Prizes generously donated by:
ADDAC System (Eurorack 3U)
Endorphin.es (Eurorack 3U)
Studio.h (Buchla-format 4U)
All Music Easel expander cards
ArguZ
Re: All Music Easel expander cards
Post by ArguZ » Sat Mar 13, 2021 8:35 am
It's complicated...it seems.
Both the cardOC V1 and the cardOC V2 work with the 208r, 208p, BEMI 208 and also the BUSA 208C
However , it seems that on the Command version a daughter card is installed on the 208C itself that blocks the bus port for direct pitch control.
I say it seems because as of today i got three different reports and they contradict each other.
I hope to get a Command soon and see what can be done to get it 100% working which might mean modding it.
Ears
Post by Ears » Sat Mar 13, 2021 8:40 pm
What should be working that some are finding isn’t working? I’m not seeing anything amiss, but still learning both the Command and the card.
ArguZ
Post by ArguZ » Sun Mar 14, 2021 11:50 am
The shared pitch output does not give full voltage through the bus, but the banana patched to the voltage pitch input works.
The difference is this board which turns midi into CV and instead of using a summing opamp from the voltage input and the bus it only seems to add the keyboard input and mixes the bus instead.
MikeLeeBirds
Post by MikeLeeBirds » Sun Mar 14, 2021 12:28 pm
The Midi board says rev2. Maybe a rev3 can have a summing opamp? Something to suggest to Buchla?
Or would the main PCB need to be modified?
ArguZ
Post by ArguZ » Sun Mar 14, 2021 6:02 pm
Well, i am still waiting fore my Command and midi card and then i can make some proper measures.
There is always room for improvements, space for mods.
Question is if it's not better to chose another out port for a cardOC V3 as there i can cal the shots and no one was to void their warranty.
That card looks to me like any 200e module on the inside, including MCU and programmer, so i think this will also hold the preset manager part for future 200e integration...maybe..
Post by 01235813 » Sat May 29, 2021 3:00 am
:mrgreen:
antonriehl
Post by antonriehl » Sun May 30, 2021 3:22 pm
Whoa... I kinda wish that had a back on it, so the module isn't just hanging out in air... but cool it exists.
Post by 01235813 » Sun May 30, 2021 11:09 pm
I agree. It does have a clandestine look to it. I am not even sure if it is being sold/offered, definitely a cool proof of concept.
Radiance2021
Post by Radiance2021 » Sat Oct 23, 2021 4:06 am
Would there be interest in a simple version of the Baby8 sequencer on an aux card?
It seems like a fun and "hands on" thing to have on the 208.
Post by 01235813 » Sat Oct 23, 2021 5:40 am
:sb:
antonriehl
Post by antonriehl » Sun Oct 24, 2021 3:10 pm
Kuro teased an upcoming 295 comb filter card from Tokyo Tape Music Center on his instagram. Looking forward to this one!
antonriehl
Post by antonriehl » Wed Nov 17, 2021 12:29 pm
Some more Tokyo Tape Music Center cards to look forward to:
Xmit
Post by Xmit » Thu Nov 18, 2021 11:04 am
these look cool...
though I've got to say, as someone who already has an extra osc card (Papz's VCS3 )& the TTMC 291 filter card, the most useful 3rd card for me to slot in the Hub would be a LPG ( plus maybe an env ) card : the ability to actually turn that VCS3 clone osc into a true third voice, with it's own triggering & articulation would be amazing for when I play out live, in particular.
Please can someone make something that's like half a 281h & 292h stuck together on a card please... ;) :hihi:
Duplan
Post by Duplan » Mon Nov 22, 2021 11:34 am
Any update on this ? I have a proposition for a cardOC v1 here and am wondering if it's compatible with my Easel Command. And what I coud do with it... Not very familiar with Ornament&Crime... Thanks !
ArguZ
Post by ArguZ » Mon Nov 22, 2021 5:34 pm
Expect a announcement before christmas.
There will be switches at the back to reroute some ins and outs so it makes more sense with the 208C mounted in the command station.
Buchla turned the pitch port on the card slot into a midi note bus, and that is something we can't change.
But we can use that instead of of of the other CV ins and use it for transpose for example.
At the same time out A can be routed to a new modulation target.
But you should familiarize yourself with the possibilities of the O_C plattform in advance..
It is deep, vast and powerful..a lot of menu diving at first but hands on control once dialed in.
I am also working on Cheat sheets that will come out at some point...they are similar to the cardOC.21 ones, now that we got LEDs on the 2OC.21
Also the firmware will be identical , including the new blanking mode that eliminates any OLED noise when recording and not fiddling with it.
So, yes, there is a V3 coming :)
monokinetic
Post by monokinetic » Thu Nov 25, 2021 10:48 am
Oh that sounds intriguing! I assume it is just a firmware change and us v1 owners might be able to take advantage of it as well?
ArguZ
Post by ArguZ » Thu Nov 25, 2021 6:00 pm
It is :)
Ears
Post by Ears » Sat Nov 27, 2021 10:33 pm
That’s great news!!! Thanks ArguZ!!
Radiance2021
Post by Radiance2021 » Fri Dec 03, 2021 9:38 am
:sb:
Almost done....
ersatzplanet
Synthwerks Design
Post by ersatzplanet » Fri Dec 03, 2021 11:57 am
Someday I will get a 208 in some version and one of the first expansion cards I will make for it will be a trigger-able audio file player (probably based on a Wave Trigger or Tsunami PCB). My modular currently is only wave players and would love to post process through a 208.
-James
fallout
Post by fallout » Fri Dec 03, 2021 6:50 pm
:sb:
Almost done....
Sounds like an awesome project!
Post by 01235813 » Sat Dec 04, 2021 1:10 am
:sb:
Almost done....
:hyper: Any pictures of the work in progress? I'm always fascinated by the prototypes of easel cards.
Radiance2021
Post by Radiance2021 » Sat Dec 04, 2021 8:44 am
This is the prototype...
Post by 01235813 » Sat Dec 04, 2021 2:59 pm
:yay:
Sidiblue
Post by Sidiblue » Sat Dec 04, 2021 3:01 pm
:sb: :sb:
