CRAP Programmer
Buchla, Serge, Studio.h, Northern Light Modular, Keen Assoc., 1979, Vedic Scapes, etc. Usually expensive, often found sniffing corks.
KSS
Re: CRAP Programmer
Post by KSS » Thu Aug 13, 2020 9:03 pm
dksynth wrote:
Thu Aug 13, 2020 6:57 pm
KSS wrote:
Thu Aug 13, 2020 5:22 pm
No more Llama?? :(
never happened, you must have imagined
Must've been.. Cuz now i'm imagining some kind of unearthly toothy grin..
Miss the expression and red necktie of your former 'self'
KSS
Re: CRAP Programmer
Post by KSS » Sun Aug 16, 2020 9:26 pm
Looking at the new yummy 'CREPES' panel ;)
It seems the left-right jack and clock jack should be swapped. This puts the left-right jack on the same row as the switches involved in left right decisions.
The two knobs should follow their respective LEDs. If the preset LEDS are on the left, the knob to select preset should also be to the left. My crappy inet bandwidth allowance won't let me review the video until next month, so this may already be taken care of.
edit: Absent of knowing -remembering! which way things are now, I'd put "preset" to the left since "pre" implies "before" and we live in the West where reading is left to right. This also keeps "left-right" in its original position, and allows the input associated with the "Address"knob to remain connected without 'blocking' the Left-Right visual connection.
I also always look for convenient 3/4" shorting bar possibles during a banana layout, but don't see any here.
bitone
Re: CRAP Programmer
Post by bitone » Mon Aug 17, 2020 9:41 am
No more Llama?? :(
You could simply eliminate pulse from both. Leaving "Active Stage Output" and "Select Stage Input"
This allows you -as a designer- latitude over time in what you can do with these jacks. irregardless of that, both say exactly the truth.
While a stage is active, there's an output. And when you patch something into the other, it selects the stage. If the edge crossing parameters are met,
Red Jacks already inform part of the story.
there we go, conventions are good for something! that's what I'll do. Neither pulse nor gate are really true all the time so... drop it....
bitone wrote:
Thu Aug 13, 2020 5:36 pm
...would be very French (Serge's homeland) if somehow the acronym could be CREPE programmer, lol
hmmmmm
joke names are for prototypes is what I have decided :)
Complex Resettable Event Presettable Electromotive Source IS pretty good tho....
Ha! Love it.
How bout Complex RE-settable Preset Event Source ? ..you can get the RE from REset ;)
KSS
Re: CRAP Programmer
Post by KSS » Mon Aug 17, 2020 10:17 am
Using most of DKsynths new name on the 2nd proto panel, we can easily GRASP a new moniker.
Generally Recursive Addressable Sequencing Programmer.
Alt: Recirculating for Recursive.
Not that it matters, but I like CREPES better.
MuadMusic
Re: CRAP Programmer
Post by MuadMusic » Wed Aug 19, 2020 8:05 pm
dksynth wrote:
Tue May 26, 2020 8:28 pm
Programmer for LW format 4U modular
8 column, 4 row
Vertical sequencer with CLOCK and RESET
TIE and SKIP options per step
HOLD, RESET and PRESET for the horizontal sequencer
Preset Address
Gate Select IN and active stage OUT
Goes both ways
This is very cool ... any plans to make it available in 5U?
dksynth
Re: CRAP Programmer
Post by dksynth » Wed Aug 19, 2020 9:25 pm
Yes. I live near a 5U maker/designer and we are working on an expanded version. Adding some fuctions that 5U users expect to have onboard. onboard clocking oscillator, that kind of thing.
(something got changed or moved and I missed it)
re: bridgeable connections, I DID realize something silly I forgot to change. PRESET and RESET are now both one shots/edge detectors as I didn't think they should be combined with any kind of hold function when a HOLD jack is already present. They will be above and below the HOLD jack so that a shorting bar easily gives you hold on preset or hold on reset behaviour.
Reason: undoing the damage
Brian2020
Re: CRAP Programmer
Post by Brian2020 » Sat Aug 22, 2020 6:40 am
This looks incredible. Loving the Buchla 245 dna mixed with the Serge and your own influence. It appears equally suited for sequencing and tactile control.
Will this be diy only or is there a chance prebuilt modules will become available?
aethyr
Re: CRAP Programmer
Post by aethyr » Tue Aug 25, 2020 4:27 pm
Even if i had to lose a stage on each module, i would love two of these in one boat.
J3RK
Re: CRAP Programmer
Post by J3RK » Thu Aug 27, 2020 11:32 am
This looks like TONS of fun! Nice work! :party:
euu3
Re: CRAP Programmer
Post by euu3 » Thu Aug 27, 2020 11:04 pm
this is looking wonderful
http://youdontlikeit.bandcamp.com/
experimental/ dark ambient/ drone/ noise/ industrial/
_____
you dont like it products.
new tape & lathe cut 8" in next few months.
''Continuous vast gasps along a stagnant point we all physically have fomented further during, I relapse amidst my own lurking depth. Overly absorbed for only a branch I can grasp and withdraw.''
dksynth
Re: CRAP Programmer
Post by dksynth » Mon Aug 31, 2020 11:58 am
first little run is going to be all pre-built. DIY will follow.
maybe a 8 stage and a 4 stage is possible but... will be a ways down before I get to making variants, trying to get caught up on everything I've started and hoooooooo boy it's a full kettle. It pairs really well with O_C/Clee Quantizer and a clock source for the extra slots!
Brian2020
Re: CRAP Programmer
Post by Brian2020 » Mon Aug 31, 2020 2:40 pm
That’s great news as I imagine this would be over my head to attempt building it.
bitone
Re: CRAP Programmer
Post by bitone » Tue Sep 01, 2020 2:28 pm
[/quote] maybe a 8 stage and a 4 stage is possible but... will be a ways down before I get to making variants, trying to get caught up on everything I've started and hoooooooo boy it's a full kettle. It pairs really well with O_C/Clee Quantizer and a clock source for the extra slots!
[/quote]
no worries, stick to the script - 8 stage is a killer place to start!
ashleym
Re: CRAP Programmer
Post by ashleym » Wed Sep 02, 2020 5:19 am
Just a quick :tu: from me
jochem
Re: CRAP Programmer
Post by jochem » Wed Sep 02, 2020 5:21 am
I would be interested in a diy kit for LW format.
Subscribed and good luck with the progress!
Bigbang
Re: CRAP Programmer
Post by Bigbang » Sun Oct 18, 2020 8:08 am
Any progress on this? I would love to order...
Statispulp
Re: CRAP Programmer
Post by Statispulp » Mon Oct 19, 2020 9:03 am
+1 bumping for serious interest on the kit, and to give mad props to dksynth for blessing us with this design
dksynth
Re: CRAP Programmer
Post by dksynth » Mon Oct 19, 2020 12:05 pm
We’re gettin there! The usual COVID hangups in shipping and in my “day job” and everywhere else but it is getting worked on. Next version is sitting in my manufacturer’s queue juuuust waitin to get done.
I’m super excited to see what other people do with it! AND to refine things with an eye towards a touch-capable 16 step version... but the main goal is to bless MYSELF with these designs :twisted: once I’m happy with it then other folks get to play with my experiments
dreamcleaner
Re: CRAP Programmer
Post by dreamcleaner » Wed Apr 21, 2021 11:13 am
Arriving late here but, WOW!
This is great, really dreamy mods. Just the right ratio of Buchla to Serge. I would definitely buy a kit if/when it comes available. Also interested in the idea of a 16 step/ TKB version.
gtapes
Re: CRAP Programmer
Post by gtapes » Wed Sep 15, 2021 1:05 am
also late, but def interested. pcbs would be amazing, schematics would suffice!
