Sonic Potions LXR Drum Synthesizer
citizensmurf
Re: Sonic Potions LXR Drum Synthesizer
Post by citizensmurf »
Dibek wrote: Mon Feb 15, 2021 1:48 pm As far as I know 60Knobs is supposed to work with the original firmware and so it leads to problems when used with Brendan‘s firmware.
Does anyone know where to order lightpipes for the erica metalcase, mine came without them.
You don't need them anymore, solder the leds to be flush or just prowed of the case. I believe the latest build guide refers to this.
Dibek
Post by Dibek »
citizensmurf wrote: Mon Feb 15, 2021 10:39 pm
Thanks, i bought it prebuilt with an acrylic case and transitioned to the metal case, i‘d rather not replace all LEDs, I’m not good with diy. :)
Altitude909
Post by Altitude909 »
Mouser has the right parts
FungusCavern
Post by FungusCavern »
Hi all, sorry for this being my first post here.
I recently completed my build of the LXR kit, but I am having issues updating to the 0.37 firmware. I used the SD card image supplied on the LXR wiki and it runs fine with no errors, but the firmware on there is 0.21. When I try to swap the old 'FIRMWARE.BIN' to the newer 0.37 one and try updating to it, it always gives me a "kit read error".
Any idea on how to solve this issue?
Don't go to art school like I did
FungusCavern
Quick update: "kit read error" issue solved thanks to Julian's assistance.
If anyone else runs into this problem, when you unzip SdCardImage on your SD card make sure to move all files from the unzipped folder to the SD card's root directory/folder.
I misinterpreted to directions on the quickstart guide so all the fault is mine. A very silly mistake lol
Same thing goes for using the Brendan Clarke firmware.
Everything works great now, however I have another issue now where user samples play back as noise. Not too big of a deal since I'd rather focus on the LXR's synthesis capabilities.
OrionG
Post by OrionG »
With the bc firmware, if my lxr is externally midi sync’d, and i change the ‘wav’ on the oscillator page, my unit freezes. Does this happen to anyone else?
MoyaMoya
Post by MoyaMoya »
My unit will freeze with the BC firmware and original Firmware after about an hour of use. Typically this happens when a have 4 or 5 sequences going and am making use of the morph function.
Nelson Baboon
droolmaster0
Post by Nelson Baboon »
fyi, i have an lxr with both the regular and alternative firmware, and also the bastl controller that was built for me. Keep on meaning to put it up for sale, but haven't because i remember that a few of the buttons on the lxr had to be pressed more than once to work (was told this was a common 'feature').
in any case - feel free to ping me about these. I just don't have a clear idea yet as to how much, haven't tested it, etc, etc.
Slopstream
Post by Slopstream »
hiya,
bought a used LXR which I recieved a couple of days ago. lovely sounding machine!
having some trouble with the trigger outs, the only gate that gives a signal is the bass drum (voice/gate 1). I get no triggers from clock 1,2 or cv out 2-7 even though corresponding tracks are active and playing ... any ideas of how this could be solved?
I checked the trigger circuit board, and it looks OK - but i'm no expert. can post pictures if anyone want to give it a shot.
paperCUT
Post by paperCUT »
Slopstream wrote: Tue May 04, 2021 1:00 pm hiya,
It been a while since I opened mine but might be a loose ribbon connector to the trigger PCB.
Slopstream
thanks for the tip, tried refastening the ribbon connector, but no change :—(
MoyaMoya
Post by MoyaMoya »
The trigger outputs can be configured to either S-trig or V-trig.. perhaps the previous owner set them up to different configurations?
and they do not match your needs?
Have you tried measuring with a volt meter to see what they are outputting?
Try posting a nice high quality picture
leterell
Post by leterell »
Sounds like the unit i built like 7 years ago and sold maybe 2019... Couldn't find any fault with anything and gave up after a couple hours since i didn't need that feature at the time.
looking for a STORAGE STRIP for my D0!
Slopstream
here's a pic of the board:
haven't had the opportunity yet to check with a volt meter, I'll do that asap!
leterell wrote: Thu May 06, 2021 9:13 am Sounds like the unit i built like 7 years ago and sold maybe 2019... Couldn't find any fault with anything and gave up after a couple hours since i didn't need that feature at the time.
oh, could that be? I bought from someone in scotland, he said he mainly used the midi out and didn't have any experience with the cv triggers.
Altitude909
your jumpers are missing for most of the channels. You dont need to stuff the parts for the side youre not using but the jumpers have to be there
leterell
Post by leterell »
Slopstream wrote: Thu May 06, 2021 9:38 am oh, could that be? I bought from someone in scotland, he said he mainly used the midi out and didn't have any experience with the cv triggers.
man, that really looks like my sloppy ass soldering on those boards. I'd bet :75: you could find my fingerprints all over that flux :hihi:
reminds me i have to start washing the boards after soldering. but the next time I'll have time to take on a project like this will be when I'm retired... ...which is when I'll build that LXR kit i have on the shelf :oops:
Altitude909 wrote: Thu May 06, 2021 10:26 am your jumpers are missing for most of the channels. You dont need to stuff the parts for the side youre not using but the jumpers have to be there
that would be exactly something I'd miss. i have a vague recollection of having a bunch of jumpers i found at some point, unsure where they came from. really nice if you'd get my unit working with such an easy fix!
Altitude909
OrionG
Post by OrionG »
OrionG wrote: Wed Apr 21, 2021 12:44 pm With the bc firmware, if my lxr is externally midi sync’d, and i change the ‘wav’ on the oscillator page, my unit freezes. Does this happen to anyone else?
Update.i had downloaded and installed a pack called “tr patches for lxr” (bjorn fogelnergs pack). Turns out some of the files were corrupt and causing my lxr to freeze. Since removing them i haven’t had a crash (fingers crossed).
CrankSatori
Post by CrankSatori »
Anyone have a copy of the most recent firmware for the LXR? I had LXR-OWL installed for years and want to revert to the Sonic Potions firmware if possible, but most of the links for firmware on the Sonic Potions site seem to be dead, and the latest I could download there was v0.21. Anybody happen to have v0.37 or know where I can find it? Not having a lot of luck tracking it down so far..
bassg
Post by bassg »
CrankSatori wrote: Thu Jun 23, 2022 3:03 am Anyone have a copy of the most recent firmware for the LXR? I had LXR-OWL installed for years and want to revert to the Sonic Potions firmware if possible, but most of the links for firmware on the Sonic Potions site seem to be dead, and the latest I could download there was v0.21. Anybody happen to have v0.37 or know where I can find it? Not having a lot of luck tracking it down so far..
Perhaps here? -> https://github.com/SonicPotions/LXR
There's a "firmware image 0.37" bin file, but I am not sure if it's what you're looking for.
CrankSatori
bassg wrote: Thu Jun 23, 2022 3:46 am Perhaps here? -> https://github.com/SonicPotions/LXR
Just installed, that's it! How I missed that there's a github! SMDH
Thank you! That helps a lot!
bassg
Post by bassg »
CrankSatori wrote: Thu Jun 23, 2022 6:11 am
You're most welcome! I am glad to hear it helped.
