Just got one with a Z on the model sticker on the bottom, wasn't sure if just serial number designations (As this one is a low number following the Z), or if this may be a revision of the model?
Build looks nice, going to fire it up this evening
Unfortunately, I can confirm now, having tried a USB adapter explicitly named in the manual as a compatible device (Ewent EW3751), that live sampling does not work on my GR-1; it does not receive incoming signals from a sound card.metamorphmuses wrote: ↑Mon Oct 11, 2021 3:19 am I've tried out various configurations of the ES-9, but unfortunately, although the GR-1 recognizes it, I can't get any inputs to actually pass sound to the GR-1.
Then I plugged in an iRig Pro Duo, not expecting it to be recognized, but lo and behold the GR-1 does recognize it as well. But again, when I put the GR-1 in live sampling mode and press Select, the red record line starts but no sound comes through and no waveform shows.
Just to make sure I can feed the machine something of my own, I loaded some Wav files onto a USB flash drive and plugged it in, and the GR-1 does indeed load samples from that device.
Still, I really want to get live sampling working on the GR-1. I may have to buy one of the cheapest interfaces listed in the manual to make sure it's not an incompatibility with the ES-9 — that would make no sense since the ES-9 is definitely class-compliant.
I've finally got my GR-1 in hand so I can provide an answer to my own query. I tested audio input from the Digitone and indeed the GR-1 does recognize this an interface and I can record USB audio out from the Digitone.pmags wrote: ↑Sat Oct 23, 2021 7:43 pm Hey Wigglers,
I've got a GR-1 incoming and I'm curious if anyone has tried inputting audio straight from a Digitakt or Digitone, both of which are supposed to able to act as class compliant audio interfaces? I also see that the latest OP-1 firmware also allows for audio over USB. I don't know whether that means it now acts as an interface per se, but I wonder if this might work as well?
I'd be curious to hear about other creative ways folks are working with getting sounds into the GR-1 besides the standard audio interface or samples onto USB route.
I tried a MOTU M4 which is a 4 in x 4 out interface. In the GR-1 I couldn't choose individual USB channels but the interface did show up in the Sample page and audio recorded just fine from it. I assume (though I haven't tested this yet) that if the GR-1 is seeing multiple channels via USB that it just sums them all to a mono signal.metamorphmuses wrote: ↑Sat Oct 30, 2021 2:08 am
I wonder if anyone who uses an interface that works for them with the GR-1 but has more than one input can confirm that their GR-1 does not allow you to choose to sample from one input rather than another.
Thanks for testing and confirming that.pmags wrote: ↑Sat Oct 30, 2021 2:24 pmI tried a MOTU M4 which is a 4 in x 4 out interface. In the GR-1 I couldn't choose individual USB channels but the interface did show up in the Sample page and audio recorded just fine from it. I assume (though I haven't tested this yet) that if the GR-1 is seeing multiple channels via USB that it just sums them all to a mono signal.metamorphmuses wrote: ↑Sat Oct 30, 2021 2:08 am
The UM2 is too large for my purposes. I chose an Ewent EW3751 because it is literally the size of a flash drive.
That is small. I'm confused about the specs. Is it stereo in?metamorphmuses wrote: ↑Sat Oct 30, 2021 7:48 pm The UM2 is too large for my purposes. I chose an Ewent EW3751 because it is literally the size of a flash drive.
I assume it is stereo, but I have only tested it with the GR-1 so far, and the GR-1's behavior with the EW3751 is weird. If I plug in a stereo jack, the GR-1's input sounds like digital noise, with no trace of the signal coming from the other end (in this case, a Eurorack module), but if I plug a mono jack about 60% of the way in, I get a clean signal, and if I plug the mono jack 100% of the way in, I get no signal at all.scottmoon wrote: ↑Sat Oct 30, 2021 8:45 pmThat is small. I'm confused about the specs. Is it stereo in?metamorphmuses wrote: ↑Sat Oct 30, 2021 7:48 pm The UM2 is too large for my purposes. I chose an Ewent EW3751 because it is literally the size of a flash drive.
TECHNICAL
• Chipset: C-Media CM108
• Interface: USB 1.1 and USB 2.0
• Audio channels: 5.1 Spatial Surround Sound
• Connectors: 2 x 3.5mm jack for microphone and speaker or headphones
It's cool that the Digitone and GR-1 work together. I saw a video by "Meska" on YouTube in which he was using the Octatrack to do real time sampling of the GR-1 and vice versa; actually that video sealed the deal for me on buying the GR-1. So, it seems that using the GR-1 with Elektron gear really pays off.pmags wrote: ↑Sat Oct 30, 2021 1:15 pm {...}
Seems like volume levels via USB audio from Digiton are on the low side so I had to turn up recording volume to 2.0x on the GR-1 and set maximum track level on the Digitone, but it does work!
Unfortunately I don't think the USB on Octatrack acts as an audio interface. I think Meska must be running his Octatrack into an interface that's plugged into the GR-1 in that video. But this should work with pretty much all the other current Elektron devices.metamorphmuses wrote: ↑Sat Oct 30, 2021 11:03 pm
pmags wrote: ↑Mon Nov 01, 2021 12:38 amUnfortunately I don't think the USB on Octatrack acts as an audio interface. I think Meska must be running his Octatrack into an interface that's plugged into the GR-1 in that video. But this should work with pretty much all the other current Elektron devices.metamorphmuses wrote: ↑Sat Oct 30, 2021 11:03 pm
www.meska.frtremblap wrote: In theory, there is no difference between theory and practice.
In practice, there is.
Ah, well, my mistake then. Thanks Meska for providing the "authoritative" answer on the matter. I really love that technique that you show in the video. It almost makes me want an Octatrack to pair with my GR-1 (although in reality I have other devices that could serve that purpose). I really must try an "auto-generative" setup like that.meska wrote: ↑Mon Nov 01, 2021 2:01 ampmags wrote: ↑Mon Nov 01, 2021 12:38 amUnfortunately I don't think the USB on Octatrack acts as an audio interface. I think Meska must be running his Octatrack into an interface that's plugged into the GR-1 in that video. But this should work with pretty much all the other current Elektron devices.metamorphmuses wrote: ↑Sat Oct 30, 2021 11:03 pm
Yep the signal rooting is OT to GR1 via USB sound card, and back to the OT with Jacks![]()
I've tried a few granular plug-ins. My general experience is none of them sound as good or have the total grain count as GR-1. GR-1 has a very clean defined sound quality. You can really hear the individual grains. It isn't as smeared as most other granular synths I've tried.sprod1 wrote: ↑Thu Nov 04, 2021 7:19 am Hate to ask this question (especially on this forum!) - but are there things to do with the GR-1's approach to granular synthesis that cannot be replicated by VSTs?
I do love the sound of some of the demos and am willing to spend the money on a piece of equipment that is really bringing something unique. But at the same time im wary of investing in a piece of hardware that is doing something that a VST i've bought is already doing. On top of this i'm just curious as to its methods if it is indeed doing something unique.
I bought one new from Tasty Chips in the second half of 2021. The build quality of the hardware, including knobs, buttons and faders, all seem pretty solid to me. It's the software, the UI, that I personally find clunky (though I have not updated the firmware to the version that just came out, so there might be some improvements to the UI that I have not yet encountered).urogijani wrote: ↑Thu Jan 13, 2022 4:22 am Can someone confirm if the build quality of the unit is better now when the machine came out ? Some years ago I was in Berlin and visited the Schneidersladen store and there was a GR-1. I really liked it's look and sound, but somehow the build quality felt horrible. The pots and especially the faders were really wobbly. Maybe it was a really early unit and it was fixed meantime ?! I am looking into getting one, but can't find a store near to try it out again, so I would need to order it directly from Tasty Chips and I am curious if it is still the case or everything is fine with the build quality. Thanks.
metamorphmuses wrote: ↑Thu Jan 13, 2022 5:24 amI bought one new from Tasty Chips in the second half of 2021. The build quality of the hardware, including knobs, buttons and faders, all seem pretty solid to me. It's the software, the UI, that I personally find clunky (though I have not updated the firmware to the version that just came out, so there might be some improvements to the UI that I have not yet encountered).urogijani wrote: ↑Thu Jan 13, 2022 4:22 am Can someone confirm if the build quality of the unit is better now when the machine came out ? Some years ago I was in Berlin and visited the Schneidersladen store and there was a GR-1. I really liked it's look and sound, but somehow the build quality felt horrible. The pots and especially the faders were really wobbly. Maybe it was a really early unit and it was fixed meantime ?! I am looking into getting one, but can't find a store near to try it out again, so I would need to order it directly from Tasty Chips and I am curious if it is still the case or everything is fine with the build quality. Thanks.
Mainly I am referring to the file system, and I find the saving of 'performances' and 'patches' time consuming and unintuitive (saving 'samples' is not so bad).urogijani wrote: ↑Thu Jan 13, 2022 7:36 am Sounds good. Thanks for the reply. Nice to hearWhat do you mean about the UI ? Too much menu diving ? Or bugs ?
