CV multivoice keyboard options for ASV?
umma gumma
Post by umma gumma » Mon Apr 26, 2021 7:47 pm
Lets say you had 4x ASV builds, and wanted to replicate an Oberheim FVS setup with poly 4 voice keyboard control
What kind of controller options are there? Is there a 4 voice CV output keyboard controller?
or would you need a MIDI to CV adaptor to get proper 4 voice polyphony? That probably opens up your keyboard options compared to straight CV
And lets say you wanted an 8 voice ASV what is the ideal setup?
I assume CV would be preferable as there would be no MIDI lag between voice/envelope triggering?
I suppose you might also want to build a master controller for all the voice modules, like the Oberheims had. Is this a crazy line of thought?
It would be glorious though...
Thx
Schlumpfhut
Re: CV multivoice keyboard options for ASV?
Post by Schlumpfhut » Tue Apr 27, 2021 12:17 am
One serious possiblitly for such task would be the midmuso CV12. It's a 4-voice MIDI/CV convertor of which multiple PCB can be daisy-chained to accive higher grades of polyphony. On the downside one would have to make a custom frontpanel and wire all jack sockets by hand but this should be doable
https://midimuso.co.uk
umma gumma
Post by umma gumma » Tue Apr 27, 2021 3:58 am
Wow look at that!! What a useful device
You could run 2 of them to get 8x CV channels out
Thanks for the link!!
Flareless
Post by Flareless » Wed Apr 28, 2021 5:27 am
@Schlumpfhut Thank you for the tip! I just ordered a kit.
Only 1 Kit left in stock UG.... I'd go for it!
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
umma gumma
Post by umma gumma » Sun May 02, 2021 12:29 am
Yep I ordered two of them, plus 3x of the accessory cables per unit, to get a bunch more gates/customizable outs. Should be fun with sequencers & other stuff!
Thanks for the headsup @Schlumpfhut!!!
oozitron
solder fume huffer
Post by oozitron » Mon May 10, 2021 10:23 pm
I used a Yarns for my ASV Four Voice and I'm very happy with it.
1) It works fine on +/- 15 volts (so you can use one PS for everything)
2) it takes MIDI pitch bend data and injects the voltage into the CV outputs
3) it has a built-in LFO (amount controlled by MIDI mod wheel amount) and injects the voltage into the CV outputs
4) it has portamento, even in polyphonic modes
5) it has a fun little sequencer built in, as well an an arpeggiator (clocked internally or externally)
6) it has a MIDI out that can be connected to a second Yarns for 8 voice control (but I haven't tried it out, YMMV)
Andrew
Never want to come down, never want to put my feet back down on the ground
umma gumma
Post by umma gumma » Mon Jul 19, 2021 1:36 am
Thanks for the tip!
Dave Peck
Post by Dave Peck » Tue Jul 20, 2021 5:53 pm
There are quite a few good four-voice (or more) Midi to CV converters available, either as modules or a standalone boxes. They generally provide lots of useful options for things like voice allocation (round-robin, re-assign, mono mode, etc.) and many have built in features like portamento, arpeggiators, vibrato LFOs that are controlled by the mod wheel on the connected midi keyboard, etc. I don't think midi lag is anything to be concerned about. If the converter is connected directly between the source midi keyboard and the ASVs, it's going to be faster than a human's ability to move a key from the 'up' position to the 'down' position on a keyboard. Get whatever type has the features you need.
folpon
Post by folpon » Tue Jul 20, 2021 7:28 pm
I don't have an ASV (I actually really wish I did, though. Maybe I should build one?) but I do happen to use, and strongly recommend, the Roland MPU-101 for four voice MIDI to CV. Best of luck!
Los Angeles Public Libra
@folpon
umma gumma
Post by umma gumma » Tue Jul 20, 2021 8:39 pm
Thanks guys!
Dave Peck
Post by Dave Peck » Fri Jul 23, 2021 4:50 pm
Another popular option for polyphonic midi to CV box would be the "CV.OCD" box: https://six4pix.net/product/cvocd/
Or a Euro module option (modulargrid should be a good place to search for more): https://polyend.com/poly2-midi-to-cv-converter/
Or a MU version, which might be handy for use with the ASVs: https://www.groveaudio.com/gms744_mu.html
And the 'big guys', in rack mount format, like the Doepfer MCV24 and the Encore Expressionist:
http://www.doepfer.de/mcv24_e.htm and http://www.encoreelectronics.com/cont_expres.html
