Overstayer Modular Channel - Who has one?
Tumulishroomaroom
Re: Overstayer Modular Channel - Who has one?
Post by Tumulishroomaroom » Wed May 12, 2021 3:52 am
Hehe :) I love the Alphabase ! But I would say that any drum machine + modular channel is a winning combo !
Here's a little stereo recording straight from the overstayer, little jam / improv with the AB and modular :
instagram
dc11 x Resilience 1h live stream of improvised deep techno.
dc11 - Pulse Outputs 5 tracks ep on Unknown Movement
slumberjack
Post by slumberjack » Wed May 12, 2021 5:01 am
I'm so tempted to get this before the API 2500 I'm saving up for.
drowld
Post by drowld » Wed May 12, 2021 5:25 am
I've just ordered one :)
I hope it's not too long until it's made and that overstayer wasnt affected by the shortage of components
WTB: Mimeophon, Rossum Morpheus, Joranalogue switch 4
For trade: Instruo Cs-L, Waldorf Microwave XT, NE Manis Iteritas
MI Stages & some other stuff pm me
Modulus
Post by Modulus » Wed May 12, 2021 6:42 am
I ordered one about a month ago and the lead time was ~6 weeks. Not too bad at all.
They will reply to your PayPal email address with an approx lead time once they've processed the order (took around 5 days in my experience)
blech
Post by blech » Thu May 13, 2021 6:11 pm
It was almost exactly two months from order to delivery of mine back in December. It's incredibly versatile. You can subtly or radically improve/transform anything in a few different ways very quickly.
enno
Post by enno » Wed Jun 02, 2021 10:40 am
Obviously there's a huge price difference and some feature difference here, but has anyone by chance compared the overstayer with the analog heat?
blech
Post by blech » Wed Jun 02, 2021 2:43 pm
I have both but haven't done a formal one-to-one comparison of like features to directly compare the sound.
I do think the Overstayer offers a wider range applications and more numerous sweet spots, so to speak, due to the compression and the options you have for engaging and blending the different stages of the device. Meanwhile, it may be quicker to dial in a sound with the Heat, depending on how tricky you get with automation, sync, MIDI, etc.
Maybe another way to put it is that I'm happy to run all sorts of things through the Heat for some flavor, but I don't often find myself using it at the end of the mixing path to treat everything at once. Although, I'm sure someone out there is happily doing that, and I suppose I have used the Heat that way a couple of times when playing live with only a laptop and controller. It certainly provides a quick and satisfying way to do some final boosting/cutting and shaping before you hit the PA.
The Modular Channel, meanwhile, can contribute meaningfully in several ways on individual tracks or on the master bus in nearly every situation.
Tough to compare them as they each live in a fairly different category of component quality, design, and craftsmanship, despite the common features.
slumberjack
Post by slumberjack » Wed Jun 02, 2021 3:07 pm
I'm listening to NOFX right now, logged into this thead and just thought how well this piece could work with this kinda sound. But then no effects...
menagerie
Post by menagerie » Wed Jul 07, 2021 12:12 pm
I'm considering this as a sort of post-mixing, pre-mastering tool, but potentially also for the mixing process itself. If I am recording my modular with an ES-9, is the Modular Channel wasted on it? I'm pretty convinced that the ES-9 is high quality, but would appreciate some opinions here.
galaxie
Post by galaxie » Wed Jul 07, 2021 12:50 pm
Very inspiring! :sb: Makes me come up a few ideas to re-arrange my setups and signal paths.
Thanks for sharing. :tu:
8-)
Tumulishroomaroom
Post by Tumulishroomaroom » Thu Jul 08, 2021 6:42 am
Thank you ! I've posted a new one last week if you're interested, still with the Overstayer strapped on the master.
Oh and I also made a video dedicated to the Modular Channel with the Jomox Alphabase :
Also now that I've spent quite a lot of time with it I'm more confident with it for production, pushing it more, and damn does it sound amazing. it's incredible what it does to a track.
instagram
Dragonaut
Post by Dragonaut » Mon Jul 12, 2021 7:48 am
I heard in an interview that Boyz Noize uses the Analog Heat when he’s away from his Overstayer. Personally I’m at the point where I’d rather hold out for the Overstayer.
Dragonaut
Post by Dragonaut » Wed Aug 18, 2021 1:34 am
Can anyone tell me what CV I/O is available on these units? The only thing I’ve found for certain is a side chain input for the compressor. One that showed up on Reverb recently mentioned unlisted CV patch points that were available on the particular unit and I am wondering if this is the case with all units.
drxcm
Post by drxcm » Wed Aug 18, 2021 3:00 am
From Overstayer:
“There are CV inputs for L&R SAT and one for the compressor. Nominal 0-5V. They’re standard issue, just haven’t made it to the manual yet. “
I’m not sure if the earlier units have the same CV but the current ones do
wminor
Post by wminor » Wed Aug 18, 2021 11:04 am
I got mine back in early 2019 and I have those CV inputs. Never use them though, personally I think CV over the low and high pass filter cutoffs, or something else related to the filter / eq, would be much more useful.
I guess I should try out the compressor one... wish it was clearer what exactly about the compressor it affects. Might be good to get some interesting dynamics happening though.
Dragonaut
Post by Dragonaut » Wed Aug 18, 2021 10:38 pm
Thanks ya’ll
tl3ss
Post by tl3ss » Fri Aug 27, 2021 11:56 am
Just an FYI, I just hit 8 weeks of the 8 - 10 week estimate. I heard from Overstayer and they are predictably suffering from supply chain/component issues and they don’t have a solid ETA. I’m expecting another month at least before it’s ready. This is what I expected, but just wanted to give a heads up for anyone else that has placed an order recently.
I don’t mind waiting, I already waited 3 years to save up for it. Another month or two isn’t a big deal.
cfernn
Post by cfernn » Wed Sep 01, 2021 6:40 pm
Ordered one back end of April. Still waiting with no ETA. That's a little over 4 months now.
I'm starting to get a little concerned.
Just a warning to everyone.
Val
Post by Val » Thu Sep 02, 2021 2:15 am
I wouldn't be worried though, component shortage is real and hits hard.
Worth the wait, best processing machine.
Hope I'll get one someday too.
WTB: XAOC: Batumi + Poti
DIY kits (panel+pcb): NTO, DUSG, VCFS
DOEPFER: A-160-2
check out my rac
soundsculptor
Post by soundsculptor » Tue Sep 07, 2021 1:16 pm
Thanks ya’ll
I agree
don´t critisize it - equalize it
Nelson Baboon
droolmaster0
Post by Nelson Baboon » Tue Sep 07, 2021 1:55 pm
I ordered mine at the end of March. The initial estimate was in May at some point, but yeah - no ETA at the moment.
They have always been a very reputable and friendly company, and I'm not concerned about the order.
Dragonaut
Post by Dragonaut » Tue Sep 07, 2021 7:16 pm
Ordered at the beginning of August and given an ETA of November but it looks like that might have been a bit optimistic.
drowld
Post by drowld » Thu Sep 09, 2021 4:16 am
Just received mine yesterday it's been 3 months at least since i've ordered from FPA audio (france)
maciej83
Post by maciej83 » Fri Sep 10, 2021 5:56 am
I am just about to order. I assume you use DS version with synths/drum machines?
rareo
Post by rareo » Fri Sep 10, 2021 6:07 am
yes
