when will we be able to have just a trigger with no cv
Moderators: Kent, stretta
revstate
Post by revstate » Sat Mar 06, 2010 6:22 pm
i know we can have multiple cvs with one trigger, but i want to use the volta to control a drm1 mkIII and a MBase through trigger inputs. is this an update that will be soon?
-bp
MrBiggs
I see dead people
Post by MrBiggs » Sat Mar 06, 2010 6:47 pm
Why not merely use the trigger sequencer? I often set up Volta with just a trigger seq or two to clock stuff like my modular sequencers.
Brian
•Music and stuff: Dance Robot Dance.
•Current contents:Modulargrid
doctorvague
ole fuckity fuck
Post by doctorvague » Tue Mar 09, 2010 9:30 am
MrBiggs wrote:Why not merely use the trigger sequencer? I often set up Volta with just a trigger seq or two to clock stuff like my modular sequencers.
Brian
Same here. I use 4 Volta trigger sequencers at different intervals and use a 4X4 matrix switcher to switch and route them on the fly. Then I often use a fifth Volta trigger seq set to fire every measure or 2 and use that as a reset pulse for the analog sequencers so everything has a 'One' reference. I love the tight timing of syncing this way. No MIDI slop at all. Even 64th notes are tighty-tight. The nice thing about the trigger sequencers is their versatility. You can set up rhythms, syncopations, off-beats, triplets, dots etc. It's an interesting area I've been exploring for several months. I HIGHLY recommend a hardware switcher of some kind (even a toggle switch) and to give these ideas a try.
Be sure to lower the duration of your trigger sequencers WAY down (I use 5). They default to 100 and won't work which is a fucking dumbass default for that parameter. I bet quite a few people have walked away from trying the trigger sequencer thinking something was wrong just because of that one parameter- it's easy to overlook.
Return to “Volta”
