Thanks for this, it helped me out quite a bit
Yeah; the best way is to sequence it externally. Then you can do all wild type of stuff that are more tightly controlled and sequence each instrument like a separate voice, very good for IDM type things. Not sure otherwise what you mean by non-EDM...it is a percussion or drum synth derived from electronic sources after all..so within that, there's limits. It's just a very groovy machine though. It makes you want to dance, even if that's not what you intend. That's why I intentionally don't use it in a piece if I want something more meditative and ambient. As where my Gotharman's Spazedrum is kind of the inverse, very much NOT EDM..I don't know how to describe it, just such a different personality. I have mine up for sale now because I'm willing to let it go of the 2 drum machines I own..but if I was able to keep it too, that'd be cool also, different instruments have such different personalities.charlie2 wrote: ↑Sat Jul 09, 2022 12:50 pm Currently have one on the way and excited to play with it. Curious if anyone here uses it for non-EDM type music? I'm starting to write some less traditional stuff and I'm interested to add this to the mix, but I'd love to see other uses if anyone has them!
You can quick-store the preset (encoder 16 click) after editing.toumpouris wrote: ↑Sun Aug 21, 2022 12:18 pm Is there any way to disable the new mbrane scenes/presets?
Every time I accidentally turn that knob i lose my current edited preset.
Like Expert Sleepers ES-‘something’.. do they need to go via a DAW or can it go straight into the AB?
Yeah but still annoying. how then you go back to your saved preset that you just quick stored?NoGuitars wrote: ↑Wed Aug 24, 2022 5:38 amYou can quick-store the preset (encoder 16 click) after editing.toumpouris wrote: ↑Sun Aug 21, 2022 12:18 pm Is there any way to disable the new mbrane scenes/presets?
Use the KIT/SEQ button?toumpouris wrote: ↑Wed Aug 24, 2022 8:02 amYeah but still annoying. how then you go back to your saved preset that you just quick stored?NoGuitars wrote: ↑Wed Aug 24, 2022 5:38 amYou can quick-store the preset (encoder 16 click) after editing.toumpouris wrote: ↑Sun Aug 21, 2022 12:18 pm Is there any way to disable the new mbrane scenes/presets?
Have you tried setting LFsyn to 128?seanandroid wrote: ↑Tue Aug 30, 2022 8:49 pm Hi wigglers! New AB owner here. I am running into an external clock sync issue and I cannot figure out how to fix it.
I have contacted JoMoX for their support with little luck on finding a solution.
Here is a video explaining the issue in detail but short form explanation is that internal clock is resetting the LFO to the correct phasing whenever I start and stop the sequencer. However, as soon as I try to clock it externally, the lfo starts at a random phase every time or takes a few bars to find it's clocking. I've tried clocking with ERM Multiclock, Elektron devices, USB via Ableton and it is the same behavior every time.
Any help is greatly appreciated! I am at my wits end.
You can live record trigs BUT... it wil activate the metronome, which is super annoying. You can deactivate the metronome, but that takes a few button presses.
That's actually incredibly frustrating. My AB is on the way and this takes a bit of the wind out of my anticipation. Well, Thomann has a 30-day return policy so we'll see how it goes.
mine does the same thing, or its similar. it loses the clock sync for the lfo periodically clocked with ableton/midi. mine seems to be fine %95 of the time, only needing the little catch-up moment sometimes. for me it doesnt happen every time i start clock. i dont know how to stop it from doing it.seanandroid wrote: ↑Tue Aug 30, 2022 8:49 pm Hi wigglers! New AB owner here. I am running into an external clock sync issue and I cannot figure out how to fix it.
