PROGUE - Analog mono synth - Available!
devinw1
Re: PROGUE - Analog mono synth - AUDIO DEMO
Post by devinw1 » Fri Oct 02, 2020 8:38 pm
Looking good!
That DAC looks tiny for sure. The 12 ch one I used for my TS0 module (Rhom BH2221) is the smallest IC on the board too. tiny little fucker.
JanneI
Post by JanneI » Sat Oct 03, 2020 1:13 am
djs wrote:
Fri Oct 02, 2020 6:46 pm
looks great! How small are the SMD DACs? 0805? 0402?
The smallest SMD passives are 0603 and MCU & DAC has 0.5mm pitch.
JanneI
Post by JanneI » Mon Oct 05, 2020 3:51 pm
Spliffgroen
Post by Spliffgroen » Mon Oct 05, 2020 4:34 pm
still down for pre-solderd version, good luck with the finishing of rev2!
JanneI
Post by JanneI » Sat Oct 10, 2020 6:02 am
Quick update: Progue REV2 proto PCBs have been ordered and I'll report back in a couple of weeks when I'll get them and build&test!
JanneI
Post by JanneI » Sat Oct 24, 2020 4:25 pm
Hi again, just keeping you posted:
REV2 boards are here. The analog side is done & tested already and the development of the digital side has started. Due to the fact, that REV2 has a bunch of 0.5mm SMD's, it seems that we are probably going for pre-soldered SMD boards for this project. I know some of you guys would like to build it from bare PCBs, but this way the project will be suitable for more builders. I will share info when/how these will be available, hopefully soon!
Mainboard with SMD's done:
JanneI
Post by JanneI » Sun Oct 25, 2020 4:04 am
Here's the main board with the THT components
midirobot
Post by midirobot » Sun Nov 08, 2020 2:59 pm
Looks great ! any idea of price ? would be in with no smd soldered : )
JanneI
Post by JanneI » Tue Nov 10, 2020 4:29 pm
Hi! Since I have multiple proto units fully built, I wanted to test them with a multi-channel midi2cv unit for polyphonic playing. There's no auto-tune, so it's a bit of a challenge to get them in tune, but I'm pretty happy with how they sound. Makes me wonder if there should be a PolyProgue someday, with a proper auto-tune... :hihi:
You be the judge:
PolyProgue-05.mp3
(1.1 MiB) Downloaded 5 times
Spliffgroen
Post by Spliffgroen » Tue Nov 10, 2020 5:56 pm
oef.. nice job JanneI! looking forward to a mono (and future poly version!)
grenert
Post by grenert » Wed Nov 11, 2020 1:57 pm
Wow, the poly demo sounds great! But I'm happily looking forward to a mono as well!
tron23
Post by tron23 » Sat Nov 14, 2020 8:38 am
The poly demo sounded really good. I would be down for the v2 if bare boards will be available.
rosch
roadkill
Post by rosch » Sat Nov 14, 2020 5:07 pm
I don't care anymore bare or presoldered. I'm in anyways.
Bjarne
Post by Bjarne » Sun Nov 15, 2020 5:34 am
Interested in presoldered SMD.
(I bought 5U 606 PCB’s from JanneI previously and they are absolutely beautiful in quality and layout.)
Cheers
mlw123
Post by mlw123 » Fri Nov 27, 2020 9:17 am
Case and PCB I am so in. So very in.THANK YOU EXCELLENT WORK!! :)
JanneI
Post by JanneI » Mon Dec 07, 2020 7:25 am
Quick update: Digital section (=midi2cv) has been tested and the firmware is in development. One simple (&stupid) PCB mistake forces me to order proto PCBs once more, but while doing this I can add a couple of test points and other handy add-ons to the main PCB. I'll also test build this once again checking carefully the build docs for mistakes and hopefully, everything is set to go. I'm not rushing this because I want it to be fully documented and tested before release so that the builder doesn't need to look for 10+ mods and fixes to get it working. Stay tuned!
devinw1
Post by devinw1 » Mon Dec 07, 2020 11:22 am
Ah yes, prototyping can be fun!
With SMT, it is indeed often just worth it to just re-order since the pick-n-place is doing all the work, rather than doing "surgery". :D
Cablebasher
Post by Cablebasher » Mon Dec 07, 2020 3:18 pm
I promised myself no more synths.
I’m in!
Cablebasher
Post by Cablebasher » Tue Dec 08, 2020 10:00 am
So what does the MW/AT switch do.
Does it control the amount of osc/vco mod from the internal LFO?
JanneI
Post by JanneI » Tue Dec 08, 2020 3:43 pm
Yes. There's an internal 2-channel midi to CV -converter: one channel for the 1V/oct osc pitch tracking and one for "LFO -> osc/vcf amount" which can be controlled via midi modwheel or aftertouch.
whoop_john
Post by whoop_john » Tue Dec 08, 2020 3:47 pm
I am happy with SMD. Go with it.
JanneI
Post by JanneI » Thu Dec 31, 2020 4:16 am
Update: The initial release date: "hopefully by the end of the year" didn't happen due to my stupid PCB routing mistake. Also, we had to make slight adjustments to the PSU section (DCDC converter related), which is tested already. I also added some modulation options ('cos why not?) so that that extra PWM tri LFO can be routed to VCF or VCO via the midi amount section.
Sorry to keep you waiting, but due to its (heavily) SMD design, I don't want this to be released with x amount of mods needed to be 100% functioning, so I rather take the time to test it as much as possible. This project is my main priority ATM, so it should be finished in JAN/FEB.
JSISYNTH.COM site is slowly coming to life too, for BOM, build docs, testpoint measurements, etc, and I will be opening it when this last iteration of the PCB is tested.
Here's "comic relief" in a form of SMD prototyping:
And here's "the extra warm sound -edition" with woodcheecks:
Happy New Year!
-Janne
Cablebasher
Post by Cablebasher » Thu Dec 31, 2020 8:23 am
Looks amazing.
I’m happy to wait until it is ready.
No one likes cutting traces!
So many DIY synths. So little time....
Bjarne
Post by Bjarne » Thu Dec 31, 2020 10:50 am
Yes, this looks fantastic! Happy new year!
B
devinw1
Post by devinw1 » Thu Dec 31, 2020 1:39 pm
Oh yeah that looks sweet with the wood ends!
And yeah, SMT board mods...ugh. No fun. Unless surgery is fun for you.
