Graphic EQ pedals
A place for the string slingers, pedal freaks and amp snobs in our midst.
chorus7
Yeah that's right
Graphic EQ pedals
Post by chorus7 » Mon May 03, 2021 5:58 am
Does anyone know if there are any graphic EQ pedals that have extreme cut and boost? Most I have seen are 18db/-18db not sure if that will cut that frequency band or just reduce it slightly?
Many thanks
Headphones73
Re: Graphic EQ pedals
Post by Headphones73 » Mon May 03, 2021 7:06 am
Try the Boss EQ20 pedal.
Gear owned: Hungry Robot Modular Output, Slew, Sample &
Hold, Sonicsmith Modulor A1, Behringer TD3, Korg EA-1, ER-1 MK2, Boss SP202, SP404, SP505, RE20, Line 6 M5, Akai
Miniak, S20, S2000, Moog MF102, MF104M, CP251, Dreadbox Taff2
Headphones73
Rex Coil 7
Post by Rex Coil 7 » Mon May 03, 2021 12:27 pm
Many thanks
... if you place two (more?) graphic EQs in series you will double the amount of cut/boost. For example, placing one 18db graphic EQ in series with another 18db EQ will produce a 36db boost/cut "EQ". I use this method all the time with my bass guitars ... I used to use a rack mount stereo 15 Band graphic EQ and run one of it's channels directly into the other channel producing a 36db boost/cut .. stomp-box type GEQs will work just as well (just fewer bands).
You may place any two EQs (graphic or otherwise) in series and produce the same results. Mind your output/input gain levels when using this technique.
5U MODULAR NORMALIZING PROJECT (for your entertainment) viewtopic.php?t=78836&highlight=
.. as of Dec 8th 2020 on a break for a bit .. contact me via bamco60@hotmail.com if needed.
WELCOME TO 2021 .. THE BEATINGS WILL CONTINUE UNTIL MORALE IMPROVES.
chorus7
Yeah that's right
Post by chorus7 » Mon May 03, 2021 2:03 pm
Many thanks
DAMN! that's genius :hail: thanks for the tip!
pricklyrobot
Post by pricklyrobot » Mon May 03, 2021 4:38 pm
MXR also have a fairly compact 10-band graphic EQ pedal. Only +/- 12dB, but might do the trick if you’re chaining 2 or more...
sduck
experimental use of gravity
Post by sduck » Mon May 03, 2021 9:21 pm
There's another (newer?) version of that boss one - the EQ-200
I have no idea if it's better or different.
flickr cloud of sound touyube NOT A MODERATOR ANYMORE
chorus7
Yeah that's right
Post by chorus7 » Tue May 04, 2021 5:37 am
I wanted to go cheap and the doubling up really blew my mind. I was thinking a couple of these
Noise and artifacts are really not a concern as much as being able to boost or cut frequencies
olix
Post by olix » Tue May 04, 2021 12:14 pm
I paid €20 for the 7-band EX Eno EQ7!
chorus7
Yeah that's right
Post by chorus7 » Wed May 05, 2021 6:00 am
How does it sound? Noisy?
olix
Post by olix » Wed May 05, 2021 8:17 am
It's not a Pultec but it's okay for my synths, drum machines, etc... No noise.
Return to “Guitars, Basses, Amps & FX”
