Sampler for Drums
stk
Re: Sampler for Drums
Post by stk » Thu Apr 29, 2021 8:54 pm
Very good!
oozitron
solder fume huffer
Post by oozitron » Fri Apr 30, 2021 10:14 pm
The Roland S-550 sounds great for percussion and has 8 indie outs and a mix out. Not a huge amount of ram, but drums don't need a lot :-)
Drew
borg029un03
Post by borg029un03 » Sat May 01, 2021 6:44 am
Isn't the Octatrack an Option?
Industrial Techno Template for the Analog Rytm:
https://gum.co/wSHfG
Analog Rytm Techno Preset Pack:
https://gum.co/ERTPbMB
computer controlled
Post by computer controlled » Mon May 03, 2021 1:54 am
If you ever come across one at a good price, the Emax is killer.
Stuff: TR-8S . MX-1 . Waldorf MicroQ . Ensoniq ESQ-1 . Ensoniq EPS 16+ . Ensoniq VFX-SD . Yamaha MODX6 . DX7 . TX802 . SPX900 . MPC Live . RE-303 . Behringer Neutron . Behringer MS-101 . Behringer Pro-1 . Behringer K-2 . Behringer TD-3 . E-mu Emax II . E-mu EMAX II rack . PCM 41 . BeatStep Pro . Keystep .
Blairio
Post by Blairio » Mon May 03, 2021 8:09 pm
Drew
The 550's were 12bit / 32khz, but none the worse for that. Same goes for the S330's. The challenge is that you need a monitor and their proprietary mouse to use either properly, and ram was pretty restricted.
The OP doesn't want an in the box sampler, but perhaps samples could be captured via a DAW like Reaper, processed there, and then exported to something like a Volca Sample? Volca Samples have sound a minute's worth of sample time, and like the Roland S550 / 330 are 12 bit. This seems to give drum & percussion sounds a nice crunchiness to them..
gruebleengourd
Post by gruebleengourd » Mon May 03, 2021 8:34 pm
The roland samplers use MSX compatible mice. You can get/make a convertor to use any mouse with them. Look into vintage computer DIY sites. The original roland mouse is junk compared with a $2 optical mouse.
Blairio
Post by Blairio » Tue May 04, 2021 5:59 am
I recently sold my s330, together with the Roland mouse. That mouse was no great shakes, but the screen resolution on the 'S' series sampler GUI was so low that it didn't matter. Good to know to there is a cheap alternative out there for those to that need it.
Cheers, Blair
