Nord Drum 2
tIB
Stainer!
Re: Nord Drum 2
Post by tIB » Wed Dec 30, 2020 4:59 am
Lep multicassa has been something I've enjoyed playing over.
dooj88
Re: Nord Drum 2
Post by dooj88 » Thu Dec 31, 2020 9:30 am
chvad wrote:
Sun Dec 13, 2020 3:17 pm
tIB wrote:
Sun Dec 13, 2020 11:42 am
I've had all three of the nord drums - the superiority of the 2s sound engine over the 3p is overstated - it has 2 extra parameters (one of which is an attack stage) but lacks some FX. The 2 has the trigger inputs obviously, which is a loss if triggering from modular, though the 3p has those pads. Win win really - the 2 and 3p are great machines. The one is pretty cool too in a far more stripped down way.
Having had the two and the three I totally agree. I just miss the form factor of the 2. I wish they'd pushed that out as an option with the 3.
solutions - individual triggers via midi
wuff_miggler
Re: Nord Drum 2
Post by wuff_miggler » Mon Feb 08, 2021 6:41 am
hmmm...so i'm trying to send midi from my laptop via Roland UM-ONE cable (usb to midi) to the ND2.
i have the nord set to global off/local control off
i can see the Roland cable light up when i send a midi message on channels 3-6 (and i can hear the drums play)
however - channels 1 and 2 do not light up nor sound.
Anyone experienced this?
wuff_miggler
Re: Nord Drum 2
Post by wuff_miggler » Sun Feb 21, 2021 3:58 am
bump.
tried a different older midi device (my NI Audio Kontrol 1) - ive set global to off, set local control off.
I can successfully send midi data on individual channels 3-6 but channel 1 (being sent on the audio kontrol and Roland Cable) is going to 2 on the ND 2 or not at all.
seems unlikely the ND 2 doesnt work on channel 1 and 2? also having the same problem on 2 different midi devices seems unlikely.
Im a bit stumped.
advrsry
Re: Nord Drum 2
Post by advrsry » Sun Feb 21, 2021 7:40 am
I remember that you can configure which channels it will respond to on the ND. Did you check that it's set up as you expect? The manual has the details, sorry for being vague.
wuff_miggler
Re: Nord Drum 2
Post by wuff_miggler » Sun Feb 21, 2021 5:05 pm
^ groan...
i just opened up the manual again - i was looking at the completely incorrect midi section before....which explains why some settings were missing - i am going to try it again tonight :D
wuff_miggler
Re: Nord Drum 2
Post by wuff_miggler » Mon Feb 22, 2021 5:45 am
all works fine now :-) midi notes were set to same numbers by previous owner - and i stupidly have not been moving to each midi channel on the ND and settings the note values there. works like a charm - love this drum module to bits! Nord Pad app is prety cool too for some fun :-)
theotteryears
Re: Nord Drum 2
Post by theotteryears » Fri Mar 05, 2021 4:07 pm
does anyone have a problem sending midi cc parameter change and a midi note at the same time?
when sequencing the WAVE parameter on 8th notes, and sending a midi note on 8th notes at the same time, the sound just becomes a click...
am I doing something wrong here?
Illiac
Re: Nord Drum 2
Post by Illiac » Sat Mar 27, 2021 1:34 am
It does the same thing for me. Not sure if there's a setting to change, but I just send CC's from a separate track in my DAW from the note sequence and it works perfectly.
wuff_miggler
Re: Nord Drum 2
Post by wuff_miggler » Sat Mar 27, 2021 2:17 am
^ i also send midi notes on the global channel - and individual CCs for each voice on their own midi channels.
theotteryears
Re: Nord Drum 2
Post by theotteryears » Sat Mar 27, 2021 7:06 am
cool - thanks for the replies. I'm using a Nerdseq though so am a little limited in free channels for this.
It only happens on the WAVE parameter though so I'm guessing the ND2 needs a little more time in loading this compared to other parameters...
Catchthehare
Re: Nord Drum 2
Post by Catchthehare » Thu Jun 10, 2021 8:27 am
Speaking of Nerdseq, here's an initial pairing with ND2 after I figured out all midi prgm and parameter changes. This one is using only 2 midi tracks on the Nerdseq.
Catchthehare
Re: Nord Drum 2
Post by Catchthehare » Thu Jun 10, 2021 8:28 am
Delete
acidbob
Re: Nord Drum 2
Post by acidbob » Thu Jun 10, 2021 10:21 am
Delete
NEVER ! HAHAHA! :slapfight:
wuff_miggler
Re: Nord Drum 2
Post by wuff_miggler » Thu Jun 10, 2021 3:52 pm
wow - neat - the nd2 is such a masterpiece :D @catchthehare - you need to make a recording worth of that shit :-) melodic, skittery, borderline breakcore/IDM is in short supply!
Catchthehare
Re: Nord Drum 2
Post by Catchthehare » Fri Jun 11, 2021 12:27 pm
Thanks a lot, I feel the same way! Will work on some more and get an EP together
