Oakley SRE330 News
Oakley SRE330 News
Post by Synthbuilder » Thu Sep 07, 2017 3:44 am
This is a picture of the first prototype which has been sold already. Basically, it is an SE330 but with several key differences:
1. Stereo in and stereo out
2. Full 19" rack width
3. Triple 'Solina' style ensemble mode as well as the SE330's quad and dual ensemble/chorus modes.
4. LED metering.
5. Classic NE570 companding noise reduction.
This first prototype uses an issue 1 board which I thought could be improved a little - wrong sized component legends and some of the trimmers were a little too sensitive - so I've made an issue 2. They arrived last week and testing was completed yesterday.
Now I need to order some new power supply boards for it - although it could work with any decent +/-15V supply capable of supplying 250mA.
I am planning to make these available as ready made units although I will look into selling PCBs too. Price is yet to be confirmed. It would be nice to have them ready before the end of the year.
This is what the prototype sounds like.
https://soundcloud.com/takla-makan/sre330-noodling
The above is my playing around with the controls. In this sound sample set you hear the raw sawtooth first from a Roland Alpha Juno 2, and then the rest of the set I'm processing the Juno's mono output with the SRE330 to produce a rich string synth sound. At extreme modulation depths the induced vibrato effect can be very pronounced.
https://soundcloud.com/takla-makan/lowrey-vs-sre330
This above sample set uses a Roland Alpha Juno to create a raw sawtooth pad which is then sent to both an Oakley Sound SRE330 and a Lowrey Symphonic Ensemble unit from 1975. The Lowrey ensemble is basically their version of the triple ensemble circuitry from the Solina string machine complete with TCA350Y BBDs.
In this set you hear the same sound firstly played through the Lowrey and then the SRE330 in Triple Ensemble Mode. I crossfade between the two effects after each sound to show how similar they sound. However, they are not identical. The Lowrey is noisier with considerable modulation oscillator breakthrough and there is some of sort of peak in the frequency response which isn't there in the more mellow SRE330. The latter could be added with EQ should one wish to replicate that part of the sound.
It should be noted that the SRE330's and Lowrey's outputs have been put into mono for this sample set to recreate the sound of most analogue string machines.
Tony
Paradigm X
Post by Paradigm X » Thu Sep 07, 2017 5:31 am
wow looks great! :yay:
terjewinther
Re: Oakley SRE330 News
Post by terjewinther » Thu Sep 07, 2017 8:00 am
This is really cool. I don´t need one, but I want one and will buy one and build it, just because I like building, and and love chorus sounds on strings and noise and those things.
I do hope you will provide files for the front panel, and hints about where one can get an empty rack that fits, othervise this will be a challenge to build.
I notice that you need el.caps on the power needs to be low enough to go into a single space 19" rack cabinet. Could you please provide info in the builders manual regarding the maximum hight of these for the builders?
Post by Synthbuilder » Thu Sep 07, 2017 8:15 am
terjewinther wrote:I do hope you will provide files for the front panel, and hints about where one can get an empty rack that fits, othervise this will be a challenge to build.
I'm looking to get rack cases for this project. These would be pre-drilled and labelled. Might be a bit expensive to ship outside the UK though.
The Scheaffer file for just the front panel would also be available as normal.
That's a RPSU in the SRE330 prototype so the ones I have used there are the ones given in the Oakley Parts Guide. They're 1000uF 50V electrolytics, Rapid part: 11-3938.
Once I'm happy with the SRE330 build I'll write a Builder's Guide for it and update the generic Parts Guide to include any manufacturers part numbers. I don't think you'll find any problems getting 1000uF caps to fit though.
Tony
Leverkusen
Post by Leverkusen » Thu Sep 07, 2017 9:54 am
Wow - the examples sound gorgeous! :yay:
Since I already have an ensemble effect in the rack I'll wait for the 5U delay though, hoping it will go down to chorus speed too, and put it besides the flanger module for some occasional extra strings...
Eric the Red
Post by Eric the Red » Fri Sep 08, 2017 1:32 pm
Hey Tony - is this the "secret synth project" you have been dropping hints at in the 5U forum a few weeks/months ago?
Abandon all hope, ye who wiggle.
Post by Synthbuilder » Sat Sep 09, 2017 4:09 am
Eric the Red wrote:is this the "secret synth project" you have been dropping hints at in the 5U forum a few weeks/months ago?
No, that's the Mysterious Audio Plaything. Work is ongoing. The prototype has been built and the first set of boards designed. This is a standalone multivoice synth with some unusual features as well as being able to interface with any modular. Again the plan is to make it ready made but there is potential for PCBs and cases to be made available too.
Tony
Blake Smith
Post by Blake Smith » Sat Sep 09, 2017 12:40 pm
Those samples sound lovely. Still working on a se330 though.
That pcb is going to be huge.
Post by Synthbuilder » Sun Sep 10, 2017 3:44 am
Blake Smith wrote:That pcb is going to be huge.
It's a lot less deep compared to the SE330 but it is about 75% wider. It also has four layers of copper - the usual two outer layers plus two sandwiched inside. The four layers mean I can make the component density higher without impacting on performance. Indeed having one mostly solid plane of copper solely for 0V improves performance. Those extra layers do mean it is a more expensive board to make though.
The additional length of the board will make it more problematic sending it through the post. The thinner Filtrex boards can be sent in tubes but for these I will have to find some sort of box.
Tony
Eric the Red
Post by Eric the Red » Tue Sep 12, 2017 9:22 am
Thanks Tony
Dr Gris
Post by Dr Gris » Wed Sep 13, 2017 2:17 pm
I really want this!
Any idea of how deep this will be?
I'm thinking of mounting it in a flightcase (30cm deep) with modular (5U) stuff.
And route the ins & outs to a front panel somehow.
I guess ins & outs in the front isn't an option because of panelspace...??
Cheers
//Magnus
Post by Synthbuilder » Thu Sep 14, 2017 3:35 am
Dr Gris wrote:Any idea of how deep this will be?
The prototype case is 250mm deep but that has to include space for the +'/-15V power supply and I/O board. I think I can make any bespoke casing I have made a bit smaller - perhaps 220mm.
It won't fit on the standard panel - although you may be able to get four 3.5mm TRS sockets on there.
Tony
Dr Gris
Post by Dr Gris » Thu Sep 14, 2017 4:54 pm
Thanks Tony for your reply.
250mm is cool.
Trying to stay away from 3.5mm as much as I can.. :hihi:
I'll find a solution.
Looking forward to when it's available.
//M
Post by Synthbuilder » Mon Oct 02, 2017 7:56 am
A limited number of SRE330 PCBs are now available. Also available are the optional RPSU issue 2 power supply module for it and the SRE330 I/O PCB designed to make the socket wiring easy and a useful anti-thump unit.
I'm in the middle of writing the documentation for all three new boards and these should be ready before the end of this week.
More details and photos at the usual place:
http://www.oakleysound.com/sre330.htm
At some point I am hoping to offer these as ready made units.
Yes, I am aware of just how expensive the main board is. But it is large and four layer. That's not cheap to produce although it is a thing of beauty to be sure.
Tony
Dr Gris
Post by Dr Gris » Tue Oct 03, 2017 4:46 pm
Awesome!!
But unfotunately I don't think I have the time for DIY these days... :cry:
I'm hoping for a ready made unit one day.
Great work Tony, I love it's sound!! :love:
//M
babysealclub
Post by babysealclub » Tue Oct 03, 2017 5:14 pm
Absolutely beautiful!
Signature:
This is a block of text that can be added to posts you make. There is a 510 character limit. Think about it.
Post by Synthbuilder » Wed Oct 04, 2017 10:23 am
The first version of the Builder's Guide has been uploaded to the site. The direct link is here:
http://www.oakleysound.com/SRE330-BG2.pdf
There may be a few typos but the parts lists should be correct. Let me know if you find anything obviously wrong.
The User Guide, which also contains all the calibration details, will hopefully be online sometime early next week.
Tony
Eric the Red
Post by Eric the Red » Fri Oct 06, 2017 9:33 am
Out of curiousity, what would shipping cost to send a set of boards across the pond to the States?
Post by Synthbuilder » Sun Oct 08, 2017 9:47 am
Eric the Red wrote:Out of curiousity, what would shipping cost to send a set of boards across the pond to the States?
My standard rate is 9GBP for any order over 35GBP.
Tony
bujbot1
Post by bujbot1 » Thu Dec 28, 2017 10:45 am
Hi Tony,
Do you know if there's a mouser project link anywhere for this build? I'm very interested in it but am trying to get a feel for the total component cost.
Thanks.
Post by Synthbuilder » Thu Dec 28, 2017 12:52 pm
bujbot1 wrote:Do you know if there's a mouser project link anywhere for this build?
None that I know of. I don't think you'll be able to get everything from Mouser though.
Tony
Post by Synthbuilder » Sun Apr 15, 2018 10:42 am
Boards now back in stock.
These are issue 2.1 boards and are basically the same as issue 2 but have a smaller hole diameter for the trimmers to suit the recommended Bourns and Vishay devices.
Tony
BTG
Post by BTG » Mon Apr 23, 2018 10:13 pm
any idea of a ready made source of these?
Post by Synthbuilder » Tue Apr 24, 2018 4:38 am
BTG wrote:any idea of a ready made source of these?
I'm planning to do some but I've not had a chance to get back to the metal shop with the detailed design they need to make the case.
Right now any official ready made Oakley Sound SRE330 modules are just vapourware. I'll probably get there but I'm slow and easily distracted by other things.
Tony
Rex Coil 7
Post by Rex Coil 7 » Sun Jul 01, 2018 11:49 am
Tony
Just populated and calibrated PCBs would be an enormous help. Between having basic metal working skills and possession of/knowledge of how to use an o-scope, I think most people have the former over the latter.
So just offering populated/calibrated boards would get most folks far ahead of the game ... the enclosure is mostly handled with FPE cover panels, as well as a bit of time with a hand held drill motor. That level of offering would take less of your own time as well, Tony.
:despair: I'm not tellin' ... I'm just sayin'.
(I am VERY interested in the SRE330 ... the audio demos sound just excellent.)
:nana: :goo: :sb: :yay:
