
Post by TwinX » Wed Nov 13, 2019 2:58 am
My appologies to raise this thread from the archive.
I finally found time after 18 years and i have almost completed all oakley boards :banana:
So 1 board i am building right now but without success as i applied the vc-adsr issue 2 building guide to the vc-adsr issue 1 board. It all went ok until i hit the capacitors. They are certainly not the same. But i was warned as the document says issue 2 is very diffrent from issue 1 :doh:
Does anyone have the buidling manual for vc-adsr issue 1? I would not like to throw it away.
The fourpot is done allready.
Post by Synthbuilder » Wed Nov 13, 2019 4:14 am
TwinX wrote:Does anyone have the building manual for vc-adsr issue 1?
I just put it onto the Legacy Support page. It's the third one down.
http://www.oakleysound.com/legacy.htm
TwinX
Post by TwinX » Wed Nov 13, 2019 7:51 am
Synthbuilder wrote: I just put it onto the Legacy Support page. It's the third one down.
Tony many thanks really helpfull as i remebered.
