Ring modulator for contact mic junk metal
Discussing gear, production, and ideas for making noise music. Enough JMJ, let's rock like Merzbow!
Bataserpa
Post by Bataserpa » Sun Apr 16, 2017 5:42 pm
Once again I am here asking for help to improve my eurorack noise machine.
Part of my setup is based in a metal object with a contact mic connect to Mutable Instrument Ears then processed through some modules ( for now a filter and distortion). To give more dynamic in my harsh noise set I am in the need of a Ring modulator module.
Which one is nice for this kind of processing? I found some options, but don't know which one works better for this kind of sound. I think some with internal lfo ( like moogerfoger ring modulate) seems to be a better option.
For the use of ring modulator I am trying to replicate think Merzbow in the early 90's (pulse demon, electric salad, green wheels, noiseembryo, etc.)
Any help will be very appreciated. Thanks a lot
felixer
Post by felixer » Mon Apr 17, 2017 7:47 am
if you can diy there is this very nice ringmod chip: ad633, farnell now makes an easy to use board http://de.farnell.com/analog-devices/ad ... Gwodqb0AqA
it sounds very clean, which i think is what you want. even if you are doing 'harsh noise'
Bataserpa
Post by Bataserpa » Mon Apr 17, 2017 4:27 pm
Thanks for the tip Felixer
The problem is that i can not diy. So an assembled module is the only option for me.
felixer
Post by felixer » Mon Apr 17, 2017 10:33 pm
too bad, methinks it really does pay (and not only financially) to be able to make your own gear ...
the doepfer ringmod isn't bad. nothing sensational (and not quite as clean as a well built ad633) but ok, esp for the money!
Luis
Erica Synths - Fusion Ring Modulator V2
Post by Luis » Thu Jun 28, 2018 3:13 am
microphone --> mutable instruments ears --> erica synths fusion ring modulator
Jasonic
Post by Jasonic » Thu Aug 02, 2018 4:42 am
The Fold by Synthrotek has a built in ring modulator, and you also get a wave folder. The kit is rather easy to build. Or you can get it assembled. If you go with a Disting you will find a ringmod and much more.
PapaLazarou
Post by PapaLazarou » Sun Nov 04, 2018 3:14 pm
Are you not considering pedals? Only modules?
felixer
Post by felixer » Mon Nov 05, 2018 9:49 am
the line6 M5 (and prob others in that series) has a potent freq.modulator. works really well. i even sold myold ems one a i don't need it anymore.
Bataserpa
Post by Bataserpa » Tue Nov 06, 2018 6:38 am
Definitely pedals are an option, actually at this time more than modules, because my case is full and i have a ADDAC pedal integrator there.
I will check the Line6 M5 but recently the Way Huge Ring Worm pedal got my attention. Too bad the most videos i found in the net are with guitars, not many with synths. Does anybody have some experience with this pedal?
MindMachine
weekend warrior
Post by MindMachine » Sun Nov 11, 2018 2:06 am
Frostwave Blue Ringer. Best RM pedal ever. If you can find one - buy it.
For Euro modules score an Oakley RM.
Permafrost
Post by Permafrost » Fri Oct 18, 2019 2:34 pm
Hello Bataserpa,
What about the Ring Thing from Electro-Harmonix ? Unfortunately it can not be build into a Eurorack housing, but it is an amazing machine !
The oscillator can easily be tuned to an input tone.
It has are three inputs: Instrument, Modulation and Expression. If you use it for pitch-shifting, the expression-input can be connected to an expressionpedal, but the amount of shifting can also be controlled by CV.
The output is mono, for normal ringmodulation. But it is also possible to have separate outputs for upper- and lower sidebands.
Greetings, Permafrost.
Bataserpa
Post by Bataserpa » Fri Oct 18, 2019 8:05 pm
Thanks Permafrost. I will try out the ring thing. I only heard good thinks about this pedal.
ryangaston
Post by ryangaston » Fri Oct 18, 2019 10:11 pm
Bataserpa
I can very much recommend the Ring Thing. CV-friendly, separate carrier and modulator inputs, and a lot of other random cool tricks (also one of the best pitch shifters i've ever owned, even for polyphonic material).
I had that and a Moog MF102 at the same time—preferred the general sound of the 102 but the capabilities of the Ring Thing are pretty dang awesome
"I have always been outside and I've chosen to remain there."
--DB
thetwlo
Post by thetwlo » Fri Oct 18, 2019 10:41 pm
EHX Ring thing and the Frequency Analyzer are both great, only have the vintage Freq Analyzer, but the newer ones should be similar.
It was actually Nakahara of Violent Onsen Geisha that turned me on to to the Freq Analyzer at a noise fest (w/ Merzbow) in '95.
In Euro, the Oakley RM-4014 or a passive one like the first MakeNoise Moddemod or CGS.
Lovetone Ringstinger? Seems like a great pedal, many say it's king, didn't grab one but the clone doesn't look too hard to build.
Oh, the rare, Technosaurus Effexon is another fav! great parametric EQ and overdrive!
spilthyfred
Post by spilthyfred » Tue Oct 29, 2019 3:59 am
Have you checked out the Metasonix RK3?
EATyourGUITAR
has no life
Post by EATyourGUITAR » Wed Oct 30, 2019 7:44 pm
A ring modulator has 2 inputs. Sometimes a ring mod pedal or module comes with a sine oscillator to fill up the second input. The frostwave is the best ringmod pedal I have ever had the pleasure of using. It does not color the sound, no noise, no carrier bleed. They will go up in value. If you find one just buy it. There are a lot of ring mod modules on modulargrid. I have a guess that a lot of them are AD633. Hand matched germanium diodes, transformers...these are luxury vintage parts. After that it was either discrete transistor Gilbert cells, or MC1496. These are all obsolete now. You will most likely see AD633 or something digital.
If you are doing all square waves as the two inputs then you can ring mod them with an xor logic module. You don't even need a ring modulator for that. How decent it is depends on how digital your inputs are.
Return to “Synth Noise”
