xlr -> 1/8" ts cables
Moderators: Kent, stretta
johnnywoods
Post by johnnywoods » Wed May 12, 2010 12:23 pm
would these work for volta?
http://www.sweetwater.com/store/detail/XVM305F/
I would make cables, but if these will work, then I get a few extra hours to actually play!
1nput0utput
Post by 1nput0utput » Wed May 12, 2010 2:42 pm
It's not possible to tell without knowing how they're wired. If XLR pins 2 and 3 are both connected to TS tip, then they won't work. You want pin 2 connected to tip and pin 1 connected to sleeve.
os
Post by os » Thu May 13, 2010 6:42 am
What an odd cable. Sadly the manufacturer's website doesn't shed any more light on the wiring:
http://www.hosatech.com/product/340572/ ... TS%2C_5_ft
Chances are it will work though.
criticalmonkey
Post by criticalmonkey » Fri May 14, 2010 12:45 am
fyi
this one will work
i use it with a motu 896 and volta on my euro rack and korg mono poly
doctorvague
ole fuckity fuck
Post by doctorvague » Sat May 15, 2010 8:54 am
I seriously doubt you're going to find an off the shelf solution that's wired to MOTU's spec - it's definitely not a standard. OTOH, I would think you could just snip the ring (pin 3 on an XLR) wire so it's not touching anything, maybe with a bit of tape and be good to go. I believe most cables are going to short pin 3 to ground rather than leaving it floating as MOTU specifies. Someone can correct me if this is incorrect.
sascha.victoria
deleted/nevermind
Post by sascha.victoria » Sat May 15, 2010 11:21 am
I'm just getting into Volta and the lack of clear documentation is somewhat mind blowing.
I'm 97% sure those cables won't work right. The closest off the shelf solution is to use an insert cable. Insert cables are TRS terminating in 2 jacks that are TR and TS. So you'd use the TR jack and leave the TS hanging or cut it off. I ordered 2 of these from eBay.
johnnywoods
Post by johnnywoods » Tue May 18, 2010 12:45 pm
thanks for all the input... I think I've realized I will have to suck it up and get out the solder. :doh:
I'm likely going to build a breakout box with 8 xlrs to run to the 896, and some 1/8" jacks for patching to the modular.
I'll let you know how it turns out!
sine
Post by sine » Wed May 19, 2010 7:33 am
sascha.victoria wrote:I'm just getting into Volta and the lack of clear documentation is somewhat mind blowing.
The Volta manual documents cable requirements, no?
oliviaarthur
Post by oliviaarthur » Wed Aug 18, 2010 3:28 pm
I use these snakes as well with volta- I scored them from a friend of mine who had them just sitting in his garage-
theslygoose
Post by theslygoose » Tue Aug 31, 2010 1:56 pm
Actually you can shop for them through me. Upon request I've made an "off-the-shelf" solution. I've successfully sold hundreds of Volta cables since May 09 and I'm sure you can get word of mouth from many people on this forum.
http://www.slygoosecables.com/index.php ... t&Itemid=2
The cables are made with 6 mm wire (standard mic size) and I've got a low-profile version coming soon too (4.5 mm wire). Hand-made, American wire, quality parts, TNT solder, etc.
Custom Audio/Video/Lighting cables
emergencyofstate
Synthesist
Post by emergencyofstate » Tue Aug 31, 2010 1:59 pm
^ I can vouch for Sly Goose Volta/Silent Way Cables. I've got about 10 myself :party:
Return to “Volta”
