Prizes generously donated by:
ADDAC System (Eurorack 3U)
Endorphin.es (Eurorack 3U)
Studio.h (Buchla-format 4U)
OPERA ROTAS, a DIY mutant drum machine BUILD THREAD
secrethero303
Re: OPERA ROTAS, a DIY mutant drum machine BUILD THREAD
Post by secrethero303 » Wed Oct 06, 2021 6:23 pm
I built mine and got it working today after a bit of hair pulling. Two issues I had to resolve.
1. No audio, similar to FungusCavern. Turned out that I had mixed up IC3 and IC4 on the OPL2 board. A quick swap and I have audio.
2. Trouble flashing boot loader and firmware with the ST-Link. I found that moving the jumpers on the blue pill from the 0 to the 1 position allowed it to be connected properly and get flashed, the returning the jumpers back and it works as expected when disconnected.
Hope this helps others having trouble.
SphericalSound
Post by SphericalSound » Wed Oct 06, 2021 7:21 pm
Bodo1967 wrote:
Wed Oct 06, 2021 4:08 pm
SphericalSound wrote:
Thu Sep 02, 2021 4:30 am
Download the lastest version of the firmware
https://github.com/spherical-sound-soci ... es/pangrus
OR_Pangrus_1.0.hex
For all non-Github experts who may have run into the same dead end as me:
Using that link and trying "right mouse button" => "save as" does not work for the firmware file (it does for the bootloader, though :hmm: ).
Use this link:
https://github.com/spherical-sound-society/OPERA_ROTAS
Then click the green 'Code' button, download the zip file, extract is, et voilà.
Flashing the BluePill apparently was successful now (haven't put it in the OR yet as it's already past 11 pm over here, but the ST Utility software behaved as expected and returned no error message this time).
Thank you, Bodo <3
SphericalSound
Post by SphericalSound » Wed Oct 06, 2021 7:24 pm
Regarding the jumpers, I have never touched them.
No need to alter them unless you exactly know what you are doing
secrethero303
Post by secrethero303 » Wed Oct 06, 2021 10:22 pm
You are right, I am able to consistently flash them now, without setting the jumpers. What I have found that works for me is pushing the reset button on the blue pill, immediately before clicking the Program and Verify button in the ST-Link Utility. That has stopped it from giving me any errors about not finding a device. Thanks!
Bjarne
Post by Bjarne » Thu Oct 07, 2021 12:23 am
Great that it finally worked! The reason I suspected the github download is that I and others have done the same mistake (for other binary firmware files)
Cheers
SphericalSound
Post by SphericalSound » Sat Oct 09, 2021 2:02 am
Ok, I can confirm that the MIDI chiclet works for the older revision (0.85) too. I will write a guide, is dead easy to implement it.
The people that wants one, please PM. It´s 20€ (shipping included) for the PCB only and 32€ for the soldered chiclet. In both cases you have to solder 3 additional cables for it to work. Is dead easy even for total beginners
The rest of users, with revision 0.9 and later dont need it
mercyofwolves
Post by mercyofwolves » Sat Oct 09, 2021 6:26 am
scuse me for my casual entry in this thread,
i expect it's less elegant than preferred, but using an arduino with usb support (leonardo) was extremely accessible, and offers a well supported route to midi connectivity,
Code: Select all
#include <MIDIUSB.h>
byte command;
byte channel;
unsigned long pulse = 1000; //  1000 = 1 millisecond
unsigned long time0 = 0;
bool note0 = 0;
void setup() {
  //pinMode(LED_BUILTIN, OUTPUT);
  pinMode(11, OUTPUT);
  digitalWrite(11, LOW);
  Serial.begin(192000);//(31250);
void loop() {
  midiEventPacket_t rx;
  do {
    rx = MidiUSB.read();
    if (rx.header != 0) {
      command = rx.byte1 & 0xF0;
      channel = rx.byte1 & 0x0F;
      if (channel == 0x09) {  //  channel 10
        if (command == 0x90) {//digitalWrite(11, HIGH);//noteon
          if (rx.byte2 == 36) {
            digitalWrite(11, HIGH); //c1
            time0 = micros();
            note0 = 1;
        //else if (command == 0x80) digitalWrite(11, LOW);//noteoff
  } while (rx.header != 0);
  if (note0) if (micros() - time0 > pulse) {
    note0 = 0;
SphericalSound
Post by SphericalSound » Mon Oct 11, 2021 5:41 am
Some of you have asked how to change the firmware: you have to pull one blue pill and push the other with the firmware that you want to play, here is the little visual aid:
SphericalSound
Post by SphericalSound » Mon Oct 11, 2021 5:44 am
Code: Select all
byte command;
byte channel;
bool note0 = 0;
void setup() {
void loop() {
  do {
            time0 = micros();
            note0 = 1;
    note0 = 0;
Thanks!!
SphericalSound
Post by SphericalSound » Mon Oct 11, 2021 5:56 am
The MIDI Chiclet uses 5 components and this schematic
1x10k resistor
1x220R resistor
1x6n137 optocoupler (dip-8)
1x4148 diode
1xstereo 3.5mm female jack (PJ324)
MIDIPCB.pdf
(11.61 KiB) Downloaded 23 times
fogoverparis
Post by fogoverparis » Sat Oct 16, 2021 11:09 pm
I'm having a problem trying to get midi sync to work. When I press SHIFT+AUTO the screen displays "MIDI" but becomes completely unresponsive otherwise. It doesn't sync to incoming MIDI and I can't un-toggle MIDI sync mode or make any other changes. I have to power cycle it to get it working again. Any idea how to fix this? I have a recently-purchased assembled unit.
SphericalSound
Post by SphericalSound » Sun Oct 17, 2021 12:43 pm
Yeah, you probably have an incompatible MIDI cable. There´s 2 standards, the Korg and the Roland. You have the other type, get a new 5pin to 3 stereo cable, the other type should work. Better get 2, both types, so one will sure work
Edit: Re reading your message, maybe is a different issue. Without the MIDI plugged, you still can´t untoggle it?. It´s strange.
Can you post what PCB revision do you have and what firmware revision do you have?
Last edited by SphericalSound on Sun Oct 17, 2021 12:47 pm, edited 1 time in total.
SphericalSound
Post by SphericalSound » Sun Oct 17, 2021 12:44 pm
For the people with revision 0.85 PCBs that wants to install the MIDI chiclet, here you have the instructions:
https://github.com/spherical-sound-soci ... 5_MIDI_Fix
Leighzi88
Post by Leighzi88 » Mon Oct 18, 2021 3:17 am
Is there a stereo MIDI plug on the unit? I thought the MIDI was via the USB cable?
.... I have my pre-assembled unit on the way, somewhere between Spain and Australia! :sb:
fogoverparis
Post by fogoverparis » Mon Oct 18, 2021 12:34 pm
Yeah even without MIDI plugged in it locks up everything to turn it on. PCB says 0.95, I don't know how to view the firmware version, it just says "Pangrus" when I turn it on.
SphericalSound
Post by SphericalSound » Tue Oct 19, 2021 1:17 am
Yeah, is in stereo 3.5 midi format... I shipped your OR yesterday. Should be there in a few days :cloud:
SphericalSound
Post by SphericalSound » Tue Oct 19, 2021 1:23 am
Yeah, is quite strange. You have the latest hardware and almost the latest firmware. Yours is 1.0, latest 1.1, is almost the same.
Does it work other combo keys?. It would be nice to check if the poly firmware reads midi ok to troubleshoot it. If you are thinking in getting it I can made you a discount. You can PM for it
SPIKE the Percussionist
Post by SPIKE the Percussionist » Tue Oct 19, 2021 5:40 pm
had a great time weaving the noiz from the Opera Rotas into last night's session...
i finally really got a grasp of the way it works since installing the updated OS.
it might help others quite a bit if all of the new key commands were thoroughly explained. :party:
more noiz!
- http://www.manipulate.net -
ASTROGENIC HALLUCINAUTING
DOGGEBI
morgue city
Unified Space
Post by SPIKE the Percussionist » Wed Oct 20, 2021 2:03 am
mother fracken satan frack...
just when i was REALLY getting some use out of this thing...THIS FRACKEN HAPPENED:
tried powering it with the second microUSB connection...the board powers up but NO screen...
seriously running out of curse words over here.
:bang: :bang: :bang: :bang: :bang:
i so hate these microUSB connectors.
more noiz!
DOGGEBI
morgue city
Unified Space
what gives?
Post by what gives? » Wed Oct 20, 2021 4:24 am
Yeah, the cable can sometimes exert a destructive leverage on those arduino usb connectors. Same thing happened to me on another board a while back. It really sucks...
Bodo1967
Post by Bodo1967 » Wed Oct 20, 2021 4:45 am
That sucks indeed :waah: .
However - you may have had "luck within the bad luck", as we say over here. The connector apparently "only" came off its solder pads, but without any further damage. They are relatively simple to (re-)solder even with a soldering iron. So I honestly believe this can be repaired by a farily experienced DIYer within a couple of minutes.
I cross my fingers (and press my thumbs, as we do over here) you'll get it fixed soon!
... why buy it for $100 when you can build it yourself for $150?
SphericalSound
Post by SphericalSound » Wed Oct 20, 2021 7:23 am
Im so sorry about this. Some chinese vendors dont solder the lateral legs that gives structure to the bluepill. I´ll be optimizing this too with my supplier so it dont happen again.
Please ship me back it for me to fix it. Im sending you a brand new one for free. PM your address
SphericalSound
Post by SphericalSound » Wed Oct 20, 2021 7:27 am
Yeah, is super easy to fix it, but I guess not all pleople is in the DIY side of the things. Normally Bluepills are quite solid, but that batch was probably not good soldered and weak. Bloody chinese, they screw a lot of things to save 0.01 cents of tin. I´ll be checking/soldering manually everyone so it dont happen again
Post by SPIKE the Percussionist » Wed Oct 20, 2021 4:56 pm
yeah...not the most well made devices.
:party:
thank you for the help!
more noiz!
DOGGEBI
morgue city
Unified Space
SphericalSound
Post by SphericalSound » Wed Oct 20, 2021 6:07 pm
:party:
Normally are solid. That batch it seems they forgot to solder the lateral pins. I´ll be inspecting by hand everyone and soldering it if needed so it does not happen again
