Roland AIRA Compact T-8 J-6 E-4, S1 and bears - oh my!
O1B
Re: Roland AIRA Compact T-8 J-6 E-4
Post by O1B »
A bit short :bang: my fail… MIDI sync cable duties.
Thanks again, Dave!
mome rath wrote: Fri Jun 24, 2022 9:13 am
oooooooooh curly ones :love:
Yes. It’ll scatter Pre or Post, as will Reverb/FX.
Voice mangling is only Pre.. :roll: .. kinda the point of … :despair:
pity the mic port isn’t Stereo.
Aira Scooper may have to join the chain….
exper wrote: Fri Jun 24, 2022 9:21 am I might have missed this, but can the E4 scatter live input without recording it as a loop first? I remember Roland's old eurorack scatter module needed to record the input before affecting the sound.
exper
Post by exper »
O1B wrote: Fri Jun 24, 2022 11:18 am Yes. It’ll scatter Pre or Post, as will Reverb/FX.
Ah ok, thanks for clarifying that. Still might be fun to put stuff through it in mono. Stereo in would have been awesome.
O1B
Post by O1B »
. It is awesome in mono… very.
I usually hate random scatter … usually… here… 👍
Scatter w Verb, synced… 👍
Drums… vocals…. Mix….Dub.. :tu:
exper wrote: Fri Jun 24, 2022 11:33 am Ah ok, thanks for clarifying that. Still might be fun to put stuff through it in mono. Stereo in would have been awesome.
O1B
Post by O1B »
mome rath
a dubious cube of margarine
Post by mome rath »
http://soundcloud.com/sex_trout/m-0-n-d ... al_sharing
T8 and monomachine
love this little feller :love: :love:
stripou wrote: Thu Jul 07, 2022 10:42 am Also can we stop with the passive mult jokes pls my moms a passive mult.
mjlong wrote: Mon Sep 26, 2022 2:00 pm
Back Down the Path wrote: Mon Sep 26, 2022 11:49 am The Elektron workflow: some like it, some don’t.
It’s the cilantro of the electronic music world
Mr_Sulcus
Post by Mr_Sulcus »
I noticed today that the Kick Drum pattern on the T8 does not randomize. I found this really helpful for jamming random patterns without losing the flow, but I'm not sure if this is intentional or if I've mangled a setting...I can't find mention of it in the manual. Anyone else's work differently?
GNSDG
Post by GNSDG »
O1B wrote: Mon Jun 20, 2022 6:33 am
The Manual SUCKS!!!!
Is there a way to internally lock the tempo to something other than 130.0 bpm.
The t8 and j6? Seem easy to do, but the e4…. :foul:
How do you change the tempo at all, internally, from 130.0? :hmm:
Did anyone figure this out? I also can’t see how to change BPM… and yes manual sucks. I have yet to successfully get the thing out of menu mode.
WTB: Your 54HP lunchbox!
GNSDG
Post by GNSDG »
ALSO can anyone confirm these don’t let you record the mix in? Looks that way from signal flow chart and I couldn’t see an option to do so when connected to USB. I thought the boutiques generally allowed this though.
Voltcontrol
Ravey Dave
Post by Voltcontrol »
mome rath wrote: Fri Jul 08, 2022 10:56 am http://soundcloud.com/sex_trout/m-0-n-d ... al_sharing
T8 and monomachine
:party: Damn, that's quite nice indeed! :party:
Gaun Yersel!
mome rath
Post by mome rath »
Voltcontrol wrote: Wed Sep 14, 2022 4:09 pm
T8 and monomachine
thanks :oops:
mome rath
Post by mome rath »
couple more
doesn't do particularly well at low rez on a square wave
but for $199, hey
xdiplo
Post by xdiplo »
Mr_Sulcus wrote: Fri Aug 12, 2022 3:07 pm I noticed today that the Kick Drum pattern on the T8 does not randomize. I found this really helpful for jamming random patterns without losing the flow, but I'm not sure if this is intentional or if I've mangled a setting...I can't find mention of it in the manual. Anyone else's work differently?
Yes, same here. i was a bit confused at first and thought i was doing a wrong process but as you said it's better like that.
mome rath
Post by mome rath »
aaaaaaaaaaand another
used the internal overdrive, it's OK but I don't like how you have to access/control it
u0421793
Post by u0421793 »
If there’s any more planned, I’d like what amounts to a tiny MC-202 - as a lead synth. It’d have to have a few fewer synth controls than a 101 to fit the form factor, so I’m wondering what can be dispensed with or function-shifted. The sequencer side would be useful if it were a riff launcher / looper, so you could improvise riffs and motifs and combine them, repeat them and recall, or something like that which would be good for live performance.
Mr_Sulcus
Post by Mr_Sulcus »
Has anyone synced up the looper apart of the E4 to a Eurorack setup, using a trigger/clock to quantize the loops?
Richard deHove
Post by Richard deHove »
No TRRS cable so I abused the mic input instead:
Headphones73
Post by Headphones73 »
I have a TB03, I’m getting a TR08, and I’m not a singer or rapper, so only the J6 would interest me tbh. Just for all the Chord functions you might stumble into.
Gear owned: Hungry Robot Modular Oscillator, Output, Slew, Sample & Hold, VCA, Looping ASDR, Sonicsmith Modulor A1, Behringer BI Phase, Crave, RD6, RD9, TD3, TD3MO, Korg OPSix, EA-1, ER-1 MK2, Boss SP202, SP404, SP505, RE20, Line 6 M5, Akai Miniak, S20, XR20, S2000, Moog MF102, MF104M, CP251, Dreadbox Erebus, Taff2, Roland MC 909, SP202, SP404, SP505, RC505, TB03, TR06, TR09
rplktr
Post by rplktr »
I don't think it gets enough attention that those super-cheap instruments support USB audio. The E-4 in particular accepts audio input via USB which allows for lossless harmonizing/scattering of any audio from your DAW while staying in time with your software and accepting MIDI input to control the harmonizer. See example where USB audio in+out and USB MIDI are used fully:
Each of those three devices also has an AUDIO IN that bypasses internal processing (and even the main volume knob) and outputs audio as-is. This signal is included in the USB audio output, too.
This makes those little devices incredible deals for portable music creation. For example, imagine you have a standalone groovebox like the Polyend Play and you just want to record your stuff with your iPhone. If you add a Roland E-4, you get both a vocoder/harmonizer to your setup that you can sequence with Play, and a class-compliant audio interface for your iPhone where you can use the AUDIO IN jack on the E-4 to route Play's output to.
I'm really impressed how Roland managed to cut down those devices to their bare minimum so masterfully. They left out so much but managed to keep every feature that actually matters. Sure, I can easily imagine additional features I would like to have but somehow the existing combination of features is flexible enough not to feel crippling.
I'm in love with the E-4 in particular because it's the device that got me singing, something I wanted to do but was afraid of for literally years. Having the voice processor with auto-tuning, vocoding, and harmonizing allows me to hide behind those things while my vocals are imperfect. But the way to get the vocals to be better is to actually sing. The E-4 gave me that confidence to do it.
Out now, a six track EP showcasing Polyend Medusa's digital FM:
mor4sso
Post by mor4sso »
didnt see it mentioned here, so thought i'd share for those that are exploring these
picked up a t-8 with the intention of having a few of my favorite roland drum sounds in a small box that I could control and modulate with my octatrack.
none of the controls on the panel are tracked, so don't expect to change parameters over MIDI.
just something I took for granted before buying. still like the thing a lot and its totally worth the price. has a surprising amount of depth and sounds great, but a few little tweaks (saving under the hood settings on power down and tracking the controls) would have made it a slam dunk.
rplktr
Post by rplktr »
Which ones aren't saved? On the E-4 power-cycling the device doesn't forget any settings. Knob and fader values are kept and MENU settings are kept.
mor4sso
Post by mor4sso »
rplktr wrote: Tue Jan 10, 2023 3:42 pm
you can adjust some of the instrument parameters under the hood on the T-8. (gain, overdrive, decay, tuning, snap, color, etc) but they don't save on power down afaik. :(
rplktr
Post by rplktr »
Let Roland know, this sounds like an unintentional omission.
Leviathant
Post by Leviathant »
mor4sso wrote: Tue Jan 10, 2023 2:52 pm picked up a t-8 with the intention of having a few of my favorite roland drum sounds in a small box that I could control and modulate with my octatrack.
Interesting! Thanks for the heads up. Considering people are still paying $150-$200 for a Boss DR-110, I'm astonished at how much bang for the buck a Roland T-8 gives you. I've got a Tempest and a TR-08 and I still feel the draw of the T-8.
DSI Tempest | Moog Sub 37 | DSI Poly Evolver Keyboard | TR-08 | SH-01A | JP-08 | SSL Big Six
anselmi
Post by anselmi »
Is there a way to set an exact bpm tempo on the E4 without using external sync?
rplktr
Post by rplktr »
anselmi wrote: Wed Jan 11, 2023 10:11 am Is there a way to set an exact bpm tempo on the E4 without using external sync?
This is actually a good question and I was also puzzled that there is no option to do that explicitly. It turns out that if there is no external clock, E-4 automatically figures out the tempo after you recorded the first loop. The loop duration determines the tempo. This is somewhat problematic because that means you cannot use scatter effects in your first loop. Or if you're not interested in the looper at all, you still need to record a dummy loop to set the tempo.
Fortunately, in practice, a MIDI clock is never really far away in my case, and I can always use eurorack or a Pocket Operator or my Circuit Mono Station for DIN clock. But it's a weird omission, indeed.
Here's another piece with E-4, this time with nothing else. Just the harmonizer controlled with Launchpad Pro. This was a little annoying to record because the harmonizer allows up to 4 notes and if you press a fifth note... the previous 4 just stop. So you need to be really careful about this, the effect is otherwise pretty jarring. What makes matters worse is that if you lift all your fingers, the harmonizer returns to the default interval set with [HARMONY] + [FORMANT]. This might be an interval far away from what you are playing and so also pretty jarring. What I ended up learning to circumvent this is to either hold the lowest chord note when switching to a different one, or to take a breath while changing the chord.
Obviously, this is not a problem at all when you sequence the harmonies via MIDI. This is only a problem for live performance a'la Imogen Heap. And I'm not even talking magic gauntlets :lol:
