Buchla 200X serie 208X build thread
boops
Post by boops » Sat Jan 30, 2021 6:12 am
I open this thread about the 208X build
A few bundle kits available
03 june 21
Build guide ,first version file added .Special thanks to Ikinni .
An HD file will be available soon to zoom on the pics.
208X-BUILD_GUIDE(7).pdf
(1.93 MiB) Downloaded 32 times
28 april 2021
5 x 208X complete kits available,brushed silk screen aluminium or black pcb panel+sliders kits.
11 may 21
Ive updated the psu/Boat 4UX mouser basket ,new external brick
Missing a trace card 8,it’s happened when we have reduced the pcb ,to not touch the reverb frame
Pic above /below ,just add a small wire.
Infos /videos / sound demos of the 200X série
https://www.muffwiggler.com/forum/viewt ... 7&t=243688 Edit 20 april 208X initial power on,208X calibrations ,below in this post .
One TL074 added in the new card 12 bom
Edit the 14 April
Aux card pcb :R20:47k
Edit of the 7 April 21
CX1 /CX2 10uf on the MB pcb ,are voltages filter electrolytics caps ,added for the seq reset, there are on the seq card 1 bom section .
CX5 is 10 nf (forgotten in the last bom update )but it is ordered in the basket,sorry
If you choose the option to have the reverb mix level cv ,in the headphone (monitor) circuit,too
Use R73 or any resistor above 10k for R73X ,this resistance will be in serie with the trimmer TRX11 to calibrate the dry audio signal return following your wish.
And make the jumper .
The pic of the motherboard modification for my new card 12 here
https://modularsynthesis.com/roman/boop ... card12.htm
the mod is already done on your 208X MB with the addition of a trimmer.
First ,the micro PSU /Power Supply Unit for the 4UX boat
Pcb :micro psu used in the 4UX boat
Function 12V,-/+15V,5V
Power switch,ground banana,12V lamp plug
IMPORTANT FOR THE PROMOTIONAL 208X BUNDLE KIT BUILDERS
THE 2 INDUCTORS NOS 120mH ARE INCLUDED IN THE KIT ,DONT BUY THEM (70-IHD3EB820L)
Psu build pics /infos
viewtopic.php?f=17&t=243936&start=75
On the psu the 12V IN+/IN- infos are backward,solder your +12 V from the external ,thru the 12v dc jack to the RED SQUARE
Pics
208X parts note(1) 2.pdf
(23.49 KiB) Downloaded 34 times
24 March 21 notes:
A molex male right angle 4 pin connector for the MB is added to connect the MB pcb to the aux/ noise pcb
30 March 21 cleaner last boms use them
Only X parts bom updated the 24 March 21,use it.
BOM_PSU-208-s(1).pdf
(20.1 KiB) Downloaded 35 times
Corrected 10 uF lead space 5mm capacitor X4
A 100nf ceramic added
TL0 71 X1 added
6 x nuts added for the 3x 200 serie E switch toggles
important 208 build links
Original Schematics in this excellent site by example
https://www.dsl-man.de/display/DSO/Buchla+208+Clone
Build links
Card 12 build
https://www.modularsynthesis.com/roman/ ... card12.htm
DONT FORGET :ON CARD 12 TO SHORT PIN 15/16
208 build
https://www.modularsynthesis.com/roman/ ... 08spss.htm
https://www.muffwiggler.com/forum/viewt ... 7&t=211862
https://www.muffwiggler.com/forum/viewt ... 7&t=127084
ALL THE MOUSER BASKETS ABOVE +HQ ic sockets edit 24 March 2021
TOGGLE SWITCHES BASKETS For the project 208X with the 4UX boat (aux card)included.
Updated the 24 March 21 the SW25X reset toggle :on (on) toggle is changed by a (on) off(on) toggle
Medium quality E switch toggles +one CKK Mouser basket +6 x nuts for serie 200 toggles
https://www.mouser.com/ProjectManager/P ... c76751b569
OR
Medium Quality E switch brand only toggles, +6 x nuts for serie 200 toggles mouser basket updated the 24 March 21
https://www.mouser.com/ProjectManager/P ... f6ddf2970f
CKK high quality ,recommended but expensive toggles switches +3 x mini serie 200 Eswith toggles mouser basket added
Change the on (on) toggle by a (on) off(on) toggle
Not updated the 23 March 2021
https://www.mouser.com/ProjectManager/P ... 5dc04490e9
Mountain switch brand is fine too.
Only X parts mouser basket updated the 24 March 21,use it
https://www.mouser.com/ProjectManager/P ... fffff3f886
A molex male right angle 4 pin connector example
https://www.taydaelectronics.com/connec ... angle.html
Power Supply Unit PSU micro pcb +parts for the 4UX boat basket link
https://www.mouser.com/ProjectManager/P ... 98307abf80
208X Card 1 V4 basket link+HQ ic sockets
https://www.mouser.com/ProjectManager/P ... 7dff1aa857
Importants notes:
208X card1 only X parts with 2N3904/2N3906 transistors turn them at 180 degrees on the pcb card1 V4 or use BC 550/BC 560
Use it if you mod your 208 card1 with our reset seq pcb,too
https://www.mouser.com/ProjectManager/P ... a3a0eea432
208X Seq reset infos
208X card 2 V2 basket link +HQ ic socket
https://www.mouser.com/ProjectManager/P ... 866fc01c6c
208X card 3 V3 basket link +HQ ic socket
https://www.mouser.com/ProjectManager/P ... 2256a68a23
208X Card 4 V2 mouser basket
https://www.mouser.com/ProjectManager/P ... 7542e6f3c7
208X card 5 V2 mouser basket +ic socket
https://www.mouser.com/ProjectManager/P ... dbb38f5378
208X card 6 V2 the LM301 in the bom is Not available ,cancel it source it at Ebay by example.
https://www.mouser.com/ProjectManager/P ... 6bd99ad829
208X card 7 V3
https://www.mouser.com/ProjectManager/P ... e5d49c5d26
208X card 8 V2
https://www.mouser.com/ProjectManager/P ... 0067dc32e0
208X card 9 V3 mouser basket the 3 x LM301 not included source them at ebay by example.
https://www.mouser.com/ProjectManager/P ... 7cc7872e16
208X card 10 V2 mouser basket
https://www.mouser.com/ProjectManager/P ... 2ea7960252
208X card 11 V2 mouser basket
https://www.mouser.com/ProjectManager/P ... 657ec64297
208X card 12 V1 updated basket
For the 3x TO 220 insulator,an electronic local store is a good choice.
https://www.mouser.com/ProjectManager/P ... 47f1a5ba4e
208X MB V4
https://www.mouser.com/ProjectManager/P ... 01fbe8f43b
29 03 21 ,I ve found the flashy leds,updated with the low light better leds.
Ive updated the 10 pins power connector for this one better quality imho
https://www.mouser.fr/ProductDetail/798-CR6-10S-3.96E
HARDWARE
A note about resistors sourcing at mouser,the day of your order .
If ref 603-CFR-25JR-52-xx
is not available you can swap with
603-CFR-25JB-52-xx
The goal here is to have more than 10 resistors of the same ref to have the quantity discounted .0,085 to 0,042 ;)
I like the tayda electronics pots
Small bear,Thonk is fine,too.
Cheap Colored caps
https://www.thonk.co.uk/shop/switchcaps-sub-mini/
4 colors Rogan knobs to customize your 208X ;)
https://www.thonk.co.uk/shop/rogan-buchla/
For the vactrol ,I use Xvive VTL5C3 brand x11 for a complete 208X ,and 2 VTL5C3/2 for the card 10/card 11 (matched pair)
For the VTL5C3/2 on the card 10 and 11
208 X Parts ONLY BOM REV1 26032021 2-fusionne.pdf
(38.57 KiB) Downloaded 40 times
HARDWARE KIT IN STOCK
I offer the sliders ,stand-off,nuts washers ,screws in my harware kit,pm .
The reverb tank,BE CAREFUL THE COILS ARE REALLY FRAGILES,specially the output which has really thin wire
The ref I use has 2 strings 1BC2E from banzai ,like the original ,the banzai description is wrong(3 strings)
https://www.banzaimusic.com/accutronics-1bc2e.html
Initial 208X Power On ,208X Calibrations..pdf
(9.57 MiB) Downloaded 28 times
208X 200X modules serie ,Buchla 200 upgraded viewtopic.php?f=17&t=243688&p=3444875#p3444875
FS :custom buchla 203 style càbinet ,skiff new design,boat ,hardware for diy cabinet ,easel case ,new 1u to 10u to 56u and more. / New 208 buchla card 12 price down atm/
HQ small case buchla psu PCB
viewtopic.php?p=3118393#3118393
viewtopic.php?t=211862&highlight=
boops
Re: Buchla 200X serie 208X built thread
Post by boops » Sat Jan 30, 2021 6:29 am
The psu pcb (power supply unit)
boops
Re: Buchla 200X serie 208X build thread
Post by boops » Thu Feb 04, 2021 9:48 am
Card 1 +X parts Card 1 boms added
boops
Post by boops » Fri Feb 05, 2021 9:10 am
208X card 2 bom added
Radiance2021
Post by Radiance2021 » Fri Feb 05, 2021 5:17 pm
following this...
boops
Post by boops » Sat Feb 06, 2021 4:15 pm
Ive added the cards 1-2 build docs (parts number of an original 208) in the first post,you will use them to build the 208X
boops
Post by boops » Sun Feb 07, 2021 4:13 am
Build thread 208rev2 a lot of information
viewtopic.php?f=17&t=127084
Radiance2021
Post by Radiance2021 » Sun Feb 07, 2021 9:43 am
Seeing all these BOM's are for Mouser...has anyone ordered from them lately? (as in after Brexit?)
What are the shipping times?
I had an order at RS-Components which took 5 weeks to arrive due to stuff coming from their UK warehouse....
boops
Post by boops » Mon Feb 08, 2021 3:31 am
Mouser is in USA
I ve just ordered the last week
Order the Friday before 2pm,received the Monday before 1pm
Usa to France ,if your basket is above 50eu =free shipping,choose the option fees paid by mouser at checkout.Fast and no surprise at the delivery
Pic of a basket of only 22eu (then a shipping has to be paid)
Radiance2021
Post by Radiance2021 » Mon Feb 08, 2021 11:17 am
thanks, good news!
ikkini
Post by ikkini » Thu Feb 11, 2021 8:15 am
Great job boops !
boops
Post by boops » Thu Feb 11, 2021 8:50 am
thanks, good news!
Thanks les amis!
Your custom boat and vintage panel order is here
Radiance2021
Post by Radiance2021 » Thu Feb 11, 2021 9:11 am
Whoop whoop!
boops
Post by boops » Fri Feb 19, 2021 7:13 am
208X- 4UX-MICROPSU-AUX- NOISE- X MODS ALL BOMS.zip
(1010.8 KiB) Downloaded 26 times
Direct orders baskets:
Ive finished the card 1 and 2 mouser baskets (just missing ic sockets,there are expensives at Mouser)
Bom micro PSU /Power Supply Unit +parts for the 4UX boat
Mouser basket
https://www.mouser.com/ProjectManager/P ... F91FAC3D61
208X Card 1 v4 bom mouser basket
Ic socket missing
https://www.mouser.com/ProjectManager/P ... 826CB6263B
Mouser basket
https://www.mouser.com/ProjectManager/P ... 6A86BF4F80
208X card2 V2 bom
Ic socket missing
https://www.mouser.com/ProjectManager/P ... 1EB65FD006
208X card 3 V3
Ic socket missing
The 13M resistor is 12M+1M
https://www.mouser.com/ProjectManager/P ... 702DD698D0
ikkini
Post by ikkini » Fri Feb 19, 2021 11:05 am
Great !
Merci Boops ! :)
DanaFo
Post by DanaFo » Fri Feb 19, 2021 8:46 pm
Mouser basket
Ic socket missing
https://www.mouser.com/ProjectManager/P ... 757d40077f
Mouser basket
208X card2 V2 bom
Ic socket missing
https://www.mouser.com/ProjectManager/P ... 97297e4102
The mouser basket links don't seem to work?
boops
Post by boops » Sat Feb 20, 2021 3:27 am
Mouser basket
Ic socket missing
Mouser basket
208X card2 V2 bom
Ic socket missing
Corrected
The links are always in the post 1
Open a mouser account ,load and save each projects,then you can manage your final order easily
For a project like this ,a local store can good,for some parts.
I like the pots at tayda ,you will find plenty of parts ,which are missing at mouser by exemple the colored caps,ic sockets,molex connectors ,some e switch toggle,etc
https://www.taydaelectronics.com/potent ... c.html?p=2
Small bear is great
http://smallbear-electronics.mybigcommerce.com/
Synthcube
https://synthcube.com/cart/
In Eu
Farnell
https://www.farnell.com/
https://www.musikding.de/
Digikey in US
https://www.digikey.fr/
For the reverb tank,in EU
For the blue 56 edge connector not included 2x28 pins
Google ebay 56 pins edge connector 2x28 pins
FOR BUNDLE KIT WITH AN ALUMINIUM PANEL ,NO 56 BLACK CONNECTOR INCLUDED ,BUY 2X BLUE 56
Example
https://www.ebay.fr/itm/1-PC-Cardedge-c ... 3809008169
TIME TO LEARN A LITTLE ABOUT PICKING SOURCING PARTS
Remenber ,you will use a lot the switches when playing your 208X!
For the toggle switches ,the best are CK/NKK,(In the MB V5 bom)APEM
E switch (mouser ,tayda )are fine ,cheaper,or you can use generic Banzai,small bear
Take time and check the bom ,learn from the datasheets
We need
DPDT ON-ON-ON
SPDT ON-OFF-ON
SPDT ON-ON
SPDT ON-OFF-(ON)
SPDT SINGLE PÔLE DOUBLE THRU
DPDT DOUBLE PÔLE DOUBLE THRU
ON/ON 2 POSITIONS
(ON) for momentary switch
Check the size of the shaft,size of the toggle itself
PC pin,SOLDER pin ,THE BOTH ARE OK WITH THE 208X MOTHERBOARD (MB)
SHARE YOUR LINKS HERE THEN I WILL CHECK THEM
A note about resistor ,capacitor often it is cheaper to buy at least 10 parts than 1or 2 parts.
Example
10 x 0,12 =1,2 eu
3 x 0,45 =1,35 eu
Ive done the first direct order card mouser baskets ,card 1 ,card 2,psu,X parts ,fyi the ref for the resistor has been changed ,as the old ref are sold only by 200 now.
Feel free to continue for the next cards 3 , 4, 5, etc and share your work,I will check it of course .
fallout
Post by fallout » Sat Feb 20, 2021 10:51 am
What is everyone planning to use for the VTL5C3 Vactrols? I've read that the decay on Xvive versions are not very good.
ikkini
Post by ikkini » Sat Feb 20, 2021 11:28 am
I tried to make a Mouser basket for Card 3, but the resistors listed have to be ordered in multiples of 200 ! I'm pretty sure you wrote something about that but I can't find where ! ^^
Anyway, here's the basket :
https://www.mouser.com/ProjectManager/P ... 6d47d359df
DanaFo
Post by DanaFo » Sat Feb 20, 2021 3:14 pm
I'd get resistors from tayda or even small bear. Very easy to order from tayda.
boops
Post by boops » Sat Feb 20, 2021 3:21 pm
Great ;)
Just above ,use the ref of the resistor in the card 1 basket,Koa brand
ikkini
Post by ikkini » Sat Feb 20, 2021 3:25 pm
Ok, then I'll make a separate project for the resistors for all PCBs. It will be easier for me.
Basket for Card 4 (without resistors) :
https://www.mouser.com/ProjectManager/P ... 0e29bc8064
Basket for Card 5 (without resistors) :
https://www.mouser.com/ProjectManager/P ... a80691fb40
boops
Post by boops » Sat Feb 20, 2021 3:27 pm
Oh great ;)
ikkini
Post by ikkini » Sat Feb 20, 2021 3:41 pm
Basket for Card 6 (without resistors), but the LM301 listed in the BOM is no longer available, could you give me the reference of an equivalent ?
https://www.mouser.com/ProjectManager/P ... ece0fa3c57
boops
Post by boops » Sat Feb 20, 2021 5:29 pm
Ebay or local store
LM301
https://www.ebay.fr/itm/10-PCS-LM301AN- ... xyni9TFRMD
Your card 4 and 5 links give us the same basket :hmm:
