CV multivoice keyboard options for ASV?
umma gumma
Post by umma gumma » Mon Apr 26, 2021 7:47 pm
Lets say you had 4x ASV builds, and wanted to replicate an Oberheim FVS setup with poly 4 voice keyboard control
What kind of controller options are there? Is there a 4 voice CV output keyboard controller?
or would you need a MIDI to CV adaptor to get proper 4 voice polyphony? That probably opens up your keyboard options compared to straight CV
And lets say you wanted an 8 voice ASV what is the ideal setup?
I assume CV would be preferable as there would be no MIDI lag between voice/envelope triggering?
I suppose you might also want to build a master controller for all the voice modules, like the Oberheims had. Is this a crazy line of thought?
It would be glorious though...
Thx
Schlumpfhut
Re: CV multivoice keyboard options for ASV?
Post by Schlumpfhut » Tue Apr 27, 2021 12:17 am
One serious possiblitly for such task would be the midmuso CV12. It's a 4-voice MIDI/CV convertor of which multiple PCB can be daisy-chained to accive higher grades of polyphony. On the downside one would have to make a custom frontpanel and wire all jack sockets by hand but this should be doable
https://midimuso.co.uk
umma gumma
Post by umma gumma » Tue Apr 27, 2021 3:58 am
Wow look at that!! What a useful device
You could run 2 of them to get 8x CV channels out
Thanks for the link!!
Flareless
Post by Flareless » Wed Apr 28, 2021 5:27 am
@Schlumpfhut Thank you for the tip! I just ordered a kit.
Only 1 Kit left in stock UG.... I'd go for it!
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
umma gumma
Post by umma gumma » Sun May 02, 2021 12:29 am
Yep I ordered two of them, plus 3x of the accessory cables per unit, to get a bunch more gates/customizable outs. Should be fun with sequencers & other stuff!
Thanks for the headsup @Schlumpfhut!!!
oozitron
solder fume huffer
Post by oozitron » Mon May 10, 2021 10:23 pm
I used a Yarns for my ASV Four Voice and I'm very happy with it.
1) It works fine on +/- 15 volts (so you can use one PS for everything)
2) it takes MIDI pitch bend data and injects the voltage into the CV outputs
3) it has a built-in LFO (amount controlled by MIDI mod wheel amount) and injects the voltage into the CV outputs
4) it has portamento, even in polyphonic modes
5) it has a fun little sequencer built in, as well an an arpeggiator (clocked internally or externally)
6) it has a MIDI out that can be connected to a second Yarns for 8 voice control (but I haven't tried it out, YMMV)
Andrew
Never want to come down, never want to put my feet back down on the ground
