Volta Interface??
Moderators: Kent, stretta
emergencyofstate
Synthesist
Volta Interface??
Post by emergencyofstate » Tue Feb 16, 2010 4:13 pm
Any hints or indications about a MOTU Volta specific interface? With Envelope controls and LFO speed control :) oh man...i NEED it.
bsmith
Post by bsmith » Tue Feb 16, 2010 4:57 pm
There's a device compatibility list going at expert sleepers site that should work with either volta or silent way (which you should check out):
http://www.expert-sleepers.co.uk/siwacompatibility.html
Also, I just emailed motu today asking about the 8pre, they say it is DC coupled, volta compatible.
emergencyofstate
Synthesist
Post by emergencyofstate » Tue Feb 16, 2010 6:34 pm
I currently use Volta with my MOTU Ultralite. I was thinking more along the lines of a dedicated/specific MOTU interface with hardware control of the plugin controls.
1nput0utput
Post by 1nput0utput » Wed Feb 17, 2010 11:21 am
udder wrote:Also, I just emailed motu today asking about the 8pre, they say it is DC coupled, volta compatible.
But the 8pre only has four analog output channels (stereo main outputs and stereo headphones output), so perhaps it's not the best choice for Volta. For the same price ($549), you could get the UltraLite mk3 Hybrid, which has twelve analog output channels (stereo main outputs, eight additional analog outputs, stereo headphones output).
bsmith
Post by bsmith » Wed Feb 17, 2010 11:30 am
Yeah, I didn't dig deep enough to see that, too bad it doesn't have equivalent outs (for more reasons than this kind of usage). What is cool about it though is that you could use the adat port to hang it off a non-compatible interface, like I'm doing now with a lexicon mpx500 using the s/pdif of my digi 002 for silent way...
1nput0utput
Post by 1nput0utput » Wed Feb 17, 2010 5:52 pm
What is cool about it though is that you could use the adat port to hang it off a non-compatible interface …
The 8pre's analog outputs (mains and phones) are disabled when it is in the standalone converter mode. You can do it with an UltraLite mk3 Hybrid (since it has S/PDIF input and standalone routing), but if you want more than two channels standalone D/A you should look at 828mk3, Traveler mk3, 896mk3, or 2408mk3.
jenamu6
Post by jenamu6 » Mon Mar 01, 2010 7:26 am
How many cv/gates channels will the traveler MKII give you?
emergencyofstate
Synthesist
Post by emergencyofstate » Mon Mar 01, 2010 11:08 am
Looks like 6. Provided you want to keep your main 1&2 outs for your monitor mix...if not, then 8. I don't recall whether you can use the headphones out for CV. If you can, add another output. Does anyone know? I'm too lazy to search this morning but I'm sure it's in one of the volta or silent way threads.
1nput0utput
Post by 1nput0utput » Mon Mar 01, 2010 11:35 am
jenamu6 wrote:How many cv/gates channels will the traveler MKII give you?
There was no Traveler mkII.
The original Traveler and the Traveler mk3 each have eight DC-coupled 1/4" analog outputs and a DC-coupled stereo headphones output. That's ten total CV outputs.
jenamu6
Post by jenamu6 » Mon Mar 01, 2010 11:36 am
OK thanks.......I've been offered one for 275 euro.
Really love the functionality of Volta/Silent way........especially for finally being able to do tonal stuff......but f8cking hate the computer for music.
peterende
1-Post Wiggler
Post by peterende » Fri Jun 24, 2011 9:55 pm
anyone tried using old rme fireface 400? does it work?
ssilk
Post by ssilk » Fri Jul 01, 2011 1:50 pm
word is that the rme ff400 will not work (except for the headphone output) - which is too bad, that really is one of my favorite interfaces
blakelists
1-Post Wiggler
Post by blakelists » Thu Jun 28, 2012 12:31 am
MOTU 828 listed as working with Silent Way. Yippeee!!! Will download and demo next week with my old 828.
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Thu Jun 28, 2012 10:24 am
blakelists wrote:MOTU 828 listed as working with Silent Way. Yippeee!!! Will download and demo next week with my old 828.
And you can get MOTU 828's on eBay for REALLY cheap. There is a Mk1 for $75 and a MkII for $76 on there now. and a couple more under $150. People always dump them as audio interfaces and they work great for CV controllers. I have 2 of them.
-James
mookmoof
Post by mookmoof » Tue Oct 23, 2012 3:30 pm
I use a duet2 for audio interface, but have a motu mk2 I'd like to use as a cv controller with volta. Is it possible to use both together? I use DP7 as host. Thanks
emergencyofstate
Synthesist
Post by emergencyofstate » Tue Oct 23, 2012 3:49 pm
mookmoof wrote: I use a duet2 for audio interface, but have a motu mk2 I'd like to use as a cv controller with volta. Is it possible to use both together? I use DP7 as host. Thanks
If you're on a MAC you can create an "Aggregate Device" which is a combination of both interfaces. You do this under -Audio MIDI Set up-
If you're on a PC, I'm not sure.
parasitk
Learn to swim
Post by parasitk » Tue Oct 23, 2012 3:54 pm
In DP though, you should be able to just go to Setup > Configure Audio System > Configure Hardware Driver (assuming it hasn't been moved since v6) and command + click as many audio interfaces as you need..
Return to “Volta”
