OverDrive II on +/-12V ?
johnstilton
Post by johnstilton » Fri Mar 15, 2019 3:23 pm
Hello,
Does anyone here know if an Overdrive II can work on a +/-12VDC supply?
If so, but if modified component values are required or suggested, can someone provide suggested substitute values?
Thank you for your time.
Post by Synthbuilder » Sat Mar 16, 2019 6:25 am
Yes, it will run just fine on +/-12V. All the bits that rely on supply voltage have their own +/-5V supply which is generated from the main supply - which can be either +/-15V or +/-12V.
