disting mk4 firmware announcement thread
Discussion and support for Expert Sleepers' Silent Way software and hardware.
Moderators: Kent, os
Shledge
Post by Shledge » Fri Nov 23, 2018 11:36 am
Quick question - is the mk3 still being supported? Wondering if some of the extra modes will be ported to the mk3.
os
Post by os » Fri Nov 23, 2018 11:37 am
I don't anticipate any further development work on the mk3.
LexTron6K
Post by LexTron6K » Fri Nov 23, 2018 5:18 pm
os wrote:I don't anticipate any further development work on the mk3.
Dangit, I was really hoping to see that Sidechain Compressor brought over to the MK3.
collumn2016
Thanks Os for all the updates!
Post by collumn2016 » Sat Nov 24, 2018 7:22 am
Love all the changes you have been making and new algorithms. Love the simplified playlist file and the folders for samples in the audio algorithms. Another big favourite is Quantiser 2. Looking forward to trying all the new goodies you have added this time round. Your a star! Cheers.
MAXTHEDOG
Post by MAXTHEDOG » Sat Nov 24, 2018 5:38 pm
I’ve just bought a MK4 with v4.7 onboard. Can I update to v4.9 or do I have to do it via v4.8?
Regards,
MtD.
REVIVER
Post by REVIVER » Sat Nov 24, 2018 7:36 pm
RE: The Crossfade/Pan algo....can't seem to change any of the parameters. Z appears to control the LFO speed as I can turn it to 99 and back to 0, but pushing Z doesn't allow me to move through the other parameters.
:hmm:
Just me?
Shledge
Post by Shledge » Sat Nov 24, 2018 9:35 pm
Time to get more mk4s then, I guess!
os
Post by os » Sun Nov 25, 2018 3:43 am
@MAXTHEDOG You can go direct to any version.
@REVIVER As noted in the manual, that algorithm has the knob recorder, so pushing Z is reserved for that function.
MAXTHEDOG
Post by MAXTHEDOG » Sun Nov 25, 2018 3:54 am
Thanks os
REVIVER
Post by REVIVER » Sun Nov 25, 2018 8:59 am
os wrote:@REVIVER As noted in the manual, that algorithm has the knob recorder, so pushing Z is reserved for that function.
Shame on me...I've never even used the knob recorder function.
:doh:
Thank you!
The Grump
Post by The Grump » Sun Dec 02, 2018 6:23 pm
*edit
Never mind, I just need to RTFM and use my Distings more frequently.
adaris
Post by adaris » Mon Dec 03, 2018 1:43 pm
*Moved my question to a separate thread*
vantablack
Post by vantablack » Sun Dec 23, 2018 2:45 pm
I can't get the bassdrum to go through in sidechain (E5), the left and right is audible and z reacts on input :despair:
os
Post by os » Thu Feb 14, 2019 11:56 am
Feb 14th 2019 - v4.10:
* Added the Clockable SD Delay, Stereo Clockable SD Delay, and Stereo Clockable SD Delay (Z clock) algorithms.
* Added the Clockable Wavetable LFO algorithm.
* Added the Wavetable Waveshaper algorithm.
* Added the DJ Filter algorithm.
* Added the Dual Vowel Filter algorithm.
* Added the Mixer algorithm.
* Added individual output attenuverters and a Y Offset parameter to the Clockable LFO algorithm.
* Added a Y Offset parameter to the State Variable Filter, LP/HP Filter, LP/HP Filter, BP/HP Filter, and BP/Notch Filter algorithms.
* The Shift Register Random CVs algorithm now has an Offset parameter, and the Shift Register Random Quantized CVs algorithm now has a Transpose parameter. For both algorithms, the output attenuator is now an attenuverter.
* Increased the length of the filename displayed by the Audio Playback algorithms.
* Fixed a problem which would cause some unusually formatted WAV files not to work.
* Fixed a problem with receiving MIDI from certain devices (notably those by Elektron) which could result in stuck notes or notes being ignored.
* Fixed unnecessary output glitches which could occur when exiting the menu system or switching parameters.
* Fixed a problem which could cause the Z push to no longer switch parameters if the module were left untouched for about 7 hours.
jwm
Post by jwm » Thu Feb 14, 2019 2:12 pm
os wrote:* Added the Wavetable Waveshaper algorithm.
:hail: :hail: :hail: :hail:
druidgrif
Post by druidgrif » Thu Feb 14, 2019 4:53 pm
Okay, firmware update issue going from 4.5 to 4.10. Boots up and goes directly to "success". It's formatted to fat32 with the image.hex file as the only file on it in the root folder. It's a Sandisk Extreme 32gb. I'm not sure what to try next.
Thanks in advance.
os
Post by os » Fri Feb 15, 2019 3:54 am
Make sure it's also using the Master Boot Record scheme:
druidgrif
Post by druidgrif » Fri Feb 15, 2019 9:22 am
That worked. I had to use "diskpart" to change to mbr from command line because Windows likes to hide things to make it "easy".
:bang: :bang: :bang:
brother32
Post by brother32 » Sun Mar 17, 2019 2:51 pm
Respect for this module fellas :yay:
I'd like to see the ability to turn the screen upside down so I could insert the module upside down and still read it as normal.
os
Post by os » Tue Mar 19, 2019 4:59 am
March 19th 2019 - v4.10.1:
* Fixed a problem with unwanted noise in the VCO with linear FM algorithm's output.
* Changed the behaviour of the Audio Playback with Reverse algorithm when crossing between forward and reversed playback (and vice versa) to not fade to zero, which makes it more useful when used as an LFO.
* Fixed a crash in the Wavetable VCO algorithm at very high frequencies.
* Fixed a problem with the Clockable SD Delay algorithms where a very short delay time would actually produce a very long delay.
woelfl
Post by woelfl » Tue Mar 19, 2019 12:07 pm
wow... I just got my shipment of two distings this morning a couple of hours before v4.10.1 got released... you sir are absolutely awesome :yay:
klingklangmatze
Post by klingklangmatze » Wed Mar 27, 2019 8:49 am
I'm very impressed by the clockable SD delay. Many thanks for the thoughtful update.
solipsvs
Post by solipsvs » Wed Mar 27, 2019 12:48 pm
what a useful module. i got another one the other day.
os
Post by os » Wed Apr 03, 2019 2:34 am
April 3rd 2019 - v4.10.2:
* Fixed a problem with the Dual Audio Playback algorithm where samples would fail to switch as expected when changing Z.
* Fixed a problem which could lead to excessive noise in the Voltage Controlled Delay Line algorithm.
* Fixed a problem with the Clockable Ping Pong (Z input pan) algorithm where changing Z could introduce unexpected noise.
os
Post by os » Thu Jun 06, 2019 4:12 am
June 6th 2019 - v4.11:
* Added the Clockable SD Ping Pong algorithm.
* Added the Clockable Wavetable Envelope algorithm.
* The Wavetable VCO algorithm now has an option for output B to be a phase shifted version of output A.
* All algorithms that use wavetables now look in a specific folder for them, keeping them separate from normal audio files. The 'playlist-wavetable.txt' file is now optional.
* The Reverb algorithms now have a 'freeze' control, and a gain control for the reverb signal. The Size and Feedback parameters of these algorithms now use a range of 1-32.
* The VCO with waveshaping algorithm now has parameters for transpose and fine tune, and the option to use Z as an 'oscillator sync' input.
* The Voltage Controlled Delay Line algorithm now has an attenuator for the Y input and an option to insert a saturation stage into the delay feedback loop.
* The MIDI/CV algorithm now supports CC control of the outputs with a 0-10V range.
* Added support for fingered portamento to the MIDI/CV algorithm.
* Improved the quality of the Vocoder algorithm. Also added attenuator parameters for the Vocoder algorithm's outputs.
* Added a parameter to the MIDI File Playback (Clocked) algorithm to select the MIDI file directly, not using the Z knob/CV.
* Added the option of gate inverters to the Linear/Exponential Converter.
* Added support for sending MIDI clock into the disting over the Select Bus.
* All audio playback algorithms are now consistent about non-looping WAV files not playing until they're triggered.
* Added support for MIDI pitch bend to the Audio Playback with V/Oct and Multisample Audio Playback algorithms.
* The Clocked Audio Playback algorithm now has an option to use Z to control sample start position.
* Added the 'startQuantize' audio playlist option.
* Saving a preset now also saves which parameter is currently assigned to the S knob.
* Fixed a problem where the SD Delay algorithms would not work correctly if they were the first algorithm used at power up.
* Fixed a problem where using the knob recorder on the Dual Waveshaper algorithm would corrupt the output.
* Fixed a problem where non-looped WAV files might play with a click at the end of the sample.
Return to “Expert Sleepers”
