Sound of Shadows Expansion Module
Gear, Suggestions and Discussion.
Moderators: Kent, computer controlled, flight
Liquidyzer
Post by Liquidyzer » Tue Jun 10, 2014 7:52 am
Just got hold of my 1st sound of shadows, love it! This expansion would be a real +++ :tu:
TWINSTATES
I'd be keen
Post by TWINSTATES » Tue Nov 11, 2014 5:26 pm
ON A SOS expansion.
Purleaase.
Yours are some of my favorites, esp the SOS
R_bot
Re: Sound of Shadows Expansion Module
Post by R_bot » Wed Apr 07, 2021 10:02 pm
Has anyone ever diy’d an Expansion for the SoS?
I have typically enjoyed running the delay out through a diy passive lpf (resistor and cap), to darken the sound a little, but have no room for such extravagance in my current case....
I was thinking to make a passive in line thing I can have dangling, or sort of a shorting bar...but then it occurred to me that maybe I could make a little backpack for the SoS and put that on the expansion header.
From the manual and expander header notes it looks like the insert is, however, a break jack, so this doesn’t seem like it would work.
Anyone given something similar a try? Thoughts?
Very keen to not damage SoS.
flight
The Plague Bearer
Post by flight » Thu Apr 08, 2021 12:09 pm
I can't see a way to do a backpack-only LPF, but there is a non-destructive way to do it with two pins and a blank 3.5mm plug:
For your LPF backpack, use DEL-FB (rev1.3) / INSJSW (rev2) as your source pin and FBIN (rev1.3) / INSP2 (rev2) as your load pin. Then stick a dummy 3.5mm plug in the Insert jack to break the signal chain (this also bypasses the Insert level pot).
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
jsu
Post by jsu » Thu Apr 08, 2021 4:49 pm
Adding a power starve. :)
Edit: and a black panel :hail:
Maybe one day. Exciting!
R_bot
Post by R_bot » Thu Apr 08, 2021 10:01 pm
Thanks for the advice!!
Had not considered losing the insert level pot either...thinking i’m gonna be putting the sexy backpack solution down for the minute and gluing some jacks together for a 0hp solution..
flight
The Plague Bearer
Post by flight » Thu Apr 08, 2021 10:51 pm
Working on the starve, and the SoS already has a black panel.
~flight
Return to “Flight of Harmony”
