Running Out of USB Ports. HELP!
peachesandbacon
Post by peachesandbacon » Tue Jun 08, 2021 11:39 am
So I'm running out of USB ports.
I've currently got:
Digitone
Digitakt
Midi Fighter
TR8-S
ES-8
Keystep
Mouse
Keyboard
USB to MIDI Box that goes to a MIDI to CV module.
External Hard Drive
That's 10 fricken USB connections.
the back of my iMac has 4 ports and I use one of these Mbeat powered hubs too.
https://www.mwave.com.au/product/mbeat- ... 20-aa00444
However the hub doesn't like everything I put in it, the elektron boxes don't get detected when they go into the hub for example, and same for the ES8 usb connection, so I only lets me use 4 things at once, despite it having 7 ports and it being powered from the mains. So I end up having to hotswap things in and out when I'm using them, which is less than ideal.
Is this a bandwidth issue or a power issue?
HELP.
What is the answer here?
Is there some industry standard MEGA usb hub that will JUST WORK with everything I throw at it?
I'm losing my mind a little bit over here, and I just want to fix this.
Magicube
Re: Running Out of USB Ports. HELP!
Post by Magicube » Tue Jun 08, 2021 11:59 am
This doesn't necessarily solve your problem, but I got this Sabrent USB extender/hub for the front of my iMac and it's great for shit you just need to plug in temporarily - like a phone or a CF card reader or whatever: https://eshop.macsales.com/item/Sabrent/HBIMCU/
peachesandbacon
Post by peachesandbacon » Thu Jun 10, 2021 6:57 pm
Thanks Magicube.
Yeah, ideally I want something to hide around the back to keep cable clutter to a minimum.
Comeon guys, 100 views of this post and not one of you have this problem?
kosmische
Post by kosmische » Thu Jun 10, 2021 7:27 pm
What about acquiring an additional hub? That might distribute things a little more evenly. Also fwiw I use an older wired Mac keyboard with USB ports, which isn't good for power but I can plug my mouse dongle right into it, works like a charm and keeps a port free. Or, maybe go Bluetooth for the keyboard and/or mouse? Not sure if any of this helps your situation but good luck to you regardless.
Red Electric Rainbow
Post by Red Electric Rainbow » Thu Jun 10, 2021 7:29 pm
cant you just use a mixer for your audio and a midi box for clock?
TOO FAR GONE
dkcg
Post by dkcg » Thu Jun 10, 2021 7:49 pm
How about a USB expansion PCI card? That would probably solve the problem of devices that don't like hubs.
Add 4 or 5 USB 3 ports for around $50-75, about the cost of a hub that won't improve too much.
But if it's a notebook or a Mac, sorry, not much help.
rowsbywoof
Post by rowsbywoof » Thu Jun 10, 2021 7:53 pm
Powered hubs are what you need. They're harder to find and cost a bit more, but you need one that will plug into the wall so it can better power all the devices going to it. I had nothing but problems until I went to a powered USB hub. Ended up doing one of the Sabrents and bought the additional power supply for it. All of my issues with picky devices cleared right up.
| Lake Onondaga || Bandcamp || Spotify |
WTB: Oberheim Prommer o// :heart: \\o
Sysagent
Post by Sysagent » Fri Jun 11, 2021 1:36 am
Anker 10 port powered hub
"The Most Annoying Man In The World..."
sierraoskar
Post by sierraoskar » Fri Jun 11, 2021 2:49 am
I have the same one and it works well for me, though I’m not sure I have as many devices as the OP :-)
mutierend
Post by mutierend » Fri Jun 11, 2021 10:42 am
I bought one of these for my rack and it works very well. I only put synths into it. All other USB devices go into a separate powered USB hub.
Robert
Co-host, Buchla podcast at http://sourceofuncertainty.audio
eb00
Post by eb00 » Fri Jun 11, 2021 11:15 am
I work in film post and frequently advise people on this. Anything mission critical 100% should be on a powered USB hub. Bus powered devices, although temporarily more convenient, are a recipe for disaster. I've seen several heat up and then either lose performance or die.
A good powered USB or Thunderbolt hub is worth every penny.
Jopy
Post by Jopy » Fri Jun 11, 2021 11:21 am
I’m also using the same powered Anker USB hub mentioned above and also will vouch for it. Much better speed and reliability relative to the unpowered device I used before.
BlinkyLights
Post by BlinkyLights » Fri Jun 11, 2021 11:30 am
I use this, a few years now, no issues whatsoever on both PC and Mac platforms.
Magicube
Post by Magicube » Sat Jun 12, 2021 11:53 am
OP's hub is powered already - is it not enough power?
Magicube
Post by Magicube » Sat Jun 12, 2021 12:08 pm
You can get a PCI breakout box for a Mac. I have one for my iMac that connects via Thunderbolt and use it for my PCI RME HDSP. I had moved from a Mac tower to the iMac and was glad to be able to just move the RME over. I'd put a USB card in there, too, but I got the two-slot version specifically for the RME. Great idea, though!
